My 8x8 idea
Hope he has an 'Escort ' vehicle ( pass wide and slow of this dangerous pile of poo)to get him there.
Just reading on the Pirate links, and didnt realise that being in the forces made you an expert in modifying Land Rovers as he claims????
I would think that he only intends to use the standard 4x4 on the road , as the foley units dont have interaxle diffs . Should give him extra flotation and traction on slippery surfaces with the extra two axles driving , as long as he only wants to go in a straight line , as I dont think steering will be that effective!! Axle 3 and 4 will eat tyres as well ! Once he made the decision to fit extra axles he would have to drive them as having an undriven axle can end up being as bad as just 2wd JMHE with a tacr2a (6x4 range rover RIV)
cheecky BUMP
i had an '86 issue of LRO with the ESARCO in and ive loved them ever since.
the drive line is nice and simple and pretty amazing tbh.
personally id have a big diesel in it and run it on interlinked parabolics due to not having enough travel in the props to get much flex
IIRC the 1st n 3rd axles were ran on the road and then the 2nd transfer box was engaged by a dog clutch when the going got tough.
you could have it twin steer with a steering rear axle for offroad only though this reduce the turning circle as it would pivot around the 3rd axle instead of between the 2nd and 3rd.
to steer the rear axle you could use the gywn lewis assistor ram that runs off the PAS box with a mech lock for the highway
from the looks of the drawing is has dual servos/brake masters which is understandable... but theyre mounted near the 2nd transfer box in the diagram... which is weird?
also i doubt you will have to flip any diffs as the transfer boxes are running PTO to PTO so its reversing the rotation that way.
Good Luck and keep us posted!
Thanks. Afraid I don't have any more updates, it's still a paper idea, but one I'd really like to build. Money and other commitments mean I haven't done anything yet, also been laid up with a back injury recently which hasn't helped.
