iron_city Posted November 4, 2023 Share Posted November 4, 2023 Thank you all again for the help id'ing this engine as a 300TDI. It was suggested to me that it might make sense to remove the fan on the engine (circled in red), as the truck has an electric fan installed. It doesn't seem like the fan on the engine really does anything - except perhaps be poised to cut through a coolant line that the prior owner secured away from the fan with a zip-tie... I wanted to get the groups' opinion if removing the fan on the engine would make sense. Thank you! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 4, 2023 Share Posted November 4, 2023 Yup, not doing anything at all there without a cowl. 1 Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 In case you aren't familiar with it, it's on LH thread. Quote Link to comment Share on other sites More sharing options...
iron_city Posted November 5, 2023 Author Share Posted November 5, 2023 thank you @fmmv, I did not know it was reverse thread 🙏 Quote Link to comment Share on other sites More sharing options...
iron_city Posted November 5, 2023 Author Share Posted November 5, 2023 any advice on how to actually get the fan off would be very much appreciated, as all I'm seeing is what looks like a coiled spring and a retainer on the front Quote Link to comment Share on other sites More sharing options...
Mossberg Posted November 5, 2023 Share Posted November 5, 2023 The "nut" is on the back of the fan. There is a special spanner for it as it's quite awkward to get to, but I think I managed mine with a slim spanner (but it's been a while so not 100%). It's worth Googling 300tdi fan spanner to see its thickness and shape. I think you need to give the spanner a knock to release it, but make sure you are undoing it in the right direction. I haven't got a great deal of experience with this but hopefully someone will be along soon with more help. I find it odd that it's still fitted due to electric fan being there. I would keep it to one side just incase the electric fan gives up, but you will need a cowl for it to be efficient. Good luck with the task. Quote Link to comment Share on other sites More sharing options...
Mossberg Posted November 5, 2023 Share Posted November 5, 2023 https://www.ebay.co.uk/itm/253786117787 Viscous coupling showing the nut (without the fan fitted). Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 5, 2023 Share Posted November 5, 2023 (edited) Remove it. My 200 Tdi was a lot quieter and used less (only 0.2l) Diesel. The Visco was stuck. But dont´t forget to put an electric fan on the Intercooler as well ! This is often forgotten and was on your setup too, as it seems. If you place a big blowing fan in front of the intercooler it covers a third of the rad as well and can run permanentely. Edited November 5, 2023 by Sigi_H Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 (edited) You could probably make a spanner if you have some 3mm plate, it just needs 2 tightish fitting jaws and a handle long enough to hit with a hammer. They normally unscrew easily after a good smite. Edited November 5, 2023 by fmmv Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 5, 2023 Share Posted November 5, 2023 2 minutes ago, fmmv said: You could probably make a spanner if you have some 3mm plate, it just needs 2 tightish fitting jaws and a handle long enough to hit with a hammer. They normally unscrew easily after a good smite. Thats why I removed it permanentely 😄 Quote Link to comment Share on other sites More sharing options...
Disco1tdi Posted November 5, 2023 Share Posted November 5, 2023 Or... if you can find a cheap one or are not precious about an exisiting 32mm spanner, just grind it thinner. It's not pretty, but is effective. (Double check the nut dimension first). Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 (edited) I have dim memory of someone posting that you could use a shorter belt, and bypass the fan pulley thus removing the bearing wear on the timing cover, but I can't find it just now. Edited November 5, 2023 by fmmv 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 5, 2023 Share Posted November 5, 2023 32mm viscous coupling spanner https://www.ebay.co.uk/itm/133015959046?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ZQiA6gHnTIK&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 5, 2023 Share Posted November 5, 2023 29 minutes ago, fmmv said: I have dim memory of someone posting that you could use a shorter belt, and bypass the fan pulley thus removing the bearing wear on yhe timing cover, but I can't find it just now. On the 200 the fan runs off the water pump, so it needed to stay, is it different on these? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 5, 2023 Share Posted November 5, 2023 google says yes ! Is that why people say their heads are prone to being cooked? With the water pump so high I’d guess you wouldn’t need the level to drop much for it to be a problem? looks like the belt would run very close to the PAS pump if you didn’t use the fan and tensioner though. 2 Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 Its worth looking at because the timing cover bearing is difficult to source and difficult to replace, or you have to replace the whole cover. Yes 300 tdi are very vulnerable to low coolant, probably its biggest Achilles heel. 1 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 5, 2023 Share Posted November 5, 2023 (edited) For those who are interested in my belt conversion on a 200 Tdi https://www-explorermagazin-de.translate.goog/bauberi/keilum21.htm?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp Edited November 5, 2023 by Sigi_H Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 For the record, the fan bearing on the timing cover is I think is Koyo 885802 RS ( I have made a note of it from somewhere else) and can be replaced by a John Deere waterpump bearing part number JD9257 superseded by JD9448 ( both of which needs a bit of the shaft cut off). I also have a note of SKF 374056B against this bearing. 2 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 5, 2023 Share Posted November 5, 2023 My preference if you can get the bits would be to refit the shroud and get the original fan running and remove the electric fan. Failing that, if the electric fan works ok, then remove the original one. Two is overkill, but the engine driven fan does nothing without the shroud. 4 Quote Link to comment Share on other sites More sharing options...
steve b Posted November 5, 2023 Share Posted November 5, 2023 The engine is in the 200 Tdi position so a 200 Defender or 2.5na shroud would be the only original options and I'm not sure the fan is at the same point. A low coolant warning light/buzzer is worthwhile with 300 Tdi's.... Steve Quote Link to comment Share on other sites More sharing options...
iron_city Posted November 5, 2023 Author Share Posted November 5, 2023 The fan is now removed. Luckily I had a slim 32mm wrench still lying around that I had used to tighten a bicycle head set about 35 years ago... (posting a pic of the wrench in case in helps out someone else). Thank you all again for your help! 3 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted November 5, 2023 Share Posted November 5, 2023 3 hours ago, steve b said: The engine is in the 200 Tdi position It's much further back than my ex-Disco 300TDi. What has determined that? The bellhousing maybe - will the gearbox have also moved across to this vehicle? I tend not to look at those sorts of topics but now I'm interested! Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 5, 2023 Share Posted November 5, 2023 That was the perfect spanner(wrench), and, well done, you have displayed the ingenuity and resourcefulness needed to keep your Defender on the road(highway). Quote Link to comment Share on other sites More sharing options...
iron_city Posted November 5, 2023 Author Share Posted November 5, 2023 thank you @fmmv! @Peaklander I agree, the engine does seem to sit way back in the bay. The gearshifter does appear to be in the original position and I took a photo of the underside of the truck in case that helps as well Quote Link to comment Share on other sites More sharing options...
steve b Posted November 5, 2023 Share Posted November 5, 2023 The brass expansion tank suggests it was originally a 2.5 N/A or turbo or an early 200 Tdi. Hence the short bellhousing and engine back against the BH. Is reverse up and left? Steve 1 Quote Link to comment Share on other sites More sharing options...
