Green200tdi Posted July 3, 2023 Share Posted July 3, 2023 Might be a strange question but refitting old wings to newly painted bulkhead would you use a silicone or just fit them as normal? Think I may rub them down fresh paint on this part, sorry just getting ideas not sure what others have done. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 4, 2023 Share Posted July 4, 2023 Just fit them dry. There’s no reason to use silicone - and many reasons not to! Some fresh paint is a good idea though. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 4, 2023 Share Posted July 4, 2023 Never use silicone! * Mike *Except round a bath or perhaps as instant gasket to get you home. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted July 4, 2023 Share Posted July 4, 2023 If you use silicone it will glue them together, making it impossible to separate later, unless you use a blade. That would be very difficult to do. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted July 4, 2023 Share Posted July 4, 2023 1 Never use silicone - Satan's juice👿 2 If you rub down and repaint the wing ends you will need an etch primer to get it to key to aluminium. Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 4, 2023 Share Posted July 4, 2023 I’d clean up the corrosion, apply a safe acid to kill it (I have had satisfactory results with the steel rust killers), etch and repaint. Do the same to the A pillar to encapsulate both metals. Plastic washers behind the bolt heads will help a lot at preventing reoccurrence, as would a dollop of grease between the faces and around the bolt holes and on the bolts themselves. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted July 4, 2023 Author Share Posted July 4, 2023 Thank you 😊 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 4, 2023 Share Posted July 4, 2023 Silicone produces acid when hardening. You don't want to have that. If you want to seal use PU sealants. There are advantages, when no water can run down to the outside of the footwell on the bulkhead, when the wing is not glued to the bulkhead, but sealed on top and on the sides. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 4, 2023 Share Posted July 4, 2023 If you seal it and you’ve ever got to get it off then you’ll kill the panel. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 4, 2023 Share Posted July 4, 2023 A layer of grease and put it together, then wipe off any that comes out of the joint. Steve Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 6, 2023 Share Posted July 6, 2023 Sealing is not gluing. Sealing is only done with a strip of PU on the outside of the seam between bulkhead and wing. Thats enough Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 6, 2023 Share Posted July 6, 2023 3 hours ago, Sigi_H said: Sealing is not gluing. Sealing is only done with a strip of PU on the outside of the seam between bulkhead and wing. Thats enough That's still going to make removal difficult, but also I really don't see any point in sealing here anyway. Quote Link to comment Share on other sites More sharing options...
