crofty Posted February 5, 2009 Share Posted February 5, 2009 Hi guys New to all this but wanted some info Ive purchased a hi lift jack for my 90 CSW but cannot find anywhere to fix it! NOrmal places like the rear right side has a wheel carrier, left side has a ladder and it does'nt fit in the back Anyone any suggestions? Quote Link to comment Share on other sites More sharing options...
JST Posted February 5, 2009 Share Posted February 5, 2009 on the bulkhead horizontally or flat on the load bay clipped to one of the seat boxes Quote Link to comment Share on other sites More sharing options...
crofty Posted February 5, 2009 Author Share Posted February 5, 2009 Thanks for the suggetsions,..... I forgot to mention my bulkhead has been cut down so no room there and for some reason the jack length is too great to fit on the floor(only just mind!) I was wondering if I could fit to the spare wheel carrier but im assuming I would have to get something fabricated for that? Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted February 5, 2009 Share Posted February 5, 2009 Have you removed the top clamp or made it point horizontally when the jack is stood up by any chance? Quote Link to comment Share on other sites More sharing options...
headhunter Posted February 5, 2009 Share Posted February 5, 2009 There was a fitting for the rear wheel made by Terrain Master, but I have not seen them advertised lately. A well made fitting in stainless steel, with a bracket that was attached to the spare wheel bolts using 4/5" threaded spacers, and quick (lockable) release pins to secure the high lift jack. Otherwise buy a Simbars bike rack mounting bracket about (£30) which fits behind the spare wheel and protrudes through the centre to which you could make up a fitting to slide into the protrusion on which to mount your jack. See here - http://cgi.ebay.co.uk/LAND-ROVER-BOSS-FOR-...A2%7C240%3A1318 John Quote Link to comment Share on other sites More sharing options...
crofty Posted February 5, 2009 Author Share Posted February 5, 2009 Good ideas!! Thanks all, Ill get on a mission I'll get some pics on here soon Quote Link to comment Share on other sites More sharing options...
white90 Posted February 5, 2009 Share Posted February 5, 2009 Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted February 5, 2009 Share Posted February 5, 2009 best pic I could find of the rear sorry, Ive used hilift seciring brkts screwed thru the rear roof above the door. Make sure you re-inforce behind with ally or steel plate. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 5, 2009 Share Posted February 5, 2009 They do fit along the wheel boxes - it is a very tight fit though. On mine it would only fit one way.... give it another go? Quote Link to comment Share on other sites More sharing options...
nas90 Posted February 5, 2009 Share Posted February 5, 2009 Thanks for the suggetsions,..... I forgot to mention my bulkhead has been cut down so no room there and for some reason the jack length is too great to fit on the floor(only just mind!)I was wondering if I could fit to the spare wheel carrier but im assuming I would have to get something fabricated for that? The nas does not have a bulkhead behind the front seats, keep my jack along the RH wheelbox, just fits in the length of the tub, but ONLY after I cut-off the top inch or so from the jack Instead of a 4ft jack it's a 3ft 11ins jack, just remove the top hole, you can never raise a vehicle safely to the top anyway, only loss is if you use the jack as a winch, but I have a milemarker for that function Quote Link to comment Share on other sites More sharing options...
ragerover Posted February 5, 2009 Share Posted February 5, 2009 Fitted mine on vertical roof section above rear door on jac mount brackets saves space in back of landy sorry no pics Quote Link to comment Share on other sites More sharing options...
gazelle Posted February 6, 2009 Share Posted February 6, 2009 My 51 plate 90 CSW does not have a bulkhead. My Hi lift fits where the original LR jack went, between the front seats and the rear wheel boxes. It fits if the lifting head is within 6in or so of the bottom of the jack, so that the handle is within the length of the jack. I use the mounting points that were there already, and the straps that were attached to the mounting points to hold it down. I put the adaptor for the LR lifting points with the chock under the passenger seat. I haven't got either a picture of this at the moment, nor have I access to the vehicle (parked elsewhere). Sorry. HTH Martin Edit : found this in the tech archive whilst looking for something else : link Quote Link to comment Share on other sites More sharing options...
gazelle Posted February 6, 2009 Share Posted February 6, 2009 I haven't got either a picture of this at the moment This illustrates where the old jack was, and the hi lift now lives. Quote Link to comment Share on other sites More sharing options...
AD90 Posted February 6, 2009 Share Posted February 6, 2009 Along the face of the wheel box, and if it's too long - cut a bit off. Will you really miss 2"? AD90 Quote Link to comment Share on other sites More sharing options...
crofty Posted February 6, 2009 Author Share Posted February 6, 2009 eh up!! more options than menu,thats my weekend sorted just before I attempt Silverdale next week cheers guys,mucho appreciated Quote Link to comment Share on other sites More sharing options...
white90 Posted February 6, 2009 Share Posted February 6, 2009 For the record I have not cut any off mine and it fits along the wheel box fine Quote Link to comment Share on other sites More sharing options...
nas90 Posted February 6, 2009 Share Posted February 6, 2009 For the record I have not cut any off mine and it fits along the wheel box fine Now who was it that made the snow penis then Tony? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 6, 2009 Share Posted February 6, 2009 boom boom Dave Quote Link to comment Share on other sites More sharing options...
ajh Posted February 20, 2009 Share Posted February 20, 2009 Have you fitted a swing-away tire carrier yet? Some of them come with hi-lift jack mounts integrated and I think this is the way I'm going to go with it, but having a way to keep it dry and clean will be a priority too since here there's always snow, ice, and salt to worry about. I agree that carrying it inside would be nice but I've got other plans for interior space. Quote Link to comment Share on other sites More sharing options...
