GBMUD Posted January 30, 2007 Share Posted January 30, 2007 I am getting tired of the interior volume level in my Landrover so the time has come to do something about it. I am aware that one can buy expensive lead blankets for things like the engine and gearbox and all manner of interesting and expensive covers for the tunnel, floors and seatbox. I want to avoid spending lots of money and I happen to have some carpet available after laying laminate on the hall floor. The carpet is hessian backed and I would like to make it stick to the inside of the hardtop roof and sides as well as to the sides of the tub and the tops of the wheel boxes. In a lot of these applications gravity is going to be working against me so I will need to persuade the carpet to adhere to the painted aluminiumm in some way. Who can suggest a sticking medium that will do the job well but ideally not leave any mess on the inside of the roof if it should fail or if I change my mind about the colour of the carpet? I am planning on some sort of rubber mat for the floor in the tub, any suggestions for something sound deadening yet waterproof and hard wearing? I also need a solution for the seat box and floors (the tunnel seems to have a decent mat already installed) and I was thinking about neoprene matting such as that used by campers to sleep on - topped with a rubber mat on the floors. This would also lend itself to the rear load area floor. Any suggestions? Chris Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 30, 2007 Share Posted January 30, 2007 Who can suggest a sticking medium that will do the job well but ideally not leave any mess on the inside of the roof if it should fail or if I change my mind about the colour of the carpet? Nothing like wanting your cake and eating it is there!! I used an aerosol of contact adhesive for the fuel tank - the can's in the garage at the moment. It certainly sticks, but gives no flexibility for positioning the carpet so you have to get ti right first time - which can be tricky. It does leave a mess, but it is soluble in celulose thinners, so as long as you don't rub too hard you can get the glue off without disolving too much paint... I'll dig the can out in a mo..... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 30, 2007 Share Posted January 30, 2007 I'm planning to use camping mats in the back of my 90. I'm going to glue the foam to 6mm ply and fix that, rather than spread glue about. Just got to work out how to do the curve of the roof. A foam/ply/carpet sandwich might work for you, and prevent getting glue everywhere? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 30, 2007 Author Share Posted January 30, 2007 A foam/ply/carpet sandwich might work for you, and prevent getting glue everywhere? Mmmm, sandwich.. Chris Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 30, 2007 Share Posted January 30, 2007 a lot of people have used camping mats for roof and sides. Lightweight so easy to stick and no problem with getting wet/damp. I bought an LR rubber mat for floor, seat box sides and top for around 60 pounds IIRC. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 30, 2007 Share Posted January 30, 2007 I would use camping mat for the roof and maybe sides, you can pick cheap ones up for a few quid. Bish what did you use to cover the tank in the end? Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 30, 2007 Share Posted January 30, 2007 Bish what did you use to cover the tank in the end? Colour matched connolly leather of course ;) Steve Quote Link to comment Share on other sites More sharing options...
nas90 Posted January 30, 2007 Share Posted January 30, 2007 You going soft now that you have moved from Horsham, hmmmmmmm, Mr Watts. What happened to the rough, tuff Land Rover image? Quote Link to comment Share on other sites More sharing options...
JST Posted January 30, 2007 Share Posted January 30, 2007 i cant believe you have posted this thread Chris, it seems so unlike you. Having had a wagon with carpet on the inside of the roof i would recommend not bothering, it gets damp from condensation and eventually falls off in my experience. camping mat the roof and lay carpet onto boarding for the sides with camping mat on the inside of the boarding, use self tappers to hold it all on. Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 30, 2007 Share Posted January 30, 2007 Why not go for some nice terracota quarry tiles , nice and easy to keep clean . Coats on , Gone !! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted January 30, 2007 Share Posted January 30, 2007 I went for a spray can of 'adhesive', I've no idea what's in it but it makes you high and sticks stuff like sh*t to a blanket. I did my hardtop and roof with camping mats, although I didn't see a marked difference but I think most of the noise is coming from the cast-iron clanker up front (as it does its job saving me money...) Quote Link to comment Share on other sites More sharing options...
freeagent Posted January 30, 2007 Share Posted January 30, 2007 don't bother with carpet on the roof, use camping mats.... as the others have said, stick the carpet to boards and use them on the side panels... held up with self tappers... as for glue, screwfix contact adhesive is as good as any...... Quote Link to comment Share on other sites More sharing options...
