stewy1984 Posted July 26, 2009 Share Posted July 26, 2009 I'm looking for some ideas and hopfully pictures of where people have mounted a arb compressor or other, in a 90 truck cab please. thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted July 26, 2009 Share Posted July 26, 2009 Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted July 26, 2009 Author Share Posted July 26, 2009 cheers tony. looks about the best and only place. have you rotated the bit with the solenoids on? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 26, 2009 Share Posted July 26, 2009 Mine is in exactly the same place. To rotate the resrvoir case just undo the big bolt at the end. Be careful not to damage the O ring at the open end though. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 26, 2009 Share Posted July 26, 2009 I have a T-Max Double-Pump compressor mounted in the same place Quote Link to comment Share on other sites More sharing options...
JST Posted July 26, 2009 Share Posted July 26, 2009 mines in a rear locker in the load bay above the wheel arch. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 26, 2009 Share Posted July 26, 2009 Mines similar but Higher, plate made to support underneath with a steady strap made to hold the top in place and stop it vibrating when on Nige Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 26, 2009 Share Posted July 26, 2009 Under the bonnet, where else?? Quote Link to comment Share on other sites More sharing options...
pedro Posted July 27, 2009 Share Posted July 27, 2009 on the front bumper!! (Warn powerplant HD) tank inside with 30ft hose extension. Quote Link to comment Share on other sites More sharing options...
mateyboy Posted July 27, 2009 Share Posted July 27, 2009 back of rear bulkhead. Quote Link to comment Share on other sites More sharing options...
calle-fas Posted August 8, 2009 Share Posted August 8, 2009 I mounted mine (Viair) inside the driver side (LHD) seatbox, onto the wall facing the door, just beside the battery. (Td5 110 this is). Had to move the battery just a tiny bit towards the center of the car, but I'm not sure that's necessary. The compressor now breaths from a filter mounted in the roof just above my head, and fills a tank that's mounted in what was before the second row passenger footwell. Could get some pics of the tank, but the compressor is hidden between the battery and the wall. Quote Link to comment Share on other sites More sharing options...
crwoody Posted August 8, 2009 Share Posted August 8, 2009 I've stuck mine on the front bulkhead, engine side between the wing & brake servo, not too noisy there! I was going to connect the inlet pipe through the snorkel and run it up to the top but never got around to it, so it's just next to the coolant expansion tank for now. Never had a problem though. I've since added an air reservoir tank, (an old water fire extinuisher) between the chassis rails above the rear propshaft with a separate take-off for tyre inflating or air tools etc. Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted August 25, 2009 Author Share Posted August 25, 2009 Cheers for all the idea's. i ended up mounting it between the seats on the bulkhead, like above. but f**k me its noisey, struggled all day sunday trying to hear co driver when it was running, plus the fact its leaking doesnt help. So its going to have to go outside or in the engine bay. Quote Link to comment Share on other sites More sharing options...
JST Posted August 25, 2009 Share Posted August 25, 2009 Cheers for all the idea's. i ended up mounting it between the seats on the bulkhead, like above. but f**k me its noisey, struggled all day sunday trying to hear co driver when it was running, plus the fact its leaking doesnt help. So its going to have to go outside or in the engine bay. wear a helmet with coms kit - a good move if your competing anyway and easier on the codriver too plus you wont hear it as much! Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted August 25, 2009 Author Share Posted August 25, 2009 It would be nice mate, maybe one day. We've only just started doing the cheviot4x4 winch challenge series, our second event. Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 25, 2009 Share Posted August 25, 2009 Under the bonnet, where else?? This looks good, where did you find the bits for teh compressor, solonid, intake etc etc? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted August 26, 2009 Share Posted August 26, 2009 This looks good, where did you find the bits for teh compressor, solonid, intake etc etc? Theres a few excellent write ups on onboard air in the tech archive Mike Quote Link to comment Share on other sites More sharing options...
