Jamie_grieve Posted September 16, 2014 Share Posted September 16, 2014 For the cab tilt, why not use some coil springs near the front and keep it all mechanical? I'd never seen this arrangement until I recently got a Gaz 66 and it works really well. Can you post a few more pics of your hinges and lock assembly? I've been meaning to make a tilting cab for years. How does the steering column get on with the tilting cab? Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 16, 2014 Share Posted September 16, 2014 Isuzu 7.5tonne trucks just have a handle on the back of the cab, as far as I can see there's no spring or assistance of any kind. Unless a c303 cab is vastly weightier than a c202 cab then it wouldn't be an issue Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 2, 2014 Author Share Posted November 2, 2014 A bit of an overdue update. Have done the following stuff: - Painted and fitted the upper cab - Started on the rewiring - Made new dash & switch panels - Constructed a battery & compressor box - Cab latch and support frame made Pics below: Cab top fitted A nice set of new wooden bump strips Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted November 2, 2014 Share Posted November 2, 2014 Maybe overdue, but proper good! Really like the 'Elegance' gearknob Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 2, 2014 Share Posted November 2, 2014 What's the MGW of a C303? Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 3, 2014 Author Share Posted November 3, 2014 What's the MGW of a C303? 3500 kg Quote Link to comment Share on other sites More sharing options...
BritanniaBoy Posted November 24, 2014 Share Posted November 24, 2014 Amazing! I'm currently planning out a very similar set-up for my 130 expedition vehicle, except using a mechanical injection pump on the engine.May I ask where you bought the 722.6 controller, and how much you paid? Will be subscribing and following this with much interest! Quote Link to comment Share on other sites More sharing options...
supaimpy Posted November 25, 2014 Share Posted November 25, 2014 For body panels look for refrigerated body builders, they can make foam insulated panels ideal for a camper , strong and light Quote Link to comment Share on other sites More sharing options...
Defender Posted November 25, 2014 Share Posted November 25, 2014 Amazing! I'm currently planning out a very similar set-up for my 130 expedition vehicle, except using a mechanical injection pump on the engine. May I ask where you bought the 722.6 controller, and how much you paid? Will be subscribing and following this with much interest! Try: http://www.dieselpumpuk.com Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 25, 2014 Author Share Posted November 25, 2014 Amazing! I'm currently planning out a very similar set-up for my 130 expedition vehicle, except using a mechanical injection pump on the engine. May I ask where you bought the 722.6 controller, and how much you paid? Will be subscribing and following this with much interest! The documentation is here https://docs.google.com/document/d/1_WiBay-rg3oWv8VhuVyUuVJ-f22PwEzD5N_LuAQHUNI/edit You need to email Ole Fejer his address is on the doc, price is around 400 Eur Quote Link to comment Share on other sites More sharing options...
chosenview Posted December 4, 2014 Share Posted December 4, 2014 Looks great I'd quite like to swap out the difflock vacuum controls, after 40 years they look a bit fragile. How have you integrated switches on your dash to the diff locks? Steve Quote Link to comment Share on other sites More sharing options...
HoSS Posted December 7, 2014 Author Share Posted December 7, 2014 Looks great I'd quite like to swap out the difflock vacuum controls, after 40 years they look a bit fragile. How have you integrated switches on your dash to the diff locks? Steve I dont quite understand. Do you mean you also have a C303 that you want to swap the controls on? Or are you recommending that i do it? I have replaced all of the vac piping and removed the orignial manual valves, replace those with a bank of 3 solenoid valves controlled by the switches. Quote Link to comment Share on other sites More sharing options...
HoSS Posted December 15, 2014 Author Share Posted December 15, 2014 The modified inlet manifold taking shape Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 15, 2014 Share Posted December 15, 2014 That's a lot of inlets....how many cylinders is it?! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 15, 2014 Share Posted December 15, 2014 It's a merc 6 pot isn't it? Quote Link to comment Share on other sites More sharing options...
94Discovery Posted December 15, 2014 Share Posted December 15, 2014 That's a lot of inlets....how many cylinders is it?! It's a merc 6 pot isn't it? Go to the first page and you will see the head with 12 holes and it is a 6 cylinders Quote Link to comment Share on other sites More sharing options...
HoSS Posted December 15, 2014 Author Share Posted December 15, 2014 Merc OM606, inline 6, 24v hence 12 ports. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 16, 2014 Share Posted December 16, 2014 Ah! Quote Link to comment Share on other sites More sharing options...
chosenview Posted January 5, 2015 Share Posted January 5, 2015 I dont quite understand. Do you mean you also have a C303 that you want to swap the controls on? Or are you recommending that i do it? I have replaced all of the vac piping and removed the orignial manual valves, replace those with a bank of 3 solenoid valves controlled by the switches. I have a c304 and wondered how you'd moved away from vacuum diff locks Are you willing to PM me details on your solution My set up is detailed here www.pearman.cc/blog Steve Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 16, 2015 Author Share Posted January 16, 2015 Why change the vaccum locks? they are reliable and we have a ready supply of vaccum and a reserve tank built in. I changed all the hoses to push fit and put 3 solenoid valves to simplify. Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 16, 2015 Author Share Posted January 16, 2015 Some updates -New inlet manifold welded Adaptor shaft from MB box to Volvo transfer box (I still need to cut down and add front oil seal race) Eberspacher installed, Nice new yacht hatch fitted Quote Link to comment Share on other sites More sharing options...
chosenview Posted January 17, 2015 Share Posted January 17, 2015 Why change the vaccum locks? they are reliable and we have a ready supply of vaccum and a reserve tank built in. I changed all the hoses to push fit and put 3 solenoid valves to simplify. Its the switches that worry me. they look very fragile with age Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 18, 2015 Author Share Posted January 18, 2015 Its the switches that worry me. they look very fragile with age Agreed, and more so all of the hose runs. I fitted 3 solenoid valves on a manifold, it simplifies it greatly. I will grab a pic later for you. Quote Link to comment Share on other sites More sharing options...
HoSS Posted January 23, 2015 Author Share Posted January 23, 2015 Pics of the vacuum solenoids Quote Link to comment Share on other sites More sharing options...
chosenview Posted January 26, 2015 Share Posted January 26, 2015 Very nice. What size hose/ports are you using? Did you make or buy the manifold? Steve Quote Link to comment Share on other sites More sharing options...
