max-ie Posted August 2, 2008 Author Share Posted August 2, 2008 Thanks for all the excellent replies, i'm getting closer to this phase of my build now, got the EFI working, sounds amazing, Bish this is coming on a treat, can't wait to see it completed. Tim, how is the LSE console made to fit near the fuse box, i see a white or silver bit by the end of the console, what is it ? Cheers Max Quote Link to comment Share on other sites More sharing options...
TJ101 Posted August 2, 2008 Share Posted August 2, 2008 Tim, how is the LSE console made to fit near the fuse box, i see a white or silver bit by the end of the console, what is it ?Cheers Max Max The silver box is made from alloy sheet, will see if i have a better pic on file ?? Quote Link to comment Share on other sites More sharing options...
pat_pending Posted August 2, 2008 Share Posted August 2, 2008 That's probably the tidiest home made auto console I've seen, superb job !Mo Thanks, maybe i could knock a few up and flog them to Ashcrofts. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted August 2, 2008 Share Posted August 2, 2008 Tim, how is the LSE console made to fit near the fuse box, Maybe a bit clearer !! Quote Link to comment Share on other sites More sharing options...
paul stage1v8 Posted August 4, 2008 Share Posted August 4, 2008 a work in progress, will be covered in vinyl, two cupholders to be fitted beside shifter Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 5, 2008 Share Posted August 5, 2008 Right, some progress this week.One coat of primer and two of gloss to try and seal the wood for a while. At one coat per night that took most of the week! Apologies for the leary red paint - it was to hand and needed using up! Besides, once it is finished no one is going to see it! Dragged out a roll of el cheapo carpet last used to trim the fuel tank in the bobtail (it's not stained, just shaddows): Paint and carpet in a 90... I knew you couldn't get away from your posh Range Rover roots Nice work BTW Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 10, 2008 Share Posted August 10, 2008 Well, I have now fitted the bits into the 90: First the base plate, shifter and hand brake: Really pleased with how solid it is - the handbrake doesn't flex it at all. Not sure what to do with the handbrake gaiter. I may build it into the cubby box.. Then the carpeted bit with the shifter housing: Then the gear indicator wotsit - don't worry about the garish red, the bling stainless is on the way.. I'll have to take it apart again to add some extra holes for wiring, but other than that, it's done. Just got to build a cubby box now.... Quote Link to comment Share on other sites More sharing options...
max-ie Posted August 10, 2008 Author Share Posted August 10, 2008 Its looking good Bishbosh, Im a bit behind with things at the moment. I couldn't get my motor started and it took ages to find the faulty relay. I like the no clutter look of your design, can't wait to see it all finished. Thanks for all the help. Max Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted August 11, 2008 Share Posted August 11, 2008 a work in progress, will be covered in vinyl, two cupholders to be fitted beside shifter thats a beauty! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 8, 2008 Share Posted October 8, 2008 Dragging this one back up to show you the finished article, well, finished until I make a cubby box: I know the cover on the transmisison tunnel is a bit wonky, but I have the MOT tomorrow and I'l sort it out later! Quote Link to comment Share on other sites More sharing options...
JST Posted October 8, 2008 Share Posted October 8, 2008 Looks good Bish, good luck tomorrow Quote Link to comment Share on other sites More sharing options...
Les Brock Posted October 8, 2008 Share Posted October 8, 2008 Same here Bish, Hope it goes OK ! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 9, 2008 Share Posted October 9, 2008 Looking good Bish, good luck ! Mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 9, 2008 Share Posted October 9, 2008 I have in my hand a piece of paper...... and it's green!!!! :D :D Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 9, 2008 Share Posted October 9, 2008 Awesome! Did you get a yellow one too, or just a green? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 9, 2008 Share Posted October 9, 2008 Only green Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 9, 2008 Share Posted October 9, 2008 Wow, congrats Bish, well done Now the really hard work starts...... Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted November 9, 2016 Share Posted November 9, 2016 Quote On 28/07/2008 at 9:14 PM, pat_pending said: A Couple of Pictures Of Mine. Massive thread revival! Sorry! Pat could you reupload the pictures of your console please. I'd saved them on an old computer with view to make a similar console but have since lost them, took me ages to find this thread! Quote Link to comment Share on other sites More sharing options...
pat_pending Posted November 9, 2016 Share Posted November 9, 2016 I've no idea what computer they were on. PM me your email and I'll take some more and send them. I wont get a chance until Sunday, but I can pop the top off so you can see how it all goes together. Even the simplest of pic's appears to exceed the file size limit on here now and I don't do photobucket etc. Pat 1 Quote Link to comment Share on other sites More sharing options...
