Toolkit for the landy
LR90
Got the new machine mart catalogue through the door today. Keep looking at those tool 'kits' in the hope one might be suitable for the landy. Sadly they tend not to come with large enough spanners and are packed with numerous small but totally useless items. Now this is a shame as having the toolkit in an abs moulded box makes it easier to check you've picked them all up after a bodge but I've not seen a suitable kit yet.
So, other then that stock brace of AA and Visa cards, what would you recomment as a suitable basic (& cheap cos its being left in the landy) set of tools to carry day to day?
OK FWIW my normal efforts - bear in mind I do a lot of recovery work and marshalling etc.....
Last few things you broke if liable again ie CV shafts etc
Fan belt PAS Belt
Brake fliud
Brake union blanking plugs
Fire Extingusher
Proper 1st Aid Kit
Basic tool kit spanners screwdriver socketset
Hammer
Mole grips
Bits of electrical wire and connectors
Self Amalgam tape
Gaffer Tape
Torch (no use having spares if you can't see !)
Lighter
Knife
Adjustable spanner water pump pliers
Pliers cutters
Breaker bar and 27mm socket for wheel nuts
Bulbs covers
WD40 (yes even with Megajolt :lol: )
Fuel pumop motor
Zippy Ties
Spare wheel
Track rod
Steering bar zippy tied to cage
EP90 I litre 20/50 Litre
2 pack araldite (amazing what you can fix with it !)
Fuel hose (often for marsahalling)
Spark plug and lead (useful for seeing re spark)
Emergency Thermal blanket (its tiny but could save you / someones life)
Asprins
Water 2 litres wash injury or for drinking
Mobile
AA Card
1 gallon Petrol (well its a V8 :D )
Strops shackles KERR snatch block highlift
Whistle (gets attention)
Cagool - ultra thin weights / size nothing
Jubille clips and rachet strap
Fine wet and dry paper just a strip(cleans points etc)
There yer go............... :rolleyes:
Nige
I put together my own 'cheap' tool kit to keep in the LR, often got some good deals at the shows on reasonable quality tools, certainly good enough for ocasional/emergency use.
In the onboard tool box I have..
set of metric spanners 8-19mm
commom imperial sizes, 1/2", 9/16", etc
couple of adjustable spanners
metric sockets 1/2 and 3/8 covering 6-24mm
1/2 and 3/8 ratchets plus extension bars
selection of screwdrivers
pliers
needle nose pliers
circlip pliers, internal and external
prop shaft tool
hub nut tool
hammer
couple of chisels
small heel bar
zip ties, lots of
gaffa tape
latex gloves
and probably one or two things that don't come to mind at this time of night :unsure:
Set of cheap spanners 8mm to 32mm (£10 at Billing)
Old socket set (bought when young - don't care if it gets lost) up to 19mm imperial & 3/4 metric
£10 multi-meter from Maplin
A hub nut spanner and one of the magic prop shaft sockets from Difflock
A club hammer
Selection of nuts, bolts, hose clips, wire and hose.
Rachet Straps, cable ties & gaffa tape.
That covers most of what you are likely to be able to fix on the trail.
Sometimes carry an impact gun, drill, selection of bits up to 10mm (remember you can chain-drill bigger holes) and a 27mm socket for wheel nuts + 30mm socket for rear A frame ball joint.
If I was going to carry something else, it would be a air die-grinder for general grinding & cutting (on a small scale)
Si
Edited to say:
Forget the tool kit, take Nigel or Mark with you!
spare undies if Nige is recovering you ;-)
I carry way too much in the 90 - socket kit, my spanners, torque wrnch, hub nut socket, hammers of course, grease gun, wheel bearings, track rod & tres, belts.
when i am going somwhere, spare cv and loads of other carp. seriously the 90 went much better when i cleared the back out one week
BIG Hammer
BIGGER Hammer!
Duct Tape (for if it moves & it shouldnt)
WD40 (for if it doesnt move & should)
:D:D:D:D
seriously i carry way too much in the way of tools etc. there is an electric drill & a rivet gun somewhere in my car. this is why i upgraded to LRs from zooks, id rather carry too much than too little & it dont all fit in a small car.
I used to have a copy of a newspaper clipping taken from a LandRover Club newsletter on the workshop wall that went something like this.Quote'' I have always thought of LandRovers as an overated pile of British nuts and bolts. The only reason they brought out the long wheelbase model was that the SWB model didn't have enough room and capacity to carry all the tools and spare parts necessary to keep the vehicle on the road. If a LandRover owner says that he has been off the road recently, it usually means that the vehicle was in the garage being repaired. end quote.
Bill.
