rick Posted January 21, 2012 Share Posted January 21, 2012 For those wondering where the ROW coolers are fitted, as already mentioned the TD5 ones are just a loop of pipe up alongside the engine on the drivers (RHD) side. Wolfs have a large cooler right in front of the radiator, its supported between the A frame that supports the bonnet lock, so well above the gearbox height. There used to be some piccies on here years ago of Wolf coolers. T/cases get stupidly hot too, there was a recent thread on AULRO with some insane t/case temps recorded here in Oz, particuallry with an OD fitted. Quote Link to comment Share on other sites More sharing options...
Howitzer Posted January 21, 2012 Share Posted January 21, 2012 I fitted a larger capacity transfer case with fins on, a cast aluminium item from Roverdrive. This was after putting it into low range after a very long motorway drive with a trailer on and the transfer box lever was hot to touch. I couldn't say how effective it was as i've not done any strenuous jobs with it since fitting. Dave! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 21, 2012 Share Posted January 21, 2012 TSD. 20 deg C in ZA. When were you there winter....We found the normal ambient temperature to be betweem 35 Deg C and 45 Deg C... I haven't a temperature gauge fitted to my 380. I have an oil cooler fitted. As I've said many times, the biggest drop in the seatbox area was after fitting the X-Brake.. Dave. Yes a good idea. I keep thinking about that..How much dit it cost please.... rick. What suprises me woth the Wolf gearbox oil cooler is the size and how much it covers the radiator. I've not checked to see if the Wolf has a different radiator to the 300Tdi... Quote Link to comment Share on other sites More sharing options...
TSD Posted January 21, 2012 Share Posted January 21, 2012 TSD. 20 deg C in ZA. When were you there winter....We found the normal ambient temperature to be betweem 35 Deg C and 45 Deg C... Yes, that would be something like 20 deg hotter as I said. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 21, 2012 Share Posted January 21, 2012 For those wondering where the ROW coolers are fitted, as already mentioned the TD5 ones are just a loop of pipe up alongside the engine on the drivers (RHD) side. Wolfs have a large cooler right in front of the radiator, its supported between the A frame that supports the bonnet lock, so well above the gearbox height. There used to be some piccies on here years ago of Wolf coolers. T/cases get stupidly hot too, there was a recent thread on AULRO with some insane t/case temps recorded here in Oz, particuallry with an OD fitted. The Wolf's R380 Oil Cooler uses the same style mount as early V8 Engine Oil Coolers. Here's some parts pics - . Civvy R380 "Oil Cooler" for comparison - . Quote Link to comment Share on other sites More sharing options...
tacr2man Posted January 21, 2012 Share Posted January 21, 2012 I am using one of these as oil cooler for trans in my 90 (auto) but would work well for manual , it sits in same position as wolf unit , and they are usually quite reasonable price In OZ , TNT were having to replace diff oil every trip Perth /Darwin in road train in summer, untill they went over to Redline synthetic , high temps kill oil real quick , reason for lots of 4x4 gearbox failures ,which i ended up recovering in Australia . (I have no connection with Redline other than as customer) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 21, 2012 Share Posted January 21, 2012 Oil temp what I think what TJ said caused the gearbox failure in his 130 James. If the cooler already in the rad isn't suitable... how about one of the RRC 'bog-brush' coolers? Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 21, 2012 Share Posted January 21, 2012 Dave. Yes a good idea. I keep thinking about that..How much dit it cost please.... £60. Second item down here http://www.rockymountainspares.co.uk/?page_id=41 I have one too and it's a nicely made thing. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 21, 2012 Author Share Posted January 21, 2012 Oil temp what I think what TJ said caused the gearbox failure in his 130 James. If the cooler already in the rad isn't suitable... how about one of the RRC 'bog-brush' coolers? Indeed. The gearbox will be under more stress than normal, and combining that with the possibility of operation in hot climates means it will be getting a cooler one way or another. If the radiator cooler doesn't work out then I'll probably just fit the 2.8 Petrol cooler that I linked above. Long and thin and will fit under the rad behind the lower vented part of the front panel. Basically in front of the gap between front crossmemeber and radiator frame. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 21, 2012 Share Posted January 21, 2012 That's where my gearbox oil cooler rad is fitted. I made my front panel into an early TD5 one by cutting that bit out under the grill Quote Link to comment Share on other sites More sharing options...
