Disty Posted September 9, 2010 Share Posted September 9, 2010 Hi Guys, I'm doing a rebuild on my 300tdi 90, and decided to go down the route of redrilled swivel balls. I live in sheffield so thought that it couldn't be hard to find a decent engineers who would do it. I started with some new teflon coated swivels and took them down to get looked at. I ended up paying a fair wack as the engeering shop machined a custom jig to hold the swivel while it was being drilled, and of course had to work out the bolt config etc. I would like to re-use the jig which I paid for, and also give the lads who worked very patiently on my project some more work. Is anybody interested in having swivels custom drilled to the height of their lift? Does anybody have any thoughts on this process? Pictures of swivels to follow... Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 9, 2010 Share Posted September 9, 2010 I'm sure photo's will answer this question, but which part of the swivel are you re-drlling and why? Cheers Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 9, 2010 Share Posted September 9, 2010 The holes where it attaches to the axle tube, by moving the holes to the correct orientation the Castor angle can be put back Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 9, 2010 Share Posted September 9, 2010 The holes where it attaches to the axle tube, by moving the holes to the correct orientation the Castor angle can be put back It also enables prop UJs to be kept at a healthier angle, and IMO is a better solution than using castor corrected radius arms. It does not however relieve any strain on the chassis to radius arm bush. Bush strain relief would require a radius arm cranked at the chassis end, such as that offered by Gwyn Lewis. (Note Gwyn offers to crank both ends or just the chassis end). I have no connection with Gwyn, nor do I even own any of his products. This is just an engineer's observation of the geometry involved. Quote Link to comment Share on other sites More sharing options...
henk Posted September 9, 2010 Share Posted September 9, 2010 What do you do with the existing holes? Weld them? Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 9, 2010 Share Posted September 9, 2010 What do you do with the existing holes? Weld them? hmmm, I'm guessing you're talking about lifts in excess of 2" for it to be really worth it? Intresting, when is it too close to the holes that are already there? I do like the idea though. Quote Link to comment Share on other sites More sharing options...
henk Posted September 9, 2010 Share Posted September 9, 2010 A lift of 2 inch means you have to redrill the holes about 5mm (calculated this once but forgot exact distance) so as the new hole is so close to the original one, best would be to close first and then redrill imho. This also avoids play on the bolts I think. Someone who knows the length of a Front Radius Arm and the PCD of a swivel ball? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 9, 2010 Share Posted September 9, 2010 Most correction arms for a 2" lift claim to offer a 3 degree adjustment. Definitely weld up the old holes first, then you have an uninterrupted cut into 'fresh' metal. Aside from this I don't like the idea of a slot for these bolts, it would provide too much opportunity to set them up wrong, or to move if you don't tighten the bolts adequately! Quote Link to comment Share on other sites More sharing options...
redneck Posted September 9, 2010 Share Posted September 9, 2010 It would better to drill the axle casing rather than the swivel housing. Makes replacement of the swivel housing with an off the shelf item possible. Not that they need replacing that often. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 9, 2010 Share Posted September 9, 2010 It would better to drill the axle casing rather than the swivel housing. Makes replacement of the swivel housing with an off the shelf item possible. Not that they need replacing that often. Very true, and possibly easier to do. I hadn't got as far as thinking of which bit to mod, just the geometry issue Quote Link to comment Share on other sites More sharing options...
redneck Posted September 9, 2010 Share Posted September 9, 2010 Very true, and possibly easier to do. I hadn't got as far as thinking of which bit to mod, just the geometry issue I wouldn't even remove the axle. Just cut the flange off an old swivel housing and use it as a drilling jig, a few hours work each side at most. Quote Link to comment Share on other sites More sharing options...