Fan belt PAS Belt
Brake fliud
Fire Extingusher
Proper 1st Aid Kit
Hammer
Mole grips
Self Amalgam tape
Gaffer Tape
Lighter
Knife
Pliers cutters
Bulbs covers
Fuel pumop motor
Zippy Ties
Spare wheel
Track rod
Asprins
Mobile
AA Card
Nige
I looked at the list and though kin hell I dont have anywere near enough kit on board but thinking about it the only things on the list I don't have in the challenge truck is...
wet and dry paper
whistle
plug and lead
EP90 but I carry ATF instead
water pump pliers
other wise its all there
how the hell it fitted all that in a truck cab I will never know
but after the roll I was hours unloading all my little hiding places in the cab and rear tub
This is more than tools :D ……………………I’m going to have to rationalise a bit :( , as often I carry this lot……………….
Spares
EFI Coolant sensor
EFI thermotime switch
Electronic ignition amp module
Ignition Coil
EFI Fuel pump
4 wheel bearings
complete axle set of seals
CV joint
Front Brake Hose
Axle bearing lockwashers
Rear half shafts
Axle drive flange bolts
2 U/J’s
Dizzy Cap
Dizzy rotor arm
Water pump belt
Steering pump belt
Spark plugs
One complete set of plug leads
Brake / Clutch Fluid
5/8 coolant hose
3/4 coolant hose
Fuel hose
Rad top hose
Rad bottom hose
Can of stop leak
Fuses
Wire
Crimps
Cable ties …..all sizes
1 Litre of ATF
1 Litre of EP90
1 Litre of 10-40
WD40
Self amalgamating tape
Electrical tape
Spare bulbs
Tools
One set of ratchet spanners 7mm to 19mm
One set of ratchet spanners ¼ AF to 1inch AF
One set of metrinch sockets
4lb club hammer
Pry bars
Hacksaw with 18tpi blades
Allen keys
Adjustable spanner
Mole Grips
Screwdrivers
RTV
Battery impact gun
Stick welding holder (connect to jump leads)
A small dark shade welding glass
1/8 Welding Rods
Brake Bleed tubes
Hand cleanser
Marigold gloves :lol:
4 Mag lights
5 Million candle power hand lamp
LED hand lamp
Recovery Gear
17 shackles (I just been out and counted them …..sad)
6 foot bridle rope
2… 24 foot KERR’s
50 foot winch extension plasma 12
2 … 16 Ton tree Strops
15 foot tow rope (6 Ton)
2 Green Recovery straps
4 foot Hi-Lift
2 Wheel chocks
2 50mm waffles
2 snatch blocks
Shovel
21 inch bow saw
Other Stuff
GPS
Laptop (digital maps)
Digital compass
Marching compass
Illuminated magnifying glass
AA – AAA – C Rechargeables (Fitted a 1 hour in-car charger)
Rayban Sunglasses
Paper maps
2 PMR handhelds
Binoculars
Bungy straps
Permanent marker pen
Phone
Yellow Highlighter Pen
Yellow tire chalk
2 - 1 Gallon fuel cans
Ratchet straps
Reflective Jacket
Spare Keys
Towel
Spare Socks
Chocolate
Tins of soup (it takes about 40 minutes to warm a tin of soup from the V8 exhaust headers ………. Just wire the tin on top of the exhaust headers.
Paracetamol
Large First Aid Kit
Elastic bands
Ian
40mins for a tin of soup on a V8 eh? should be about 30mins strapped to the turbo on my TDi then? now do i need the baked potatos nearer or further from the engine for best results? :D
i did try the baked potato thing once, but threw the car in a mudhole which kind of ruined the plan as id cut the potato open.
I use this one
Add a big hammer, maybe a big adjustable and some prybars and you aren't far off of the money IMHO
Seems a well thought out kit
Now that is useful - to have almost everything in one box that you can pick up and throw into whatever vehicle you are going in. If I don't have tools with me its because I can't be bothered to pick them off the wall put them into a toolbox and then spend ages hanging them all up again afterwards but an all in one box sounds like a damn good idea :)
Sainsburys combat food - £2 a pack, can eat it cold or strap it to the turbo, its in a tinfoil pack and has over 1100 calories per sachet - yay! lard mmmmm :)
I cant get over how many tools/recovery bits you all take out (not a criticism just an interested observation), how much does it all weigh?
I lernt long ago the cars have there own tool left in them that way if a Pikey/Chav helps himself your good home tools arnt missing...
Having said this I have just noticed that my every day car the disco has a 13mm ring spanner and a multi screwdriver, apart from the factory jack & wheel brace that it.... oops
Dunno what my tools weigh but they all fit in a 16" platsic tool box and they certainly weigh less than the main tool box which either stays at home or goes in the service truck.
The car tool box lives in the 110 which is my daily drive and takes all of 30 sec to transfer to 90 when required. Like Jules I don't like carrying my main/expensive tools around all the time.
i do carry my main/expensive tools. mainly cause i live in a studio flat & there is no way i can keep them inside. i wont bother to list it all but included are a complete set of shafts/props/CVs/drivebelts/oils/water/etc/etc an it fills the boot of my disco to within about 6" of the bottom of the back window.
weighs a hell of a lot but when im playing 5hours from home (like last wkend in wales) i dont want to be stuck cause i've got something broke & the tools at home.
