ianmayco68 Posted November 17, 2015 Share Posted November 17, 2015 Hi all, on my rebuild project I'm planning on upgrading the turbo to either a hybrid or vnt unit, and while browsing ebay I came across these for sale from a firm called Turbo Rebuild LTD in lancs ( link below). There listed as a UPGRADED STAGE 1 HYBRID TURBO CHRA CARTRIDGE KIT FOR A DEFENDER OR DISCOVERY 200 TDI at £225 which is a lot cheaper than the full upgrade units. Is this a purchase that the more experienced members on here would recommend or would the advice be to leave this sort of job to the turbo experts ? Or has anyone on here done this upgrade on there own turbo and could offer any advise ? cheers all Ian http://www.ebay.co.uk/itm/Uprated-Hybrid-ST1-Turbo-CHRA-465171-465175-Land-Rover-Defender-Discovery-200tdi-/321875737193?hash=item4af149fa69:g:eKIAAOSw9r1WBTKZ Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 17, 2015 Share Posted November 17, 2015 A fully built up cartridge like that should always be good from the suppliers and suitable for a straight fit by any competent mechanic. The ones to avoid are the kits of bits that need to be built up. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 17, 2015 Share Posted November 17, 2015 That is fine. Note that the upgraded parts are the bearing and seals, not the turbo itself. Standard bearings and seals should be fine for most people. It is not too hard to install a cartridge. What is your reason for changing? If you just have a bad bearing or seal, they are easy enough to change. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 17, 2015 Share Posted November 17, 2015 What's hybrid about it then, if all is got are better seals and bearings ? Mo Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 17, 2015 Share Posted November 17, 2015 I was wondering this ^^^ its not VNT or anything special in that sense. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 17, 2015 Share Posted November 17, 2015 I've just looked at it again, i reckon that's a 300 turbo casing not a 200, it has the much improved two bolt flange fixing for the oil drain. It might simply be a library photo Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted November 17, 2015 Share Posted November 17, 2015 ive seen there pop on fb recently. http://www.ebay.co.uk/itm/LANDROVER-DISCOVERY-200TDi-T28-HYBRID-TURBO/171994757596?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D1e5d1c0b7064413b821dff1e0ed2582a%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D181681006599 i think if they havnt already have them for sale for defender, they will soon be, buy many options for turbo upgade, weather 360 bearings or ball bearings for quick spool, different turbines etc then vvt/vnt but there still £1100.... many other vnts fit but controling them reliably without it surging/over boosting is the issue. Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 17, 2015 Share Posted November 17, 2015 My understanding is that a hybrid turbo consists of a different set of either compressor or turbine wheels, set up to alter the maximum flow and spool up characteristics from the standard "ok for everything not perfect for anything" turbo. There are a few different ones out there so research is a must! Quote Link to comment Share on other sites More sharing options...
Jon W Posted November 17, 2015 Share Posted November 17, 2015 Noticed these on facebook the other day, not looked into what is uprated or hybrid about them but seemed reasonable https://www.facebook.com/NKK-Turbos-Ltd-662011710528814/?fref=ts if the link doesn't work have a look for NKK turbos Newark upon Trent Nottingham Quote Link to comment Share on other sites More sharing options...
cackshifter Posted November 18, 2015 Share Posted November 18, 2015 I emailed turborebuild a few months back re 300tdis, their hybrid is a different (and lighter) compressor wheel which they reckoned would give a faster spool up and more boost lower down. I tried to contact NKK but got no response. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted November 19, 2015 Author Share Posted November 19, 2015 Cheers all, contacted them and think Red90 is right its not a hybrid its just got uprated bearings and seals . But contacted NKK via there web page and got a response they sell an uprated T28 core modified cold side housing and uprated actuator for a 200 tdi that you can bolt on yourself for £380 which is reasonable so gonna look into that cheers Ian Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 19, 2015 Share Posted November 19, 2015 Keep us up to date with how you get on with it Ian. I'm curious to see what difference it will make. Mo Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted November 19, 2015 Author Share Posted November 19, 2015 Will do Mo, will be a while tho have just finished the chassis and rear axle and am putting the front axle and suspension back on this weekend. Will post some pics up then, cheers Ian Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 19, 2015 Share Posted November 19, 2015 looks promising. I would like the VNT from allisport too but I think the wife would kill me. Quote Link to comment Share on other sites More sharing options...
