Shop that sells the TD5 dash switch plugs
Because I was too stupid to save the link when I saw it posted before and now I can't find it :(
Pretty please :D
Mo
The Black one -
http://shop.dingocroft.co.uk/acatalog/Electrical_Miscellany.html#aZZPLUG01
Connector Kit for Defender Switches Ref: ZZPLUG01
Application: Defender 2001 to 2006 with the facelift dash.
Description: Connector kit for auxillary switches on centre dash.
Price: £4.15 (£4.88 Including VAT at 17.5%)
The White one -
http://www.expeditionexchange.com/cart/product.php?productid=19291&cat=288&page=1
Connector Kit For Disco2 Cruise Control Switch
Details
SKU CKD2
Price: $4.00
The Hazard Warning Light Switch Connector -
http://www.easternbeaver.com/Main/Elec__Products/Connectors/090_Connectors/090_connectors.html
10 Position 090 HM Connector
Fits wires from .5mm - 1.25mm (22 - 16 AWG).
With complete set of terminals.
10P090-HM $6.95 ea
  • 11 months later...
Update on my previous post
The Black one -
Price: £5.50 (£6.60 Including VAT at 20%)
The White one -
Details
SKU CKD2
Price: $4.00
Also available from -
http://shop.dingocroft.co.uk/acatalog/Electrical_Miscellany.html#aZZPLUG02
Connector Kit for Defender Switches Ref: ZZPLUG02
Description: Connector kit for auxillary switches on centre dash. This is a direct fit to the rear wiper switch YUG000350LNF, but will fit the other switches if the splines are removed with a small sharp blade such as a modelling scalpel.
Price: £5.25 (£6.30 Including VAT at 20%)
10P090-HM $6.95 ea
Spare Terminals for the 10 Position 090 HM Connector
(handy if you've sourced an old connector from a scrappy)
FM090 Terminals (10 males/10 females)
FM090 10 Sets $3.95
http://www.kojaycat.com/Motorcycle%20connector%2010%20way.htm
10 Way Connector (HM09010)
For wires from 0 .5mm - 1.25mm (22 - 16 AWG).
Complete White connector is supplied with both male and female tinned brass terminals.
£9.25 + VAT
Jumping on this post as it seems to have the TD5 wiring answers
Does anyone know where I can get the accompanying adapter for the td5 binnacle clocks (I have the 16 and 20pin ones for the warning board) - the socket that takes the temp, fuel, speedo, illumination etc to the clocks.
Cheers,
James
Cheers,
James
I think they are like rocking horse s**t. I'm pretty sure that most of us, that have done the td5 upgrade, just buy a suitable multi plug connector and use that to connect the guage and lighting loom to the dash loom.
I think it was somewhere within the 'wibbly wobbly speedo' thread this was mentioned.
HTH
HTH
As you say, info.is in the 'wibbly wobbly speedo' thread, but I'll post it here as well.
The Connector you're looking for is a Sumitomo HD Series 14-Way Female Connector
Sumitomo Part No. - 6090-0253
If you want to try and source a used connector, they can be found in -
  • TD5 Defender - Main Harnesses (Main Harness to Instrument Harness - C1040)
  • Freelander 1 - Main Harness (Passenger Compartment Fuse Box - C0581)
  • Discovery II - RH Electric Seat Link Harness (C0772)
and, according to the Rover RAVE -
  • Rover 600 (LHD & RHD - 2.0L MEMS & Diesel) - Cabin to Side Harness, LH Side (C062)
  • Rover 600 (LHD & RHD - 2.0L MEMS & Diesel) - Cabin to Floor Harness, LH Side (C078)
The Female Terminals are the same as the ones used in the Hazard Warning Lights Switch -
Sumitomo 090 Female Terminals -
Part No. - 8240-4422 (for 0.5-1.25mm2 cable)
Part No. - 8240-4412 (for 0.3mm2 cable)
Available from SWS-Europe...in quantities of 5,000 :P
I just used a 15-way multi-plug connector pair as Paul above says. You could raid a scrapyard vehicle and cut the plug off the loom, I've heard of it being found in Freelanders and Hondas. Then you'd solder your vehicle's wires onto the wire tails you acquired.
... I've heard of it being found in Freelanders and Hondas.
Isn't the Rover 600 based on some sort of Honda?
... Then you'd solder your vehicle's wires onto the wire tails you acquired.
Or, you could use the scavenged Connector Shell with new terminals crimped onto your wires.
Yes I think so. I had a comment on my tech blog from someone who said they found it in a 1998 Honda. In fact I think it was from a chap called Muttland, who I believe posts on here.
Yep, one of these Accords:
http://en.wikipedia.org/wiki/File:Honda_Accord_rear_20080205.jpg
You can see the similarities I am sure!
Well what are you doing with it? Just converting an earlier vehicle to Td5 dash?
If so you only need an 11-way connector, the Td5 setup only uses 13 of the 14 pins in the connector, and two are unused for the basic conversion (the YK and K wires). So a 13-way Econoseal would be fine, just replace it pin-for-pin.
The Black one -
http://shop.dingocro....html#aZZPLUG01
The White one -
http://www.expeditio...&cat=288&page=1
Details
SKU CKD2
Price: $4.00
http://shop.dingocro....html#aZZPLUG02
http://www.easternbe...connectors.html
10P090-HM $6.95 ea
FM090 10 Sets $3.95
http://www.kojaycat....%2010%20way.htm
£9.25 + VAT
got this today, fits perfectly, and as you dont need the male connectors you can snip the first third off them and use then to connect directly to the individual terminals on my electric window switches although £10 is a bit steep for a socket :-(
 Share
