CLANCY Posted January 3, 2007 Share Posted January 3, 2007 Hi All I have a Warn HS9500i winch on my Defender 90 300tdi.When I switch in or out on the remote control,I just get a click out of the solenoids,I have lots of power from my twin batteries Any thoughts on my problem. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 3, 2007 Share Posted January 3, 2007 Hi All I have a Warn HS9500i winch on my Defender 90 300tdi.When I switch in or out on the remote control,I just get a click out of the solenoids,I have lots of power from my twin batteries Any thoughts on my problem. I'm moving this from the Defender to the Int'l Forum as it will probably get a better response there. Quote Link to comment Share on other sites More sharing options...
white90 Posted January 3, 2007 Share Posted January 3, 2007 Solenoids have packed in or a loose connection Quote Link to comment Share on other sites More sharing options...
LR90 Posted January 3, 2007 Share Posted January 3, 2007 or bad earth? Quote Link to comment Share on other sites More sharing options...
Andy Posted January 3, 2007 Share Posted January 3, 2007 i had similar on my T-Max. took the solinoid off & shook the hell out of it then tapped it a few times with a hammer (just tapped honest) & refitted on cleaned connectors, something worked & its never played up since. Quote Link to comment Share on other sites More sharing options...
BoatBuoy Posted January 3, 2007 Share Posted January 3, 2007 Got this problem on a works 110. Mr Hobbit thought it could be the brakes playing up... well I think thats what he said anyway. Could be solinoids though. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 3, 2007 Share Posted January 3, 2007 A click with no action is in my opinion definately a dead solenoid pack. Time for the albrights....... Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2007 Share Posted January 3, 2007 Defo a dead solly pack, go for Allbrights, there's a connection diagram in the Tech Archive Quote Link to comment Share on other sites More sharing options...
streaky Posted January 4, 2007 Share Posted January 4, 2007 Defo a dead solly pack, go for Allbrights, there's a connection diagram in the Tech Archive Ralf. Bear with me on this one..... I recently purchased a 6.5HP Motor and an Albreit solenoid from those very helpful chaps @ GigglePin. The motor is now firmed bolted to the winch and all is tickatyboo. (but not yet running) Next step was to undo all of the rats nest of wires around the old solenoids. I noted then that the plug-in connection for the trigger assembly was rotten.....back on the phone to Jim/Brendon @ G.P and they dispatched a new plug-in connector along with the instructions on how to wire it up...... to solenoids. The connector also has an up-grade to connect it via 5 wires instead of the previous 3.....so I have to find homes for two extra wires now! I've been to the tech section and found the daigram you refer to...it's the same diagram that came with the Albreit connector. Where can I get an idiot proof diagram of how to wire in my new 5 wire plug to an Albreit connector and then to the 6.5HP Warn winch motor? Any offers? Thanks and regards. Streaky. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 4, 2007 Share Posted January 4, 2007 ISTR that when I went from Warn 5 wire solenoids to the albright that we just cut 2 wires off...... . Probably not what you want to hear though!! Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2007 Share Posted January 4, 2007 same here -- Warn only need 3 of the 5 wires as Bishy said ^^^^ don't remember where i read it though. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 4, 2007 Share Posted January 4, 2007 Aye only needs 3 wires. IIRC the other two are for switching the earth as well as the live. Quote Link to comment Share on other sites More sharing options...
CLANCY Posted January 6, 2007 Author Share Posted January 6, 2007 Hi to all Thanks for all you help and advice on this one, I could check it out,Armed with your info, I have contacted BRITCAR (UK) LTD who supplied my winch,All parts in stock ie Solenoids @ very good prices. www.brit-car.co.uk Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 6, 2007 Share Posted January 6, 2007 Changed my warn xp 9500 to albrite and put in cab switches for it and the 9500 MOSFET on the front I also use the earth wire a safety switch so if its not on winch cannot be used Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 6, 2007 Share Posted January 6, 2007 Have copy of how to test your winch and an albrite wiring diagram will look it out and post for you Quote Link to comment Share on other sites More sharing options...
CLANCY Posted January 6, 2007 Author Share Posted January 6, 2007 Hi that would be a great help to me many thanks Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 6, 2007 Share Posted January 6, 2007 http://forums.lr4x4.com/index.php?showtopi...mp;#entry112827 all here for you Quote Link to comment Share on other sites More sharing options...
CLANCY Posted January 6, 2007 Author Share Posted January 6, 2007 Thanks for the Tech Information,It reads very well.I will check out my motor first,Then I will make a decision on the Solenoids.I may be back if all fails me, to pick your brains. (Ps its nice of people to take time out and give advice) Quote Link to comment Share on other sites More sharing options...
CLANCY Posted January 7, 2007 Author Share Posted January 7, 2007 Hi Some follow up on my winch problem,Spent today on it, carried out the motor test Thanks Br00n1e for paperwork,as it turned out it was the Motor, the windings full of wet and corrosion a total clean up and all is now working fine Thanks Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 7, 2007 Share Posted January 7, 2007 good stuff, did you strip off the other end and clean and regrease it? Quote Link to comment Share on other sites More sharing options...
CLANCY Posted January 7, 2007 Author Share Posted January 7, 2007 NO but now you mentioned it, I will sort out that end tomorrow before it goes back on.I am glad you thought of that Cheers Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted January 7, 2007 Share Posted January 7, 2007 you're welcome Quote Link to comment Share on other sites More sharing options...
