Anderzander Posted January 14, 2015 Share Posted January 14, 2015 I have been using one of these for quite a while to fill my Diffs and Transfer Box with oil : It's good - but must be made for a fluid of much lower viscosity, so using it can be quite a work out. So I was wondering if there was something that I could run off my compressor to do the job ? First thoughts were a shutz Waxoyl type gun - with the end nozzle replaced by the pipe and hook from my hand pump. Is there something else more suited ? Or any issues with the plan ? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 14, 2015 Share Posted January 14, 2015 Just get a metal cylinder (gas or fire extinguisher) and you can connect compressor to that, fill with oil and take the output pipe from the bottom of the cylinder. When you pressurise the oil will fly out 1 Quote Link to comment Share on other sites More sharing options...
ian_s Posted January 15, 2015 Share Posted January 15, 2015 i use an old 2 litre coke bottle with a bodged up cunningly crafted adapter for a short length of garden hose for filling my diffs. the garden hose just about fits through the fillers, and i just hold the bottle and squeeze it. it makes it fairly easy to get a measured amount in too. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 15, 2015 Share Posted January 15, 2015 I use a gear oil pump in a 25 lit drum. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2015 Author Share Posted January 15, 2015 Thanks both ... The only issues with the cylinder is getting one and setting it up ..? I've done the bottle thing before I got the pump - I kept crushing the bottle and popping the pipe off my totally bodges adaptor ! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2015 Author Share Posted January 15, 2015 I think I've seen those Mikey - are they quite expensive though ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2015 Author Share Posted January 15, 2015 Maybe something like this would be ok - swap the rigid nozzle for a pipe .... http://pages.ebay.com/link/?nav=item.view&alt=web&id=361014756179 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 15, 2015 Share Posted January 15, 2015 Maybe something like this would be ok - swap the rigid nozzle for a pipe .... http://pages.ebay.com/link/?nav=item.view&alt=web&id=361014756179 I doubt that would work very well if at all with EP90. That is trying to suck the liquid up by blowing across the top of a tube in the same way as a spray gun. Quote Link to comment Share on other sites More sharing options...
dave1607 Posted January 15, 2015 Share Posted January 15, 2015 I bought one of the 1 litre bottles of EP90, with the pullout spout, to fill my diffs and transfer box, and I just keep refilling it from 5 litre bottles. Dave Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 15, 2015 Share Posted January 15, 2015 I think I've seen those Mikey - are they quite expensive though ? I think I paid around £20 for mine, but that was a while ago. It works well with thicker gear oils, and has a nifty 90 degree elbow on the spout - ideal for side entry to a transfer or main gear box. It also has an open/shut valve. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 15, 2015 Share Posted January 15, 2015 Just get a pump up garden spray. I've been using the same one for about 20 years! Something like this - 7.50GBP delivered! http://www.ebay.co.uk/itm/BRAND-NEW-5L-LITRE-PUMP-PRESSURE-KNAPSACK-SPRAYER-SPRAY-KILL-WEEDS-INSECT-GARDEN-/111498559494?pt=UK_Home_Garden_Garden_Plants_Bird_Bath_Feeder_CV&hash=item19f5d50006 Just cut the spray nozzle off the end of the tube. Si Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2015 Author Share Posted January 15, 2015 Blimey ! Quote Link to comment Share on other sites More sharing options...
steve b Posted January 15, 2015 Share Posted January 15, 2015 A visit to your local truck breakers would give you a air receiver of a size to suit your needs , stand it up vertically , use the plug in the end at the bottom for a feed out , with a ball valve tap to turn on and off , the one in the top end as the filler and one on the side to pressurize . If you can fudge a tyre valve fitting on to pressurize, the pressure can be set with the tyre inflator . About 30-40 psi will do it . check out the ones on one of the tool supplies www's such as Clarke or Sealey for pics cheers Steveb Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 15, 2015 Share Posted January 15, 2015 Just get a pump up garden spray. I've been using the same one for about 20 years! Something like this - 7.50GBP delivered! http://www.ebay.co.uk/itm/BRAND-NEW-5L-LITRE-PUMP-PRESSURE-KNAPSACK-SPRAYER-SPRAY-KILL-WEEDS-INSECT-GARDEN-/111498559494?pt=UK_Home_Garden_Garden_Plants_Bird_Bath_Feeder_CV&hash=item19f5d50006 Just cut the spray nozzle off the end of the tube. Si Hmm, I have one of those in the car and a whole shed full of them at work. Worth a shot! Do you have to warm the oil at all? Quote Link to comment Share on other sites More sharing options...
muddy Posted January 15, 2015 Share Posted January 15, 2015 What about getting a regulator and tapping your existing setup for a air fitting, then dial the pressure right down and plug the air on when you want to fill. You could buy loads of cheap spray pump containers then and have one for each oil. Myself I have a silverline weedsprayer for ATF and a barrel pump for EP90. Will. Quote Link to comment Share on other sites More sharing options...
Hebdo Posted January 16, 2015 Share Posted January 16, 2015 I've an idea with random things I have lying about. Don't laugh, it's my first post I normally just glean information. Two tyre ( Schrader ) valves one plastic container size of your choice with a lid big enough to get your hand in. Drill hole in lid just undersized for valve, pull fit into hole. Drill another hole in the side of the container as close to the base as possible. Remove core from valve and insert into lower hole. Push on length of plastic pipe maybe bond it on. Add fluid of your choice and use any commpressor ( gently ) or foot pump. Fuel containers work well. You can get valves from any tyre place for a couple of pounds. I take no responsibility for the mess made if you over pressurise the container though. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 20, 2015 Author Share Posted January 20, 2015 Sorry for my delay in replying - thank you everyone for the ideas and suggestions. I'm going to go with the plant sprayer - because it's cheap, simple, and very portable. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 20, 2015 Share Posted January 20, 2015 I use a 5-litre plastic oil-container with the top cut off and a "water-tank connector" 1/2-inch-BSP fitting http://www.screwfix.com/p/tank-coupler-15mm/82376 screwed to a hole bored in the bottom. Attach a few feet of standard 1/2-inch garden hose to the fitting. Stuff hose-end into the gearbox/transfer-box/diff filler-hole. Hook the modified oil-container on a convenient door-mirror with a bit of wire. Pour the prescribed amount of appropriate oil into the top of the container. Go and have a coffee/beer while the oil flows into the transmission assembly. When you come back, remove the hose and refit the filler plug. Job done. Go and have another coffee/beer. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 21, 2015 Share Posted January 21, 2015 Do you have to warm the oil at all? You don't - but the delivery speed is inversely proportional to the viscosity which is of course temperature related. If you don't need it to fill quickly - then no. Si Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 21, 2015 Share Posted January 21, 2015 Garden sprayer, drilled hole, tyre valve, air line tyre inflation tool, job done. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 21, 2015 Author Share Posted January 21, 2015 What pressure do you put it at ? Quote Link to comment Share on other sites More sharing options...
zardos Posted January 21, 2015 Share Posted January 21, 2015 Garden sprayer, drilled hole, tyre valve, air line tyre inflation tool, job done. I did something similar when spraying my garden fence, the safety valve hole was the perfect for a PCL connector to screw in, Connected up airline and turned the reg down to under the rated pressure for the container so it had a constant air supply. It sprayed the fence in no time with no hard graft of pumping it up every few minutes :-) Quote Link to comment Share on other sites More sharing options...
zim Posted January 22, 2015 Share Posted January 22, 2015 We use old pumps like these : G Quote Link to comment Share on other sites More sharing options...
