Sam Coombes Posted June 30, 2008 Share Posted June 30, 2008 What do I need to replace jsut my rear shocks? I've just rang Paddocks to see if the shocks come with the bushes, they said it depends if they are in the box when it gets delivered Not that helpful. So i'll order the two shocks, and then is it just the upper and lower bush each side? Thanks Quote Link to comment Share on other sites More sharing options...
harle Posted June 30, 2008 Share Posted June 30, 2008 Id say it would be rude not to include bushes with shocks What make from paddocks did you have in mind? I recently ordered de carbon from paddocks for the front shocks and the steering dampner, and they came with bushes. So id assume the rear shocks would have bushes (for de carbon at least) Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 30, 2008 Share Posted June 30, 2008 Yup, just the rubbers and the large washer things: part numbers: 14) hex head M12 nut NY112041L 13) retainer,outer NRC5603 2) bush,upper NRC5593 12) retainer,inner NRC5602 4) washer,damper lower fixing 500746 3) bush,damper mounting,lower 552818 5) washer,damper lower fixing NRC6235 Quote Link to comment Share on other sites More sharing options...
Orange Posted June 30, 2008 Share Posted June 30, 2008 Remember that part 5 (NRC6235) needs to be a dished washer with a lip to fit into the hole on the axle bracket. I ordered a pair of ProComp shocks and allof the washers were the same. This means that the bottom of the shock isn't located very well and ends up wearing the bracket and the shaft of the shock away (hence I was replacing mine!!) Luckily there were some spares lurking in the garage where I was doing the work!! In short....... The ProComps came with all the bushes and the right number of washers, but not all the washers were the right type. HTH Adrian Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 30, 2008 Share Posted June 30, 2008 I've never known shocks not to come with the rubbers (and new nuts for that matter) Les. Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 thanks guys, I may go for the pro comps then. I was looking at the britpart Gaz ones. diesel jim, where can i get the software that has all the info and piccys on like you've got? Cheers Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 30, 2008 Share Posted June 30, 2008 diesel jim, where can i get the software that has all the info and piccys on like you've got? You can either download it (from green oval in this case...bottom of page, and the manual is also handy,above the link), but if you're on dialup, it could take a while. Or i can burn you the discs when i get 5 minutes and fling them in the post (unless anyone else jumps in first) Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 i'll download at work mate Cheers ;-D Quote Link to comment Share on other sites More sharing options...
Cat_J Posted June 30, 2008 Share Posted June 30, 2008 I've heard that ProComps tend to fail at an alarming rate. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 30, 2008 Share Posted June 30, 2008 Sam Cut the nut off at the top mount. I'm told the pin very often shears off when taking the nut off. mike Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 cheers for the advice ;-) Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 would these be any good? Quote Link to comment Share on other sites More sharing options...
western Posted June 30, 2008 Share Posted June 30, 2008 Tep, if you just want bog standard ones Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 good enough for me, dont need nothing special. Are Craddock's reliable though? Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 30, 2008 Share Posted June 30, 2008 good enough for me, dont need nothing special.Are Craddock's reliable though? NOOOOOOOOOOOOOOO Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 30, 2008 Share Posted June 30, 2008 Occasionally They might say they have them when in fact they don't, so your money goes through the sound barrier into their account and then you wait......................................................... Some companies advertise genuine, but then send you 'white box' tat, which they claim is 'the same as genuine' - thereby ripping you off. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 30, 2008 Share Posted June 30, 2008 I'ev got a pair of delivery milage standard one here off of a 110 if you're interested. i got them from dunsfold, with a pair of equally new springs, but i only wanted the springs. apparently they've got about 20 miles on them. your's for £15 the pair. (i think there's the nuts/washers/bushes on them, if not i've got some nice yellow ones from a set of old OME's i had!) Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted June 30, 2008 Author Share Posted June 30, 2008 ah, best not order from Craddocks then.... What about cheap and cheerful Armstrong oens from Paddocks? Can get them for a tenner each - are they OEM? Quote Link to comment Share on other sites More sharing options...
Thon Posted June 30, 2008 Share Posted June 30, 2008 "I've just rang Paddocks to see if the shocks come with the bushes, they said it depends if they are in the box when it gets delivered" Not sure i'd bother buying anything from them with an attitude like that. If we answered a customers questions like that, we'd be hung, drawn and quartered, and rightly so. I'd take my money elsewhere. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 30, 2008 Share Posted June 30, 2008 Occasionally They might say they have them when in fact they don't, so your money goes through the sound barrier into their account and then you wait......................................................... Some companies advertise genuine, but then send you 'white box' tat, which they claim is 'the same as genuine' - thereby ripping you off. Les. Im in agreement with les, Just look for a topic a few weeks back on crappocks, put john craddock landrover in the search engine, Really everybody deserves a chance just tread very carefully with craddocks, A lot of members on here have had very bad experiances with them. By the way people, If you remember my topic about craddocks( the one I got slated on for my grammer ) Well you know I bought through ebay to craddocks and they messed me about with the brake lines etc etc Well yesterday they left me positive feedback saying good transaction on ebay They still dont know anything about the order Even after the manager phoned to inform me they were wasting my time lol Quote Link to comment Share on other sites More sharing options...
Eightpot Posted June 30, 2008 Share Posted June 30, 2008 They wouldn't have been my first choice, as Britpart gets a bad name by and large, but I put a set of britpart gaz shocks on the missus' disco along with some britpart HD springs and to be fair, the ride and handling is fantastic. I have to admit that the ride is better than genuine HD springs and Terrafirma shocks on my 90. Try MM4x4, highly recommended for service and delivery http://www.mm-4x4.com/suspension-146-c.asp Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted June 30, 2008 Share Posted June 30, 2008 The Britpart Gaz shocks I ordered did come with bushes if that helps. Quote Link to comment Share on other sites More sharing options...
