Imagedude Posted October 31, 2014 Share Posted October 31, 2014 Where can one purchase the correct tool for removing the spline head bolts that are used on Defender disk brakes? I know you can get by by using a bi-hex socket but I do like to have the correct tools whenever possible. Toodles... Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 2, 2014 Share Posted November 2, 2014 a 14mm bihead socket it the correct tool... Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted November 2, 2014 Share Posted November 2, 2014 The 14mm Bihex IS the right tool. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 4, 2014 Share Posted November 4, 2014 The 12point/bihex is the right tool! Quote Link to comment Share on other sites More sharing options...
JeffR Posted November 4, 2014 Share Posted November 4, 2014 Machine Mart do a nice socket rail: https://www.machinemart.co.uk/shop/product/details/clarke-pro224-10pc-12-multi-drive-socket-set that does the job rather nicely and cheaply Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted November 4, 2014 Share Posted November 4, 2014 The bolts are Bi Hex heads not spline drive. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted November 4, 2014 Share Posted November 4, 2014 yup, what they said. 14mm 12 point for the disks and 13mm 12 point for the caliper bolts. The bolts on the end of the axle tube which hold the wheel station/swivel housings are 13mm 12 point but you need a good quality ring spanner or offset ring spanner, not enough room to get a socket handle in. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 4, 2014 Share Posted November 4, 2014 I find they are 14mm bi-hex on the swivels... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 4, 2014 Share Posted November 4, 2014 They're 14mm on the swivels.... I have a modified spanner especially for them Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 4, 2014 Share Posted November 4, 2014 definately 14mm bihexon the swivels. i use one of these bad boys to crack off why the modified spanner? just for the extra length? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 5, 2014 Share Posted November 5, 2014 Halfords pro 14mm with the open end removed.... It's a nice fit in the disco jack handle then for undoing them. Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 5, 2014 Share Posted November 5, 2014 ahh mine are quite lengthy as they are maybe I should have put another standard spanner next to that for scale haha, although if im not at home a standard combination spanner and a few taps with the hyde hammer seem to be the best solution for me Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 5, 2014 Share Posted November 5, 2014 Rather than removing the ends of spanners I used to apply a healthy dose of lump hammer..... Quote Link to comment Share on other sites More sharing options...
