Swivel Pin Play
Gromit
I've some play at the top of the swivel housing, such that the housing can move in and out about 0.5-1mm at the top of the swivel ball.
Can this play be removed by removing shims from under the top swivel pin?
thanks,
Oh Dear, I'm going to be in trouble again!!
The shims affect the vertical spacing of the swivel pin, which bears down on a small paxolin type pad within the upper bearing. As this pad wears, so the friction built into the assembly decreases, and the effort required to turn the swivel pin decreases to below the specified limit. The damping effect of the friction becomes so small that any wheel shimmy is not damped out. To correct the effects of this wear you remove shims, which increases the clamping pressure of the pin on the pad.
However, you clearly state "the housing can move in and out about 0.5-1mm at the top of the swivel ball".
Now I take that 'in and out' to be sideways movement, not vertical movement.
If it is sideways movement then the cylinder (bearing) surrounding the pin, and possibly the pin itself, is worn. Removing shims won't cure that.
In my limited experience, overhaul kits include new cylinders and new pads, but I don't recall if the pin is included or a separate purchase.
Note that the upper bearing is a press fit in the swivel.
Perhaps not the answer you wanted.
Cheers.
JC. Guessing game is it, I thought this was a technical forum, where fact is king!
I suppose Guessing ties in with Range Rover articles buried in the International Forum, instead of the Range Rover forum, and the same Air Suspension article filed in the Tech Archive under Misc rather than Suspension.
In future I'll know not to bother attempting to contribute, I'm obviously too far out of step.
Cheers.
Hey, I’m with David on this one………….. ;)
It is usually fraught with more detail than just removing some shims…………….. often the shims of a different thickness are required to get the preload anything near right.
To be honest I have not had great success in just re shimming, especially with the taper bearing swivel housing …………….. often the (as David rightly says) the pin wears and no amount of shimming will cure the problem. To compound the issue further, both the lower and upper pins sometimes has a little wear on each ………….
Also unless you keep upward pressure on the swivel housing all the oil / grease comes raining out as the top bearing is released and the swivel ball moves within its seal …….. often that seal tends never to work again…………..
I would have thought that 1mm was excessive to the point of a complete swivel bearing rebuild…………. No expensive and probably quicker in the long run
My experience suggests that if it is a railco then you may get away with shimming if the pin is perfect (which I doubt) …………. If its twin taper bearings then bearing / pin replacement is often the only way forward.
Ian
Thanks for everyone's input. Does anyone know what year they changed from a railko to twin taper?
My parts catalog for 1987 onwards, doesn't indicate if it is railko or not.
Given the age of the truck, I'd suspect there is a bit of wear everywhere. I've no problem overhauling the swivel, just need to get the bits before I start.
The thread isn't buried anywhere - it's copied into the tech archive. As I already explained to you once David - I put tech threads in the int forum so that the maximum number of people will perhaps notice it and at least remember that there is a thread covering their problem in the future.
Well perhaps White90 either put it there for a reason or made a genuine mistake - a pm to him would be productive I think.
Tech threads are in the archive covering both railko and twin taper roller bearings - Gromit has used the tech archive on previous occasions, so I'm sure if he needs detailed information on the work involved he can use the relevant thread.
Les.
Can I squabble too? :P
My 2004 110 suffers from some (considerable) wheel wobble/oscilation between 40mph and 60mph. I plan to change the steering damper but I am assuming that there must be some play in the swivel bearings too. So, what type of bearings are fitted to mine? I assume that it is the later type with the radial bearing below the top pin, so does one adjust this with shims too? Is it a Railko bush otherwise? I presume that with a radial bearing there cannot be a tapered roller bearing in the top.
Chris
Chris if you haven't got any free play, rock wheel like checking for wheel bearing play but just top to bottom not side to side, then it may just be that there isn't enough 'resistance' to turning. In this case removing a shim or two should allow you to set the correct 'resitance' (14lb on the TRE hole rings a bell, but I just do it by feel). This will work to alter the resistance with both railko bush or taper bearings. Your 110 should be taper bearings.
You can tell if it's taper bearing or railko bush at the top by the size of the 'pin head', the railko bush one is bigger, I think that's the right way round :unsure:
Oh and with axle stand under axle, put a jack under the hub to take the weight so when you remove the top pin the hub won't drop down spilling all the oil (may not be an issue if you have grease filled swivels) and possibly damaging the seal. Also the top pin comes out a bit easier if the weight of the hub is taken on a jack.
Thanks Mark, good advice. :)
Just been looking in the downloadable manuals but they all seem to refer to different (300Tdi) models and the 2002 supplement does not mention swivels. Was it only the ABS axles that had the radial bearing in the top swivel? I guess I will find out when I take mine apart.
Chris
Sounds a bit like my Panhard rod woes Chris..... I know you will have eliminated that choice but gave me the opportunity to mention my 100% record of vehicle problems when out driving with you ! :)
(I'll be bringing spare panhard to Lakes because I know I'm going to blow it ! )
:hysterical:
Neil
OK, given mine's a 91 200tdi, I guess it's a Railko. I'll pull the top swivel pin to be sure before I get new shiny bits for it;
Then that'll be the argument settled......................... or will it :P :P
Always amuses me to see a dolly go for a flight on the various forums.
The posters on these forums are doing it out of the kindness of their hearts and are not getting paid to do it. Ok so sometimes they get it wrong, but usually the info - esp les's with the photos - is top quality.
And some of those asking questions on the forums have no idea what they've got on their cars or don't put any info in about the car itself.
You COULD of course always go and BUY a factory workshop manual for your vehicle...............
Maybe I should keep that, or maybe get it printed on a t-shirt :lol:
Now this may not be gospel, it's just my limited experince/findings.
Early 90/110 had railko bush. 300tdi on have taper bearings, other axle changes here too, wider radius arms, 24 spline diffs. I think the swivel pin change came in with the 200/300tdi change over.
RRC had taper bearings from much earlier, mid 80's axles had then I think, certainly lates 80's, not sure about earlier RRC axles, maybe they all did, I don't know. Also RRC had wider radius arms much earlier than 90/110.
Disco, I think they tended to use axles more aligned with the RRC than the 90/110 of the same vintage.
