cackshifter Posted April 22, 2020 Share Posted April 22, 2020 Quick question to anyone who has one on a 300tdi or any 'traditional' LR diesel for that matter I suppose; have you got the 4000rpm or 6000rpm full scale (and is it OK)? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 22, 2020 Share Posted April 22, 2020 I use a 4000. They run out of poop well before 4000. Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2020 Share Posted April 22, 2020 mine is a 0 -5000rpm VDO unit as fitted to the V8 50th annivesary models, LR part number is or was AMR5724 works from a signal off the alternator 'W' terminal. updated 9 digit part number but exactly same as my unit. VDO part number in photo's in this Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 22, 2020 Share Posted April 22, 2020 The problem with the TD5 one is that it is not adjustable. You need to have the exact correct alternator and pulley size for it to be accurate. The aftermarket ones can be precisely adjusted to match any setup. Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2020 Share Posted April 22, 2020 Well that one of mine is adjustable it has 3 dip switches & a adjuster in body side Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 22, 2020 Share Posted April 22, 2020 4 minutes ago, western said: Well that one of mine is adjustable it has 3 dip switches & a adjuster in body side Cool. I did not know that. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 22, 2020 Author Share Posted April 22, 2020 Thanks for the insights folks. FYI the AMR5724 is about £450, the YAE100800 about £290, both genuine parts. The picture of the AMR5724 on lrdirect shows a 6k rpm dial - maybe not the correct picture. So I might just buy a VDO one. Quote Link to comment Share on other sites More sharing options...
TSD Posted April 22, 2020 Share Posted April 22, 2020 I have a couple of the aftermarket VDO 6k units, works just fine on a 300tdi. I needed to do some adjustment with the TGV engine because the alternator has an unusual number of poles, but with standard tdi alternator it was nearly spot on straight out of the box. (Second unit was already fitted on the 200tdi when I got it). Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2020 Share Posted April 22, 2020 24 minutes ago, cackshifter said: Thanks for the insights folks. FYI the AMR5724 is about £450, the YAE100800 about £290, both genuine parts. The picture of the AMR5724 on lrdirect shows a 6k rpm dial - maybe not the correct picture. So I might just buy a VDO one. I certainly didn't pay that much for mine, just over £58 back in July '99 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 23, 2020 Share Posted April 23, 2020 I’ve got a 6000 VDO one brought it from a place in Shropshire, can’t remember the name begins with C sell billet aluminium stuff. It was listed as for the 200/300tdi . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 23, 2020 Share Posted April 23, 2020 Croytec was the place . Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 23, 2020 Author Share Posted April 23, 2020 15 hours ago, western said: I certainly didn't pay that much for mine, just over £58 back in July '99 I just need to borrow a time machine then from someone. You can have it back straightaway. 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 23, 2020 Share Posted April 23, 2020 Croytec is showing £157 but price list is from 2017 , but might be worth a call to them Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2020 Share Posted April 23, 2020 this on ebay [UK only] 0 - 6000 rpm. £110 -- https://www.ebay.co.uk/itm/VDO-Cockpit-Vision-Tachometer-Rev-Counter-52mm-6000-RPM-Not-lesser-4000RPM/293554711678?hash=item4459396c7e:g:72kAAOSw3fFeQb0~ Merlin Motorsport £129 -- https://www.merlinmotorsport.co.uk/p/vdo-tacho-52mm-diameter-0-6000rpm-333015010 there is another on ebay at £85 but it's in Latvia so postage on top. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted April 23, 2020 Share Posted April 23, 2020 How easy are they W driven ones to set up ? Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2020 Share Posted April 23, 2020 if it's a VDO unit very easy, set the 3 dip switches on rear set the max range then at idle adjust the small screw to set the idle rpm. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted April 23, 2020 Share Posted April 23, 2020 Many thanks Western , from reading the previous posts It seems the VDO gauges are very popular , ive seen the Merlin motorsport website and it would seem to be an average price . Thanks once again. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 23, 2020 Author Share Posted April 23, 2020 Or Demontweeks, £120.90 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 24, 2020 Share Posted April 24, 2020 Seriously get the 4000 rpm one. Nobody would purposely run a TDI over 4000. https://www.ebay.co.uk/p/1323808637 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 24, 2020 Share Posted April 24, 2020 I have the one Red90 has linked too, I've never hit 4000 rpm (nor would I want to ! ). I've found it very good, clear, easy to read and reliable. Mo Quote Link to comment Share on other sites More sharing options...
simonpelly Posted April 24, 2020 Share Posted April 24, 2020 On 4/22/2020 at 7:05 PM, cackshifter said: Quick question to anyone who has one on a 300tdi or any 'traditional' LR diesel for that matter I suppose; have you got the 4000rpm or 6000rpm full scale (and is it OK)? Here’s a link to when fitted to my 1997 300 Tdi - scroll half way downish... https://pellylandroverdefender.blogspot.com/p/autumn-2017.html?m=1 Simon... Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted April 24, 2020 Share Posted April 24, 2020 Appreciate what Mo & Red are saying , im assuming the 4000 units are as easy to set up as the 6000 ones ? Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2020 Share Posted April 24, 2020 Doubt there is any difference in setting it up, just 3 dip switches & the trimmer screw. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 25, 2020 Share Posted April 25, 2020 Hog, if I can set it up, you can ! Buy one of those infra red tachometers from ebay, cheap as chips, you can then get an accurate tick over speed to set the rev counter to. Mo Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 25, 2020 Share Posted April 25, 2020 Just be careful if you do buy one from outside the EU. If the Post Office decide that tax is to be paid, they will hold it at the sorting office, leaving you a card directing you to a bill for the tax and that will include their own fee too. So expect to pay VAT on the whole cost (item plus P&P). Quote Link to comment Share on other sites More sharing options...
