ashtray Posted April 15, 2009 Share Posted April 15, 2009 Speaking to my Mac distributor the other day, and hes managed to get hold of an alternative to the land rover 52mm hub tool. One of my complaints with the land rover hub tool is that it has no provision for using any form of ratchet or bar, only the use of a tommy bar ( or in some cases a couple of screwdrivers) So after a long time searching, i've finally found one with a 3/4inch drive! now most people's tool cases wont include a 3/4" drive ratchet, so if you want it you will need to buy a drive adaptor. The Tool is Made by Melco in Sheffield and its part no. is TBS 89 I got mine for £30, which yes is expensive for a hub tool but ive wanted the solution for so long i couldnt resist Below is the website for the tool company. But as yet i havnt found a website that you can order them through. Hope this little bit of info helps anyone who moans about the land rover hub tool Melco Tools Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 15, 2009 Share Posted April 15, 2009 I was given one of those as the chap had no more use for it! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 15, 2009 Share Posted April 15, 2009 I have a 1/2" drive impact socket the correct size, which I find perfect for the job. Can't remember where I bought it - think it was an online tool shop. I can have a look and see who made it if it's of interest? Quote Link to comment Share on other sites More sharing options...
SacredDog Posted April 15, 2009 Share Posted April 15, 2009 Speaking to my Mac distributor the other day, and hes managed to get hold of an alternative to the land rover 52mm hub tool.One of my complaints with the land rover hub tool is that it has no provision for using any form of ratchet or bar, only the use of a tommy bar ( or in some cases a couple of screwdrivers) So after a long time searching, i've finally found one with a 3/4inch drive! now most people's tool cases wont include a 3/4" drive ratchet, so if you want it you will need to buy a drive adaptor. The Tool is Made by Melco in Sheffield and its part no. is TBS 89 I got mine for £30, which yes is expensive for a hub tool but ive wanted the solution for so long i couldnt resist Below is the website for the tool company. But as yet i havnt found a website that you can order them through. Hope this little bit of info helps anyone who moans about the land rover hub tool Melco Tools I've had one of those for years, I think I got it from Kingsley Cross Country, only cost a couple of quid more than the 'cheap & nasty' ones. Colin. Quote Link to comment Share on other sites More sharing options...
mpb Posted April 15, 2009 Share Posted April 15, 2009 I've got a 1/2" Drive one from Difflock http://shop.difflock.com/land-rover-socket...drive-p-58.html Quote Link to comment Share on other sites More sharing options...
TD5 power Posted April 15, 2009 Share Posted April 15, 2009 i got the 3/4 drive version from difflock a bit expensive but well made and does the job. luckily i all ready have 3/4 drive for work but adaptors are cheap enough from halfords and the like, still has the hole to put a bar through if you wanted. matt Quote Link to comment Share on other sites More sharing options...
Mark Posted April 15, 2009 Share Posted April 15, 2009 Is the 1/2" drive one the right size for std LR hub nuts? ie 52mm? the link above refers to DII and p38 hub nuts, which I thought were different for some reason... I might be tempted to get one if someone can confirm that it is the right bit of kit for the job? Cheers Mark Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 16, 2009 Share Posted April 16, 2009 I've got a 52mm 1/2" drive impact socket - Laser I think, and it cost £12. Les. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 16, 2009 Share Posted April 16, 2009 I welded a gobby old 1/2 drive socket onto the end of mine for free Mike Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted April 16, 2009 Share Posted April 16, 2009 I welded a gobby old 1/2 drive socket onto the end of mine for free Mike Yours cost you the welding wire and gas , mine cost me nothing as I was given the box spanner and used your welder . Pete. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 16, 2009 Share Posted April 16, 2009 I've also got a 52mm 1/2" drive impact socket, I think it cost around £18 but well worth it. Quote Link to comment Share on other sites More sharing options...
mpb Posted April 16, 2009 Share Posted April 16, 2009 Is the 1/2" drive one the right size for std LR hub nuts? ie 52mm? the link above refers to DII and p38 hub nuts, which I thought were different for some reason... I might be tempted to get one if someone can confirm that it is the right bit of kit for the job? Cheers Mark It's the standard 52mm socket so fits the hub nuts. I've been using mine on my 1996 Defender 90. HTH Quote Link to comment Share on other sites More sharing options...
nicks90 Posted April 16, 2009 Share Posted April 16, 2009 I welded a gobby old 1/2 drive socket onto the end of mine for free Mike same here - why pay for something when you can do it for free! Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 16, 2009 Share Posted April 16, 2009 I think the best of them all is the Franklin Hub nut spanner 52mm... B) wicked!! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 16, 2009 Share Posted April 16, 2009 I've got a 1/2" Drive one from Difflockhttp://shop.difflock.com/land-rover-socket...drive-p-58.html Ditto, works great, much better than a tommy bar that all it wants to do is slip out and bash your knuckles... Quote Link to comment Share on other sites More sharing options...
henk Posted April 20, 2009 Share Posted April 20, 2009 I've got a 52mm 1/2" drive impact socket. I also have such socket, works fine on rear axle but too short for TD5 front axle. Which one mentioned here also works on a front axle ? Henk Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted April 20, 2009 Share Posted April 20, 2009 It would seem that there are after-all many different options....... shame the OP didn't know of the alternatives before he spent near on double what he need have.... Quote Link to comment Share on other sites More sharing options...
antichrist Posted April 21, 2009 Share Posted April 21, 2009 I took two old hub nuts, fitted some 6" lengths flatstock around them, and welded them up, then removed the hub nuts. Welded on a piece of flat steel on one end with an old 3/8" socket attached. I won't say it was totally free, but it was cheap Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 22, 2009 Share Posted April 22, 2009 I tend to find that a lot of people have used a hammer and chisel Les. Quote Link to comment Share on other sites More sharing options...
SacredDog Posted April 22, 2009 Share Posted April 22, 2009 I tend to find that a lot of people have used a hammer and chisel Les. Yep, that was what I found when I had to change my Hub after terminal Bearing Failure, it was so butchered I had to chisel off all the burrs to get the proper tool on the nuts. Colin. Quote Link to comment Share on other sites More sharing options...
antichrist Posted April 23, 2009 Share Posted April 23, 2009 Yep, that was what I found when I had to change my Hub after terminal Bearing Failure, it was so butchered I had to chisel off all the burrs to get the proper tool on the nuts.Been there, done that. But if they are that bad I usually chisel them off and replace with a new nut.Sometimes there's enough left I can just grind all the burrs off on with my bench grinder and reuse them. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 23, 2009 Share Posted April 23, 2009 The act of butchering is very common actually. I took over 4 coffee breaks before the d£$¤m thing budged!! But with the spanner at hand one tough tackle and it turns... Quote Link to comment Share on other sites More sharing options...
