Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 I believe so. The high pressure pump powers the injector, and returns excess fuel from and to a mini tank. The low pressure pump fills the mini tank. It's quite neat. Fitting a high pressure pump to the two main tanks became difficult, fast. And having high pressure petrol in a switch over valve was a bit frightening. I like this plan. I worry about the diaphragm in the lift pump, but I'm sure there's a replacement part somewhere, that will cope, perhaps in California. Somewhere that's been down this road before us. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 I broke the original lift pump. Snapped off the filter part of the casing. This was ages ago, during one of my house moves. I bought a new one from Britpart, but the cam lever that operates the diaphragm is awful, three steps of steel spot welded together running on my new cam shaft. No. Not happening. I'll build one good one out of two, I think. Hopefully Britpart just copied the original part, and it is all compatible. A dining room table job. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 A nice one to photograph and share .... 😊 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 Oh. Well, I suppose I could. It's on the list. The alternator should be next, though. Pulley alignment and VR CPS sensor bracketry is the thing I want to do first, before the engine goes in the chassis. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 RN11YC, champion. Is what Roland recommended. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 Go for it !! I think it’s mainly NGK that have the carp copies - so a safer option too 😊👍🏻 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 Genuine Landrover only£6 each. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 https://www.ebay.co.uk/itm/272796134972 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2020 Share Posted July 10, 2020 Always found NGK a better bet, but guess Roland knows his stuff too Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 10, 2020 Author Share Posted July 10, 2020 43 minutes ago, Anderzander said: https://www.ebay.co.uk/itm/272796134972 What does the 4 at the end signify? Is it just x4? When I order plugs it's usually "one of those" and I show the old one to the husqvarna guy. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2020 Share Posted July 10, 2020 You can find everything here: https://www.sparkplugs.co.uk/spark-plug-symbol-codes/ 'wide gap required'.... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 That’s a good question .... I don’t know what it means. The codes are broken down here. https://www.sparkplugs.co.uk/spark-plug-symbol-codes/ I’ve read it and still done understand it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2020 Share Posted July 10, 2020 You and I seem to be trading URLs tonight, @Anderzander.... 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 Oh bloody hell 😂 I’ll back off - or we can take it in turns ? 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 I think the number at the end is just what the gap comes set at .... which is a bit weird. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 Now Bowie may well be posting this as I type ... https://www.championpowersports.eu/assets/II-Partnumbering-structure.pdf but the 4 is just what the gap comes pre-set as. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2020 Share Posted July 10, 2020 Hardly..... I wouldn't want to encourage your stalking me. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 10, 2020 Share Posted July 10, 2020 If you look outside - I’m waving 👋🏻 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2020 Share Posted July 10, 2020 That'd be amazing, I'm away in a caravan.... Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 11, 2020 Author Share Posted July 11, 2020 9 hours ago, Anderzander said: Now Bowie may well be posting this as I type ... https://www.championpowersports.eu/assets/II-Partnumbering-structure.pdf but the 4 is just what the gap comes pre-set as. That will do. Thanks! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 11, 2020 Author Share Posted July 11, 2020 Alternator fitting. I was surprised that this was metric. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 11, 2020 Share Posted July 11, 2020 Getting closer now ! 😊 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 11, 2020 Author Share Posted July 11, 2020 I'm not so sure. In the obvious position the alternator doesn't align. Bad times. In the extreme opposite position, it's doesn't align either. The pulley is too close to the body of the alternator. A couple of washers makes it good, but then the pulley nut isn't entirely over thread. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 11, 2020 Author Share Posted July 11, 2020 Does anyone have a series alternator pulley to hand? What diameter is the shaft? What is the distance between the inboard end and the middle of the vee? Oh! And what diameter is the pulley?!! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 11, 2020 Author Share Posted July 11, 2020 I do have enough to start feeding my thoughts as to brackets and position for the CPS. I like this one: I'd have to fit an adjuster on the bracket so I can move the sensor up and down, but this is neat, keeps the wires away from spinning stuff and is clear from the rest of the timing marks. This is an option, all inside the belt arc: Very tight to the timing mark, very little space for the bracket, but very protected. Is there a risk of a stray signal from the fan? Or the alternator? Don't like this, but do-able: vulnerable wire: This might have worked, but the sensor is the wrong way around: Quote Link to comment Share on other sites More sharing options...
