Just another how Heavy is my 4x4 thread
MogLite
Last chance saloon for guesses
We've got Reads 90 who has guessed at 1500kg. Which is about 350kgs less than Perv's challenge spec 88" Bowler - which would be a helluva achievement - what a muppett :P
All the way to Nige's red-wine fuelled 3 tonne +
There isn't a prize BTW ;)
Well i was being very optomistic :lol:
And i know you were aiming to get it as light as poss
I am aiming for 1700 for my truck, comp ready
Okay - the scores on the doors
You can see the little logo of the car which shows front/rear & left/right if you can't read the writting on the scales
GBMUD - pretty close there chap :)
Looks like with a couple of spring packers under the front left and rear right springs, you will end up with virtually 50/50 weight distribution front to rear, and left to right.
Regards,
Diff
God you are really the king of bling. Where the hell did you get that bit of kit, you tart :lol:
NAh NAh don't tell me , where you got most of Moglite EBAY :lol:
about the same as a challenge prepared 90. Pretty good I would say. It looks like the spring rates or the platform height is not distributed evenly; it is trying to balance on left rear and right front.
It is set up like an ovalracer. What could that be?
Daan
And with me on-board
Blame the wife for not zooming the camera - and me being too lazy to crop it - but you get the idea.
FWIW - my guess was 2400kgs - so I'm made up :)
Its about the same weight as my Ibex
I'm very happy with the front/rear balance :D
Daan
Daan
The springs are cast offs - 2nd hand Procomp +2's that are well knacered. But I need to know how heavy it is before I can calculate spring rates and ride-heights.
Unless the springs are way off - I'll probably not spend any money - but go air-springs.
I've not really measured the ride heights.
The engine/trans isn't central in the chassis - its offset for clearance.
Ali - that is about £1200 worth of Longacre corner weight gauges - as used by race car boys. I borrow it off of my mate who hill-climbs an Escort Cosworth.
Daan
hey lighter than my old 90 then
Nice bit of kit though
As well as possibly tired springs, it depends on how level was the concrete on which the gauges were stood? A bit of camber or a dip in the surface can throw the corner weights right out, as could uneven tyre pressures across an axle. If the springs were say 200lb/in, then a quarter inch dip in the surface at one corner would unbalance the corner weights by ~50lb. The axle weights and hence total weight would be correct though. The race car boys take the time to ensure the pads are levelled before adjusting corner weights.
The question has to be asked - is a ~3% variation in weight at the axle ends all that critical in this application?
intresting as my 90 is very similar to your old one and only weighs 2180kg loaded up
including the tasteful wood lining inside that weigh 30kg on its own :)
Andy quite remarkable to get the weight as low as you have I expected 2500+ at least
The concrete is pretty level - it was a proffesionally laid slab.
I've got frames for the scales that allow you to level up the scales perfectly. But that is probably taking things a bit far as you say.
Overall weight and front <-> rear balance is enough info for me at this stage.