rick Posted January 21, 2012 Share Posted January 21, 2012 The Wolf's R380 Oil Cooler uses the same style mount as early V8 Engine Oil Coolers. Here's some parts pics - Civvy R380 "Oil Cooler" for comparison - . Excellent, thanks for that Paul. Mike, I can't believe the size of the bleed hole in the divider plate of a stock radiator, no wonder 300Tdi's are a bit marginal in cooling capacity here in summer. I still haven't fitted my cooler yet, only had the t/stat housing and pipes for seven years...... The fix here is to run Castrol Syntrans 75W-85, and even that can thin out too much in the top end (Top of WA. NT, Qld) behind a TD5 towing. It's a tougher trans fluid than MTF94, which isn't available here anyway. I've gone to Motul Gear 300. Solves the high temp issues. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 21, 2012 Share Posted January 21, 2012 I've not seen inside a 300Tdi left tank..... I believe that a ZA mod is to add another devider plate another third up the tank. IMO the 300Tdi rad is a shambles. They should have used the same rad as the 200Tdi and taken the pipe across the bottom of the engine. That way you'd have had a proper crossflow radiator......Then a devidor plate wouldn't have been necessary.... A couple of years ago I aquired a 200Tdi rad to fit into mine. The stumbleing block at the time was pipework.... Quote Link to comment Share on other sites More sharing options...
JST Posted January 22, 2012 Share Posted January 22, 2012 i think oil to coolant works fine for what you describe. i have an oil to coolant cooler (laminova) on my autobox (tgv) and it works well with a restirctor in it. things to consider. if engine or box get too hot they heat the other. Failure of the cooler can bugger things up nicely for both. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 27, 2012 Author Share Posted January 27, 2012 I guess the other option is this type of thing mounted under the radiator, between the rad frame and front crossmember: http://www.ebay.co.uk/itm/230602885916 Quote Link to comment Share on other sites More sharing options...
rick Posted January 28, 2012 Share Posted January 28, 2012 I guess the other option is this type of thing mounted under the radiator, between the rad frame and front crossmember: http://www.ebay.co.uk/itm/230602885916 FWIW, that's wherer I planned to mount mine. Quote Link to comment Share on other sites More sharing options...
jad Posted July 17, 2013 Share Posted July 17, 2013 Old thread revival time! I was thinking of doing this for my project. Lexus V8 on R380.Has anyone done it? Does anyone know the normal operating temperature of the oil in an R380 or of the water coming out of a radiator? I know there is a few variables. Just wondering if anyone has actually measured these to work out if its viable? or has anyone done it before? Cheers Jad Quote Link to comment Share on other sites More sharing options...
tacr2man Posted July 17, 2013 Share Posted July 17, 2013 I dont see why this would be any problem , you are effectively doing the same with autobox , and that is more susceptible to o/heat damage than a manual box, the same oil was specced for 380 originally . The only question mark would be the heat capacity of the radiator , but if it handles an auto should be able to deal with a manual , as i would expect that to be cooler running . Less heat generated thru slippage etc JMHO . Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 17, 2013 Author Share Posted July 17, 2013 For what it's worth after deliberation my latest plan was to just use the long thin wolf-style oil cooler mounted below the rad to cool the R380 oil, as it also avoid any potential for fluid mixing should the radiator tank fail for any reason. Quote Link to comment Share on other sites More sharing options...
rick Posted July 19, 2013 Share Posted July 19, 2013 FWIW I logged some g/box temps a few years ago. IIRC (and the memory isn't quite what it used to be...) I think I hit 75*C or so 7km from home just cruising up the highway @ 100km/h. Can't recall the ambient, but it was only a mild day. The t/stat is rated @74*C........ I'd use a dedicated air/oil cooler. That was taken with a thermocouple attached to the pump transfer pipe on the outside rear of the R380. Quote Link to comment Share on other sites More sharing options...
jad Posted July 19, 2013 Share Posted July 19, 2013 Hi guys Thanks for the replies. Hadnt realised there were any cos I didnt get an e-mail..... The thing I wasnt quite sure about was if the coolant on the cold side of the radiator was going to be lower than the temp of the gearbox oil. Obviously its not much use as a cooler if what you are trying to cool with is hotter than what you are cooling! Anybody have an idea of what the temperature of coolant exiting the radiator is on a V8? cheers Jad Quote Link to comment Share on other sites More sharing options...
