Winch off
MogLite
Also we'll need to generate 15,000lb + of drag to give the winch something to pull against. I was originally thinking a number of vehicles chained together, however I think its going to need quite a few, especially on a sandy surface.
I don't fancy the logistics/safety of doing the pull on a slope with a number of vehicles chained together :o
Try and get hold of a bulldozer or other bit of heavy plant? Depends on the location I suppose but if its on a weekend and there's a site nearby then somebody might be persuaded to leave something parked in a convenient place for a couple of cases of beer :)
how much does a tank weigh?
i'm sure one of the military enthusiasts would drop by in a tank if you asked nicely!
Something small like a scorpion should do it.
Or how about a 7.5t truck? They weigh about 4.5t empty which isn't too far off what you want- if you got a flat bed you could put a lardy arsed land rover on the back and have an adjustable load for those winches which won't pull the full 15,000lb- ie truck plus land equals 15,000lb, truck minus landy equals 10,000lb.
The maths eludes me at the moment, but I think you are assuming lifting and pulling are the same.
Sure a loaded 7.5 tonner is a ~15,000lb lift, but you don't need anything like 15,000lb to drag it on a sandy surface.
I was assuming that you were pulling up a gradient with a high co-effiecient of friction. I hadn't actually worked out the forces but i could do i guess.
Think my tank idea was probably bettter as far as weight goes- i'll go and work out how much weight you need on sand to equal a sideways force of 10,000lb and 15,000 lb. can't be that hard to work out!
You are on the right lines there with a tank. Aloaded AVRE (DON'T HAVE A PIC AT PRESENT) weighs just short of 70 ton IIRC. The resistance on flat tarmac is about 5 ton. So that means you need a good friend with a tank that does not alot to the gallon to bring you a tank. Works out kinda expensive. Unless you can get into a mil camp somewhere and just hook up a dead tank. I'm sure there are a few dead ones about.
Scorpians' only weigh about 6 ton loaded so resistance would be negligable. 432 wieghs in at 16 ton loaded so a bit better but still not many of them about.
If you wish to buy a tank then I think Jim Marsden has 1 for sale, or he did the last time I spoke to him. Lovely runner and only 1 careful owner :)
Fine looking winch, god-like infact, much like the axle in the background. :D
Anyway twig boy, what are you doing with "heavy" porn :P
monster bit of kit fella, shame it was stood up against some scrap panzer axles - kinda ruined the pic :lol:
less of the twig boy - you're the one with the sausage dog :P
  • 3 weeks later...
Guest diesel_jim
the Spartan, which is the turret-less version of the scimitar, weighed 8153.5kg battle weight.... i remember that from my D&M course!
the Scorpion will be a bit heavier as it's got the turret.
