SteveG Posted January 22, 2006 Share Posted January 22, 2006 I want to protect the hardtop sides, mostly against tree damage that you pick up either laning or sites with lots of trees! So, I already have a front roll cage section off a 50th 90.. So what I was thinking was to fit this and extend it with some extra lengths of cds tubing down the whole side of the hardtop. a bit like this... Only neater and in tube not paint! Now if I do this do I just simply bolt the ends of the tube to the hardtop so that the whole thing still flexes and gives or do I put a bracing bar from one side to the next? I don't want to go the whole way of putting a cage in for now, as the 90 is dual purpose and I don't want lengths of tube running all over the place in the back taking up space etc and also for the costs. What does everyone think?? Ideas etc?? btw I'll also be adding Simon's side bars down the length of the sides. Cheers Steve Quote Link to comment Share on other sites More sharing options...
landrover598 Posted January 22, 2006 Share Posted January 22, 2006 Like this you mean It would certainly do the job, but i don't think it looks that nice to be honest Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 22, 2006 Share Posted January 22, 2006 Agreed, I think it looks horrible, BUT it DOES work, so its a case of living with uit Also consider MANTECd window meshs, or WVA too, they will help the glass stay in place (a bit More ) Simons Bars are an exellent piece of kit IMHO and will help as you know deflect trees etc from the bodywork, nicely made (as his all his stuff) and frankly cheap - try mking them gfor the money if you "Price" you time. Lastly unsure as to how effective the steps you have now would be vs proper side bars, depends on strength of units and mountings etc but consider this too.. HTH NIge Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 22, 2006 Share Posted January 22, 2006 Like this you meanIt would certainly do the job, but i don't think it looks that nice to be honest Looks ugly and won't be that effective IMHO. Steve, what about a Safety Devices, or simerlar, full external cage? There's no bars inside, it offers some roll over protection and superb bodywork protection. Noth Off Road do a nice looking one and they'd also be able to add a bar to go arround the back of the hard top to protect the back of the vehicle. Also, with this set up you could add in diagonals at a later date when you want them. I know my cage doesn't offer massive roll over protection but its a lot better than standard and I've done very little damage to the hard top (one very small dent when I slid backwards into a tree). Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 22, 2006 Author Share Posted January 22, 2006 Thanks for comments so far. What a bunch of tarts -"it won't look good" Lastly unsure as to how effective the steps you have now would be vs proper side bars, depends on strength of units and mountings etc but consider this too.. Wake up Nige this is mine, pics were just to show 50th front section The bar is there to stop the roof crumpling, as I have seen numerous times - I don't see why it won't be effective at that Will. Personally I don't like the external SD cage. The trees tend to be forced outside vertical bars and then spring back in. It also prevents me from fitting Si's side bars and lastly cost. Cheers Steve Quote Link to comment Share on other sites More sharing options...
darthdicky Posted January 23, 2006 Share Posted January 23, 2006 The one in Dave's picture is Bos's one which ties into the cage so is stronger than just having the outer part. That said, if you're not going for a full cage then anything like that tube will be far far better than just leaving the roof there - you don't need it to be bombproof if it's only going to lean on a tree gently to keep the roof the right shape! Make the roof/spreader plates a decent size and I can't see it being a problem... Richard PS. I don't think it looks bad, I wouldn't mind something similar on mine to protect the alpine windows! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 23, 2006 Share Posted January 23, 2006 We could swap roofs Steve, mine is pre-damaged so that you needn't worry about further damage Mo Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 23, 2006 Share Posted January 23, 2006 The bar is there to stop the roof crumpling, as I have seen numerous times - I don't see why it won't be effective at that Will. Personally I don't like the external SD cage. The trees tend to be forced outside vertical bars and then spring back in. It also prevents me from fitting Si's side bars and lastly cost.Cheers Steve Steve, I'm just worried that if the vehicle's at an angle or if there are overhanging trees you'll damage the top part of the roof. If you had bars the went along the top of the radius of the roof too that'd give much more protection IMHO. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 23, 2006 Share Posted January 23, 2006 Doesn't Simon do roof sliders as well as side sliders? I am sure he was looking for willing models for his kit a little while back. I'd say they'd be your best bet and I am sure you could negociate a bit of a discount.... Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 23, 2006 Share Posted January 23, 2006 Simon's roof bars would also spread any loads better than a bar with 2 or 3 mointing points. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted January 23, 2006 Share Posted January 23, 2006 I think it looks better than the usual set up thats just external over the front seats. But then I would I find the full length bars really useful for climbing about and securing loads to the roof. Will Quote Link to comment Share on other sites More sharing options...
