Stainless Steel Swivel Retainers - FRC4142
landroversforever
I'm content to wait as long as it takes for you to get a decent number together ?
If you were to have another batch made then I would take 2 pairs please Ross?
Anderzander and Boris113, can you both please check your front axles? It would seem that brit-car is wrong.... the swivel seal retainers on a colleagues T-reg 90 are different! They don't have the bulge at the top near the upper swivel pin.
These fit only 20L/21L/22L/23L front axles.
Sorry to be a pain!
EDIT: I think I've PMed all the others, if I haven't and they aren't right... please get in contact and we can arrange getting them back for a refund!
Ross,
The bump and bolt hole are still there I think but on TD5 types as it's a tapered bearing in the top as well, the casting is filled in at the back. Railko is open section...
Not the best of pictures but I think it shows the shape is there and bolt hole still utilised....
Will see about grabbing another piccie if no-one else can / does...
Neil
Ross,
Neil
The bump near the top swivel pin isn't there! and looking at the pictures of the parts, mine are 7 bolts, the later ones 6.
