white90 Posted November 17, 2008 Share Posted November 17, 2008 Any proven methods I can try other than Sandpaper Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 17, 2008 Share Posted November 17, 2008 T cut. Stanley blade if the drops are raised enough and you have a steady hand Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 17, 2008 Share Posted November 17, 2008 Have you tried rubbing compound yet Tony Quote Link to comment Share on other sites More sharing options...
Ian M Posted November 17, 2008 Share Posted November 17, 2008 i had this issue once when a had an aerosol explode and spray black flecks all over a silver car, first off i t-cut it, then used normal polish to finish, it was hard work though, or mopping it may be a eaiser option! Quote Link to comment Share on other sites More sharing options...
timmymac Posted November 17, 2008 Share Posted November 17, 2008 if the drops are fairly new on older paint work thinners on one rag and warm water on another , then do very sort sessions with the thinners and wipe with the other then a good rub with compound and a coat of polish . always used to work if someone made a mess in the body shop Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 17, 2008 Share Posted November 17, 2008 If the paint specs are new and soft then T-cut will work a treat. Chris Quote Link to comment Share on other sites More sharing options...
white90 Posted November 17, 2008 Author Share Posted November 17, 2008 If the paint specs are old of unkown age and seem pretty set there? Quote Link to comment Share on other sites More sharing options...
JST Posted November 17, 2008 Share Posted November 17, 2008 grinder......... well you said not sandpaper i have some very abrasive scratch remover stuff here, more abrasive than T cut - may work you are welcome to try it. Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 17, 2008 Share Posted November 17, 2008 http://www.ukvaletsupplies.com/product_details_101.htm This is good stuff Quote Link to comment Share on other sites More sharing options...
landmannnn Posted November 17, 2008 Share Posted November 17, 2008 If the paint specs are old of unkown age and seem pretty set there? Are they raised like blobs? A disposable razor.......... Quote Link to comment Share on other sites More sharing options...
white90 Posted November 17, 2008 Author Share Posted November 17, 2008 no hardly detectable on the surface by feel but white on Blue paint Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 17, 2008 Share Posted November 17, 2008 Go over the rest of the car with fine white spots? Chris Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 17, 2008 Share Posted November 17, 2008 Ask on Meguiars UK forum They specialise in high quality products for valeting and paint shops - they have a company forum where you can ask this. They are helpful and their stuff is fantastic. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted November 18, 2008 Share Posted November 18, 2008 Depends on what sort of paint it is - I removed a load of household ceiling paint spots that had been there for months with boiling hot vinegar and a soft cloth recently - probably won't work on gloss etc but worth a try. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 18, 2008 Share Posted November 18, 2008 Have you tried rubbing compound yet Tony This should do it nicely in my experience. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted November 18, 2008 Share Posted November 18, 2008 http://www.ukvaletsupplies.com/product_details_101.htmThis is good stuff That's what I'd try. Water based and not greasy like T-Cut. If it's very hard I'd go with treating each blob to a haircut with a razor blade and then very fine wet n dry, compound then wax. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 18, 2008 Share Posted November 18, 2008 First rule of all paint - if you want it to stick it won't no matter how careful the preparation, and if you don't want it to stick, you'll never get it off even if it lands on a waxed surface in the rain! Always wondered why people bother with all this wet n't dry and primer, all you need to do to give a car an indestructable coat of paint is to accidentally paint it a colour you didn't want Quote Link to comment Share on other sites More sharing options...
white90 Posted November 18, 2008 Author Share Posted November 18, 2008 Thanks all I went and got some of This and it seems to work well Quote Link to comment Share on other sites More sharing options...
