Brake Pipes
Need a bit of advice for replacing my brake pipes. New chassis will be going on next week. I know I need a brake pipe flaring tool but is there much difference in quality between the different brands and also is there a technique to doing it. I've got a lot of time to play about with it and can still look at the old chassis for reference.
Also can someone tell me which pipes go in where into the servo (diagram of some sort maybe) as we kinda forgot to detach the g-valve (I think that's what its called) from the bulkhead and ripped all the pipe up when we lifted it.
I like breaking stuff. Means I have to learn how to fix it.
Cheers
Jethro
Oh yeah and what size pipe do I need. Is it 3/16"?
I got a draper flaring kit and its ace!!! now flaring takes a bit o getting used to but its tiddle easy when you get it... Think I found it on fleebay for a song!
I took me ages becasue I didn't quite read the instructions properly :unsure: ... make sure you put a blob of greese/lub on the mandrel before you slide it into the end of the pipe - lub is the key to a good flare!
very satisfying!
If you use the kit to form ends on copper pipe use a bit of brake fluid rather than grease or oil to lubricate the mandrel.
I have one of the cheap kits and it works reasonably well with practice although I think the better ones work every time all the time.
You're welcome to have a go with mine if you want?
Cheers
Jethro
My local motor factors make up brake pipes, just measure the length(s) and specify
what unions are required, or take in the old ones as a pattern. They can often do this
while I wait, or at least the same day, using copper pipe. Pretty cheap as well.
Don't you have such a place in your area? Nothing wrong with buying your own kit, of
course, depends how often you feel you may need it. You also need a selection of unions.
Just had to rip loads of copper pipe with zinc plated steel unions off my 90 that some muppet had fitted. The well known galvanic action had seized the ends on to the pipe, and the copper had sort of sagged between clips. The pipe itself was fine. So when I came to replace the hoses, I just ended up twisting the ends off. Replaced with kunifer pipe with brass ends - with a bit of luck that will not be so bad to undo in the future.
Nigel
  • 2 weeks later...
from Defender workshop manual, refer to the upper left diagram for your 90.
Cheers ralph. Very handy.
very satisfying!
I think I was looking at the same things. Did it come in all different parts, there seem to be some grips like ones too
The pipes from landrover arent particularly expensive.
I priced up the long front to rear pipe the other day and its 12 quid...
For that money theres no point messing about with flaring tools etc.
Depends how long you will keep it for. Steel pipes from LR will still rust, whereas a copper pipe will last the life of the car
I think if its steel pipe coming from LR then I'd rather make up some copper ones. Unless I just waxoyled over them afterwards.
Cheers David I may have to take you up on that if I ever get a spare day ;)
I shall ask, there's a couple local here.