Disty Posted September 9, 2010 Author Share Posted September 9, 2010 Just to note, the metal is in the engineers words "tough as nails"- bit of a ridiculous thing to say, but his point was that it's very tough stuff, and I think you really need decent machinery to do it. I'll get some pictures up this weekend, don't have the balls with me. There is no welding on these! The ideal set up imho is to have single/double cranked trailing arms at a STANDARD castor angle, and then have redrilled swivels. The castor correction arms are terrible for 3 reasons: They're damn expensive They supposedly break very easily (?) They worsen the pinion angle causing prop-shaft vibrations to increase and UJ's to wear quicker. (?) I wanted a lift which would be driveable without wandering steering, but wanted to use stock radius arms. I'm going to try and get mine bent. I love gwyn lewis, but wales is a bit of a journey and they're gonna be damn expensive to post... Pictures to follow tomorrow night!! disclaimer: I'm not suggesting this method is the best or the only method- just my custom method- we'll see how it holds up! Quote Link to comment Share on other sites More sharing options...
Disty Posted September 9, 2010 Author Share Posted September 9, 2010 @Maverick you can read more about this solution here: http://www.lrautomotive.com.au/contents/en-us/d658.html That site says 1 degree for every 1/2 inch lift. So 2 inches and you're at 4 degrees. Most people agree on 3, and mine are redrilled 3 degrees. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted September 9, 2010 Share Posted September 9, 2010 The best thing to do in my book would be to buy new balls, have them machinned, and offer them for sale, done Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 10, 2010 Share Posted September 10, 2010 I'll get some pictures up this weekend, don't have the balls with me. There is no welding on these! Are they slotted then? I can't see how you can re-drill and not have slots without welding the old holes up first. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted September 10, 2010 Share Posted September 10, 2010 ................... I love gwyn lewis, but wales is a bit of a journey and they're gonna be damn expensive to post... [............... Not really. Use someone like INterparcel.com My calculation makes it about £13 Quote Link to comment Share on other sites More sharing options...
Lara Posted September 10, 2010 Share Posted September 10, 2010 Just to note, the metal is in the engineers words "tough as nails"- bit of a ridiculous thing to say, but his point was that it's very tough stuff, and I think you really need decent machinery to do it. I'll get some pictures up this weekend, don't have the balls with me. There is no welding on these! The ideal set up imho is to have single/double cranked trailing arms at a STANDARD castor angle, and then have redrilled swivels. The castor correction arms are terrible for 3 reasons: They're damn expensive They supposedly break very easily (?) They worsen the pinion angle causing prop-shaft vibrations to increase and UJ's to wear quicker. (?) I wanted a lift which would be driveable without wandering steering, but wanted to use stock radius arms. I'm going to try and get mine bent. I love gwyn lewis, but wales is a bit of a journey and they're gonna be damn expensive to post... Pictures to follow tomorrow night!! disclaimer: I'm not suggesting this method is the best or the only method- just my custom method- we'll see how it holds up! Answers to your "anti" corrected arms list. 1. Is re-drilling 2 "hard as nails" swivels plus any future replacement swivels honestly cheaper? 2. Supposedly! 3. Think about it!! How can putting the angle back to standard be worse than moving it away from standard and often needing double cardan props to rectify miss coordination of prop uj angles? Not trying to cause a fight, just sensible observations! Lara Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted September 10, 2010 Share Posted September 10, 2010 Personally I wouldn't be trusting my life to reworked swivles, especially if the metal was high-carbon or chrome steel as you are weakening it. Wedling it up first? that just makes it worse, full of stress, heat effected metal (crystalised) and dissimilar metals. If you realy hate castor correcting arms then buy properly offset swivles from Tomcat Motorsport. Reason why I Like QT castor arms 40% lighter lengthened to correct the wheelbase with the lift corrected at the chassis end and the axle end straightens the spring because the spring seat is level releaves the twist in the lower shock mount and panhard rod bushes straightens the bottom UJ allowing the fitting of a TD5 propshaft/flange for zero noise transmission stops steering wander and re-aligns drag link and track rod all other parts standard/of the shelf. as soon as you fit a 2" lift you will start having propshaft problems, they become more noticeable with castor arms but they are there anyway. I re-aligned the propshaft UJs to make it better but it will always be there. Quote Link to comment Share on other sites More sharing options...
