L90 BCM Posted January 13, 2012 Share Posted January 13, 2012 Where should i buy carling switches from ? I was going to buy 4 of them from mud-uk but then i realised that they are the wrong way up. But i was going to buy the defender rear wash wiper from them as well. My other option was to by them from croy tec bcus i have herd that they are the correct way, so can i just buy a off-on-mom switch from croy tec and wire it up the same way as it would have been if i brought the defender washer switch from mud uk ??????? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 13, 2012 Share Posted January 13, 2012 Just buy the right type switch from them and wire it up as you would expect the MUD one to be EDIT: X-Eng also sell carling switches I believe. Though I'm not sure which type they are. Quote Link to comment Share on other sites More sharing options...
L90 BCM Posted January 13, 2012 Author Share Posted January 13, 2012 Just buy the right type switch from them and wire it up as you would expect the MUD one to be EDIT: X-Eng also sell carling switches I believe. Though I'm not sure which type they are. yes but i dont know if the connections are the same for the off-on-mom switch and the defender wash wipe switch. Does any one know ? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 13, 2012 Share Posted January 13, 2012 (edited) I was under the impression that Carling are American switches and therefore are the 'wrong' way up, thing it said something about that on either Muds' site or X-Eng's site typically, I can't find it now... Edited January 13, 2012 by ejparrott Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 13, 2012 Share Posted January 13, 2012 Carling are american, but they do make the switches in both configurations. Quote Link to comment Share on other sites More sharing options...
L90 BCM Posted January 13, 2012 Author Share Posted January 13, 2012 I was under the impression that Carling are American switches and therefore are the 'wrong' way up, thing it said something about that on either Muds' site or X-Eng's site typically, I can't find it now... I believe this is the quote you are looking for which was found on the mudstuff website. The switches ARB uses for its air-locker kits are Carling Technologies Contura II switches. ARB switches are compatible with the full range of Carling Switch Mounts and accessories. Please note that ARB switches rock the opposite way to our Carling switches. MUD Carling switches operate in the American style. Push the top to turn 'on'. ARB Carling switches operate by pushing the bottom to turn on. I have been reading a little more and i think the best way for me is to just buy them from mudstuff as the rear wash wipe switch makes sure the wiper blade goes back to the home position which i do not think i would get doing it my self Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 13, 2012 Share Posted January 13, 2012 the same style and configuration but right way up are available from hella,i have replaced like for like in terberg port machineryand they have come in hella packaging. Quote Link to comment Share on other sites More sharing options...
jimyd Posted January 13, 2012 Share Posted January 13, 2012 We use a company called dun bri at work. http://www.dun-bri.com/3338490-switches-dash-lights/21609903-carling-contura-ii-complete-switches/page_1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 13, 2012 Share Posted January 13, 2012 Just buy the right type switch from them and wire it up as you would expect the MUD one to be EDIT: X-Eng also sell carling switches I believe. Though I'm not sure which type they are. When I bought a switch or two I found Si was cheaper than Mud due to postage. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 14, 2012 Share Posted January 14, 2012 We use a company called dun bri at work. http://www.dun-bri.c...switches/page_1 Cheers mate, If I had been able to find this seller through Google 2 days ago I might have saved a fortune Bookmarked for future though Quote Link to comment Share on other sites More sharing options...
jimyd Posted January 14, 2012 Share Posted January 14, 2012 Cheers mate, If I had been able to find this seller through Google 2 days ago I might have saved a fortune Bookmarked for future though Sorry, thats nomaly my luck!!! Thay do some good stuff and the service is not bad either, although i have not tried to send anything back yet! OT, but was it you that has put Nissan axles under your truck? I have a set that i have been fitting for way longer than i should cos of that anyoying think called work! If so do you mind if I drop you a PM about it? Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 14, 2012 Share Posted January 14, 2012 Correct. And still going strong. Feel free to PM me and I will help if I can Quote Link to comment Share on other sites More sharing options...
simonr Posted January 14, 2012 Share Posted January 14, 2012 You know that if the switch is the "wrong way" you can remove the rocker bit on the front and turn it the other way up? We just buy the switches off of MUD to compliment the other bits X-Eng sells - but make absolutely nothing on them. Sure I could buy them direct from Carling, but I like Kevin and he's much easier to deal with for the relatively small volumes we require. To that end, it makes no odds to me whether you buy from X-Eng or MUD. They are lovely switches! I had one on the outside of a truck as a winch controller and it survived gentle jet washing plus everything off roading could throw at it! It's probably not recommended - but it shows how good they are! Si Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 14, 2012 Share Posted January 14, 2012 When I bought a switch or two I found Si was cheaper than Mud due to postage. I was going to, but I wanted the rear wash/wipe switch, so I went with Mud....Sorry Si! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 14, 2012 Share Posted January 14, 2012 You know that if the switch is the "wrong way" you can remove the rocker bit on the front and turn it the other way up? I thought just turning over the switch facia means that the lighting will be all wrong? Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 17, 2012 Share Posted February 17, 2012 Yes you are correct Ross. Ive been told by MUD that if you swap the rockers around, instead of them lighting green with sidelights to match LR gauges, they will light orange. Oh and when you switch em on the led bar will of course be green. That is why i will be going with dun-bri so the switches will be 'press bottom to switch on'. It may not seem a big deal but it doesnt feel natural pressing the top of them to switch them on. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 17, 2012 Share Posted February 17, 2012 I have a mixture in my truck... but never had a problem! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 17, 2012 Share Posted February 17, 2012 I'm reading this and wondering. What's so good or different about Carling switches ? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 17, 2012 Share Posted February 17, 2012 You could use an ordinary On/Off Carling Switch, wired to switch a changeover relay to earth, as is done in the 2002 -> Defender. The relay is mounted on the rear door, behind the door-card. . Quote Link to comment Share on other sites More sharing options...
ejparrott Posted February 18, 2012 Share Posted February 18, 2012 Just recieved my last 3 SPST switch's I need from Si, hopefully I can see about getting them wired in to my Raptor Dash now, just got to remember where I put the instructions for the wash/wipe. and how to wire the SPDT switch! Quote Link to comment Share on other sites More sharing options...
Dads Toy Posted February 18, 2012 Share Posted February 18, 2012 I bought all mine from Mud, the rear wash/wipe from him is the easiest way to get that working. This does mean that you have them the "wrong" way round though I've got totally used to it despite my initial fears. They're actually just a robust switch that's very straightforward inside. You could take the front off and turn it round and it's not a difficult job to swap the led's over (apart from the mini resistor and the springs that make a bid for freedom as soon as you open it) but why bother? Malcolm Quote Link to comment Share on other sites More sharing options...
Landrover hangover Posted March 5, 2014 Share Posted March 5, 2014 Any one have a pin function diagram for the lucas 579006 round switch ? I'm in the process of replacing with a carling wiper washer switch and the pin function diagram it comes with does not match up with the old style round Lucas wiper washer switch. All this being fitted to a yr 2000 Defender 110. Quote Link to comment Share on other sites More sharing options...
