reb78 Posted February 8, 2014 Share Posted February 8, 2014 As I'm driving my 110, I constantly have a draft on my right knee. It gets a bit annoying after a while and like an old man, I end up putting my scarf or wooly hat on my knee! Is this just door seals leaking or coming from elsewhere? The door seals seem to close on the door nicely. Quote Link to comment Share on other sites More sharing options...
L835 Posted February 8, 2014 Share Posted February 8, 2014 Tried the holes in the pedal boxes? Quote Link to comment Share on other sites More sharing options...
Blackfiesta123 Posted February 8, 2014 Share Posted February 8, 2014 Mines really drafty i didnt really know how to line the body back up when i rechassised her but iv since put a foam strip around it as a temporarily solution which is working well and also stuffing the heater box with closed cell foam has helped to get the heat on. And filling the holes in the bulkhead aswell. It gets too hot under 35-40mph but gets cooler the faster i drive cause of the drafts. It is a land rover after all. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted February 8, 2014 Share Posted February 8, 2014 Try around the handbrake lever - makes the back of your left leg cold and your right leg cold as it swirls round! Quote Link to comment Share on other sites More sharing options...
redneck Posted February 8, 2014 Share Posted February 8, 2014 I recently cured a similar problem on my 110, its got the inset door handles, I found the draft coming fom the slot where the lock latch slides up and down, and the inner door handle slot . I cut some bits of neoprene and stuck them over the slots, with a slit in them to allow them to move. Worked a treat Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 9, 2014 Share Posted February 9, 2014 I have a draught that cools my right knee that comes from the top rear corner of the drivers door glass ! Mo Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 9, 2014 Share Posted February 9, 2014 I get a cold left knee from the holes where the centre seat used to bolt through. Must get some grommets. Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2014 Share Posted February 9, 2014 I get a cold left knee from the holes where the centre seat used to bolt through. Must get some grommets. just refit the bolts, that's all I did. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted February 10, 2014 Share Posted February 10, 2014 Scarf? Hat? I thought Defender drivers were supposed to be hard. Are you aiming for a matching cold left knee (easy), or cessation of draughts to below level of outside privy in a gale(beyond optimistic)? Could also be the right vent not quite sealing and air leaking round the dashboard if the door seals (if!!), there's quite a pressure on them at warp speeds. The door seals seem to leak worst on the sloping bit of the A post, but that seems a bit high. Quote Link to comment Share on other sites More sharing options...
Steve King Posted February 10, 2014 Share Posted February 10, 2014 I have a draught that cools my right knee that comes from the top rear corner of the drivers door glass ! Mo Can't you re-arrange the spider's webs to cover this?? Quote Link to comment Share on other sites More sharing options...
cookie64 Posted February 11, 2014 Share Posted February 11, 2014 i had a similar problem for ages and couldnt figure it out, eventually i noticed that the fuel tank cover under the seat wasnt locked properly (i actually noticed this thanks to a big puddle making my legs wet from behind) anyway when i locked it again i no longer had a cold knee Quote Link to comment Share on other sites More sharing options...