redneck Posted September 10, 2010 Share Posted September 10, 2010 Answers to your "anti" corrected arms list. 1. Is re-drilling 2 "hard as nails" swivels plus any future replacement swivels honestly cheaper? 2. Supposedly! 3. Think about it!! How can putting the angle back to standard be worse than moving it away from standard and often needing double cardan props to rectify miss coordination of prop uj angles? Not trying to cause a fight, just sensible observations! Lara Your not putting the pinion angles back to standard. Parallel pinions are recommended for a 3 or 4 link setup. however the front end is a ladder bar system, the front axle sweeps in an arc from the chasis mounting not perpendicular like a 3 or 4 link system. The front uj on the front axle is only really there to take up the misalignment when the axle twists etc. the rear u.j does most of the work when the axle moves up an down. Using caster corrected arms is just a backyard solution which increases the angles at both joints, therefore increasing the vibration and wear. If the chasis pivot and the gearbox u.j were perfectly ( :lol: not in land rover world) aligned then you could fit a solid joint at the axle end without any problems (if the axle were to travel in a vertical axis only obviously). Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted September 10, 2010 Share Posted September 10, 2010 Personally I wouldn't be trusting my life to reworked swivles, especially if the metal was high-carbon or chrome steel as you are weakening it. Wedling it up first? that just makes it worse, full of stress, heat effected metal (crystalised) and dissimilar metals. If you realy hate castor correcting arms then buy properly offset swivles from Tomcat Motorsport. Reason why I Like QT castor arms 40% lighter lengthened to correct the wheelbase with the lift corrected at the chassis end and the axle end straightens the spring because the spring seat is level releaves the twist in the lower shock mount and panhard rod bushes straightens the bottom UJ allowing the fitting of a TD5 propshaft/flange for zero noise transmission stops steering wander and re-aligns drag link and track rod all other parts standard/of the shelf. as soon as you fit a 2" lift you will start having propshaft problems, they become more noticeable with castor arms but they are there anyway. I re-aligned the propshaft UJs to make it better but it will always be there. but don,t forget they also suffer stress fractures Quote Link to comment Share on other sites More sharing options...
Giles tout terrain Posted September 10, 2010 Share Posted September 10, 2010 If i remember correcly most Simmbugghini's and i know for a fact my one has redrilled swivels and most have been and still will race for years as they are Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 11, 2010 Share Posted September 11, 2010 When I converted a 110 front axle to fit on leaf springs I had to alter the castor angle. I made up a simple jig, sliced through the axle tube, rotated it to the new position, then welded it back together again. Just an alternative to redrilling swivel balls. Marked-up prior to the cut - Very carefully cut with a plasma blade - Chamfered to allow depth of weld - The simple jig I made is bolted to a couple of the diff studs, then a plate on the end to hold the flange in position. A few spot welds and then check all is square - Then full weld - I cleaned the weld down, then banded over it with 4mm plate (just to be sure ) - Les. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 11, 2010 Share Posted September 11, 2010 Reason why I Like QT castor arms 40% lighter And considerably weaker than std, just in case you've missed all the recent topics on this issue. Quote Link to comment Share on other sites More sharing options...
Disty Posted September 11, 2010 Author Share Posted September 11, 2010 Although range rover blues does have a point about the spring seat orientation. If it's a toss up between aligning suspension and pinion angle, I'd go for pinion angle any day. The real question is, is anybody interested in laying down the bucks for these? (If not, I may as well stop here!!) Picture attached. Quote Link to comment Share on other sites More sharing options...
Disty Posted September 11, 2010 Author Share Posted September 11, 2010 Personally I wouldn't be trusting my life to reworked swivles, especially if the metal was high-carbon or chrome steel as you are weakening it. Wedling it up first? that just makes it worse, full of stress, heat effected metal (crystalised) and dissimilar metals. If you realy hate castor correcting arms then buy properly offset swivles from Tomcat Motorsport. From other peoples replies it seems castor corrected arms are definitely not an ideal solution.. As you can see, I've not done any welding at all- you're right about how it would affect the steel. It was also my understanding that Tomcat no longer offered these. Does anybody know any different? Quote Link to comment Share on other sites More sharing options...