Dark green 90 Posted January 30, 2007 Share Posted January 30, 2007 Ive got the mat/board/carpet effect, works well, keeps some heat in too glued and screwed..... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 31, 2007 Share Posted January 31, 2007 Spray contact adhesive is very good. Make sure you get it right though - you don't get a second chance. There's not much that will remove the glue that won't cause other damage at the same time. Les. Quote Link to comment Share on other sites More sharing options...
reads90 Posted January 31, 2007 Share Posted January 31, 2007 OK for carpet o the floor and places its going to get wet, then don't use hessin backed carpet as when it gets wet it will mouled and then stink. And hessin rots when it gets wet. Rubber backed carpets use to be the best but they are now baned (well have been for about 4 years now) Felt back would be a little better than the hessin As for glueing . Balls F3 (or elephant come , as it is called in the trade, when you see a 25ltr tibe of it you will see why ) is the best stuff but had one problem , will never come off. Or Balls F44. That is more of a arcric adhesive that is water proof , but still you will not get it off. So that leves you with Balls F54 which is a tackifer. Which means you put it on both surfaces let it dry and then put them to gether, but you can take this up and put it back down again and again.. But B&Q carpet spay adhesive will do the job but for best result spay both surfaces and wait for them to dry (about 5 mins) and then contact them together. This will really make it stick like **** to a blanket Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 31, 2007 Share Posted January 31, 2007 I would use camping mat for the roof and maybe sides, you can pick cheap ones up for a few quid.Bish what did you use to cover the tank in the end? I used jumbo cord carpet and rubbed the foam backing off before sticking it on with Loctite spray Adhesive. Quote Link to comment Share on other sites More sharing options...
reads90 Posted January 31, 2007 Share Posted January 31, 2007 I used jumbo cord carpet and rubbed the foam backing off before sticking it on with Loctite spray Adhesive. Best stuff for it. Also the cheapest even more cheap if you find it in a skip at the back of an exibition center. They put it down for 3 days and then rip it up and bin it Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 31, 2007 Share Posted January 31, 2007 I used jumbo cord carpet and rubbed the foam backing off before sticking it on with Loctite spray Adhesive. Nice idea. Has it helped quieten down the noise of that chip fat sloshing about? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 31, 2007 Share Posted January 31, 2007 Nice idea. Has it helped quieten down the noise of that chip fat sloshing about? Dunno - the fuel sender is now rattling off the side of the tank!! Will have to come up with a cunning plan for that one. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted January 31, 2007 Share Posted January 31, 2007 tricky one - always going to be a laugh with dissimilars, I would have suggested ESAB Wilton brazing rods unless you wire brush back to clean underlay and then root with a lino based wire running axminster/foam backed gas... worth a go? Quote Link to comment Share on other sites More sharing options...
Bigwood Posted January 31, 2007 Share Posted January 31, 2007 tricky one - always going to be a laugh with dissimilars, I would have suggested ESAB Wilton brazing rods unless you wire brush back to clean underlay and then root with a lino based wire running axminster/foam backed gas... worth a go? The floor covering in my 90 is carpet tiles from *&Q . You can buy them indiviualy in lots of colours, They have a sort of ruber backing. When my 90 got temporarly drowned I simply lifted them out and took them indoors to dry. Quote Link to comment Share on other sites More sharing options...
Dark green 90 Posted February 1, 2007 Share Posted February 1, 2007 Not great pics,looks better than they suggest ply and carpet ,angle iron and screws. Quote Link to comment Share on other sites More sharing options...
