90 brake upgrade
my '89 110 runs vented front disc/calipers with 46mm pistons.
vented disc are FTC902 http://www.lrseries.com/shop/product/listing/7183/FTC902-BRAKE-DISC-FRONT-VENTED.html?search=FTC902&page=1
Caliper for vented front disc are
STC1266 rh http://www.lrseries.com/shop/product/listing/11670/SEB500460-BRAKE-CALIPER-FRONT-RH.html?search=STC1266&page=1
STC1267 lh http://www.lrseries.com/shop/product/listing/11672/SEB500470-BRAKE-CALIPER-FRONT-LH.html?search=stc1267&page=1
from 1991 the number of brake parts was rationalised across the 90/110 range. the above parts should fit your existing axle.
I would just fit 300tdi axles front and rear anyway, they are so cheap these days it's daft not to (I skipped two pairs recently as sick of them in the way). 24 spline diffs and shafts and parts are a lot cheaper for them than the earlier axles.
You should have said something I,d have had them...
Except that are not as good. Weaker half shafts, weaker CV joints, weaker hub bearings, wealer drive flanges. The newer axles are downgrade.
Later brakes fit on earlier axles.
  • Like 1
They will bolt up, but the bolts should be a tight fit at the shoulder in the axle/calipers (I forget which way LR ones bolt up!)
If you have wrong bolts they rely on friction of the clamping forces rather the locating nature of the good fit of the bolt.
Early 110s are indeed metric. Ron, my note regarding imperial and metric is derived from experience when I fitted an relatively early imperial RR rear axle to my 90. The caliper bolt pitch is the same but the thread and the bolt shoulder size is different. I think it changed from imperial to metric around about '79/'80 so all 90/110 will be metric.
Mo
