Shackleton Posted March 15, 2009 Share Posted March 15, 2009 Folks we're all bailing into a pals Td5 110 SW tonight for a wee trip west to catch some surf. There's a spot thought that may require a fairly long wade. What's the safe wading depth for a 110 Td5? I'm fairly sure the water wont be more then about 2ft deep, a standard Defender will handle that once a bow wave is maintained won't it? George Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 15, 2009 Share Posted March 15, 2009 I believe the standard stated depth is 500mm, half a metre. Which in real measurements is about 19-20" Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 & put the wading plugs in before you leave home. entre the water get a good bow wave formed & drive steady so it doesn't break up, the bow wave will form a depression under the engine. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted March 15, 2009 Author Share Posted March 15, 2009 Cool, thanks Aren't the plugs put on the truck from the factory? We'll be forgetting it if they aren't cause I don't got no spares... Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 the plugs are normall stowed either in the tool roll or with the owners handbook, if you can't find any you'll only need 1 for the clutch housing, the engine doesn't need one as the timing case is sealed. Quote Link to comment Share on other sites More sharing options...
Keith Keir Posted March 15, 2009 Share Posted March 15, 2009 Ye there was two in my tool roll in my Td5 thats where they will be Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 15, 2009 Share Posted March 15, 2009 except that TD5's don't have wading plugs Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 except that TD5's don't have wading plugs is there not 1 in the flywheel/clutch housing then ? I know the timing case hasn't got 1 that's why I mentioned it above. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted March 15, 2009 Share Posted March 15, 2009 except that TD5's don't have wading plugs there is one in the bottom of the bellhousing and there is also one about 2" away that is used for the seting of the timing well thats what my disco has and i would say that a defender will be the same Quote Link to comment Share on other sites More sharing options...
smo Posted March 15, 2009 Share Posted March 15, 2009 None of my TD5's were supplied with wading plugs, nor ever had any fitted/removed. Quote Link to comment Share on other sites More sharing options...
JST Posted March 15, 2009 Share Posted March 15, 2009 td5s dont have them Quote Link to comment Share on other sites More sharing options...
steven Hart Posted March 16, 2009 Share Posted March 16, 2009 Mine had wading plugs with it just had nowhere fit it. LAnd-Rover Recommend No deeper than 500mm with-out proper wading kit( Snorkel Axel Breather, ETC) Quote Link to comment Share on other sites More sharing options...
T1G UP Posted March 16, 2009 Share Posted March 16, 2009 Mine had wading plugs with it just had nowhere fit it. LAnd-Rover Recommend No deeper than 500mm with-out proper wading kit( Snorkel Axel Breather, ETC) TD5's will wade alot more than 500mm. BUT the ecu is under your seat! 500mm for a standard lr is enough to get through. whats the fasination with getting wet anyway? most people don't like going through a puddle in there euro boxes and there alot more water tight than a land rover! Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 16, 2009 Share Posted March 16, 2009 I've had mine in a deep ford up to the door handles, a bit scary as it started to float until the footwells filled up with water! Raised air intake and breathers certainly helped here. Check afterwards though that the seatbox (driver side) is not full of water, UCU may not like it! It's also worth while keeping a check on the bearings around the front of the engine - belt tensioner, fan etc, I have had to replace a couple on mine after the grease washed out, the seals don't seem that good. Quote Link to comment Share on other sites More sharing options...
