Les Henson
Removal of the EGR on a 300TDi
Right then here are some pics of my engine minus the EGR and the bits I took off.
EGR valve removed from exhaust manifold.
Top intercooler hose (cheap silicone ones from fleabay)
EGR solenoid with pipe work removed but still connected electrically positioned on nearside inner wing by the air intake part of which is removed to take the photo.
The bits that were removed.
HTH :D
Pete.
editted to add the following.
just remembered that i blanked off the vacuum feed to the solenoid at the tee on the bulkhead (sorry no picture of that).
Share this post
Link to post
Going back to the post by BogMonster on the previous page, I am intrigued by the ftment og an EGT probe refered to in the posts from last year. I note that a few regulars have these fitted and wonder what I would need to buy and where to get it in order to fit one to my 200 tdi disco. I have full set of tap and dies.
I have tweeked the pump a little bit and upped the turbo boost (again only a bit) but have noticed recently, especially when towing up long hills that the engine "smells" hot. The temp gauge rarely goes above halfway (when I remember to turn on the leccie fan!).
Share this post
Link to post
im sure ive seen a thread on fitting EGTs mark. damned if i can find it though, maybe someone else will be able to?
Share this post
Link to post
Yep
I found the post in the tech Archive earlier. Was in fact the same one as was refered to in this thread! But where does one actually buy the stuff from to make one. i found somewhere selling the probes but not the digital read-outs. Any one?
Share this post
Link to post
Thermoman for me too - a complete kit everything you need to fit it except a number plate fixer which I used to attach the display.
Share this post
Link to post
just finished removing my egr valve finally, after 2 prvious attempts. first time just blocked the pipe after the valve wi a thin piece o metal. worked fine but looked a bugger. second time couldnt get those pesky allen screws undone for the life of me, and anyway had got a wrong blanking plate (td5 too small, my mistake ,oops, cant read) :unsure: this time follwed advice on here and after soaking with wd40 and going for a drive, then chapping gently with a chisel and medium persuader, they popped off just like that (well almost like that), only removing a small amount of skin from two of my knuckles in the process, bargain! :D looks much neater now with proper blanking plate and big gasket from famous four, v cheap, and a proper rubber intake hose from pegasus parts, v v cheap. nice 1 :D
Share this post
Link to post
We also remove EGR from TD5s. Remove the pipe thingy that runs around the front of the engine, fit a blanking plate (home-made) to the exhaust manifold, push a ball-bearing down the vacuum (or whatever) connection and unplug the electrics. The ECU is quite happy after this. But, like Steve in the Falklands, we don't have to worry about emission tests as there are no rules here either. And no MOT test, which is a good thing or a bad thing depending on your point of view.
Share this post
Link to post
I've done Td5s too but a bit differently. All I did was pull off the vacuum inlet to the EGR modulator (stupid buzzy thing on wing) and the pipe to the valve itself (the bit in the manifold) shove either a small bolt, or neater still a 3/16" blind pop rivet, into the end of the connectors, put a small cable tie round the rubber part of the connector to hold the rivet in place and then cable tie the pipes to the third one (which just feeds the breather filter). The electrics are still connected so no faults, but no vacuum to the valve means no EGR silliness as the valve stays closed, it can all stay in place :)
Note: you MUST block the vacuum feed otherwise the vacuum pump is sucking in air all the time and this does not improve the brakes :blink:
Share this post
Link to post
yep, i just stuck a bolt up the vacuum pipe and tucked it out of the way. sailed through it's emissions test at the mot with 132000 miles on the clock :D
Share this post
Link to post
We remove the pipe and fit a blanking plate because the pipes have a history of breaking off under the EGR valve. The pipe doesn't break, but the alloy connection into the EGR valve does. This causes major havoc with the exhaust gases melting the plastic cover and electrical wiring etc.
I make the blanking plates using an angle grinder and a drill. We have been meaning to have some laser cut.
I'm glad to see that it makes little or no effect to the emissions.
Share this post
Link to post
Interesting ... I've never seen that here but I can see it would get a bit warm under there!
Share this post
Link to post
After following the thread , i decided to replace my brother 300's EGR valve and fit one of those thermo guages. ordered it from Thermo man too. took some 6 days to travel from Down under to the island of Malta.
The digital guage looks great during night driving !!!! :lol:
thanks for the very detailed topic.
I also have some pics to add to the ones you have about the dashboard fitting and wire routing , but here ISP connection is slow so it will take me some time to put them up.
thanks again
Share this post
Link to post
I have had an egr removal kit on my TD5 for about 1 year now, this consists of a blanking plate for the ex manifold and a flange and pipe assy to replace the egr valve complete, been trouble free as it should be no moving parts etc!
Lynall
Share this post
Link to post
i have just unplugged mine - as I believe the solenoid is failed shut without power, so havent gone to the hassle of removing it unless someone knows otherwise.
But boy what a difference. At 1800-2800rpm when on full boost. i can really feel it pulling,
Worth doing.
Share this post
Link to post
I would think that'll only work if your EGR valve hasn't failed yet? They seem to jam open rather than shut.
Share this post
Link to post
agreed, before i removed mine i took off the pipe from the egr to the intake and it was just puffin out smoke all the time, so got rid and then got rid of cat also for an even better improvement. next i'm gonna clean out the intercooler. http://homepage.ntlworld.com/stage1v8/Tech...Intercooler.htm havent got round to doin my suspension yet though :mellow:
Share this post
Link to post
Hello everyone, this is my first post (reply) since joing the forum and I would just like to say that the technical info on here is outstanding but expensive as my
wallet is getting worried with all the extra mods to come.
Anyway the reason I'm posting here is I wanted to know if someone could tell me where to get a EGR bypass top hose for a 300Tdi (intercooler to inlet), I've seen the pic on this thread of the one I want and it suggests ebay, but even on there I cannot find one. The only ones that would do the job come in lengths of a metre but I haven't got any use for it as I'm already siliconed up everywhere elese (apart from the wife)
cheers lads
Rich
Share this post
Link to post
Buy one from a dealer - it won't be that expensive. You just need to ask for a hose from intercooler to inlet manifold for a non EGR engine.
Share this post
Link to post
If you want silicon call Allisport .. thats where i got mine ..
Cheers
I found that the standard Intercooler to Inlet minus EGR branch is around £6-7 and I'm about to send a mail to Allisport.
Share this post
Link to post
standard one is perfectly ok and far cheaper.
my TDI is running 18psi and was 21psi with standard tube work
never had any issues.
make sure you seal the tube that went to the large bore tube work from the airbox to the turbo around the basck of the engine as this is after the airfilter and any water getting in there is non stop to the engine.
I removed the entire set up wiring everything.
Share this post
Link to post
Just come back from Landranger in Stockport with the bits I need.
1 Rubber Inlet Hose
1 Blanking Plate
Gasket & Bolts for good measure
Bring on the weekend!!!!
Share this post
Link to post
