DC_ Posted August 1, 2020 Share Posted August 1, 2020 Hi guys, just returned from my second camp to find the steering box is weeping at the bottom seal. What’s your thoughts? Easy enough to repair the seal or better to go for a good known box Replacement? 👍 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 1, 2020 Share Posted August 1, 2020 According to one LR manual the 6-bolt is the heavy duty box, hence why I'm retaining mine on the 127. Not sure what the difference is, and would quite like to know. Not sure what the insurance would make of fitting a different non-heavy duty one Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted August 1, 2020 Share Posted August 1, 2020 if you can find a puller for the drop arm => try to repair Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 1, 2020 Author Share Posted August 1, 2020 I’ll do a bit more research, it’s only a slight weep right now. Am I correct in thinking it’s an O ring failure? Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 1, 2020 Share Posted August 1, 2020 Most people suggest the leak is wear on the shaft around the seal, so new seals rarely seem to provide a solution. Try it if you can get the arm off, but it may not work. I think Zeus used to sell a seal that sits on a different part of the shaft - I dont know if they still do or it the one they had fits the Gemmer box. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted August 2, 2020 Share Posted August 2, 2020 18 hours ago, FridgeFreezer said: According to one LR manual the 6-bolt is the heavy duty box, hence why I'm retaining mine on the 127. Not sure what the difference is, and would quite like to know. Not sure what the insurance would make of fitting a different non-heavy duty one The 3 bolt Adwest box is the one listed as "Heavyweight". Then the Adwest 4 bolt as "lightweight" and the six bolt is just a Gemmer. My practical experience of all the boxes would indicate little difference other than the six bolt Gemmer is less prone to leaking. 12 hours ago, reb78 said: Most people suggest the leak is wear on the shaft around the seal, so new seals rarely seem to provide a solution. Try it if you can get the arm off, but it may not work. I think Zeus used to sell a seal that sits on a different part of the shaft - I dont know if they still do or it the one they had fits the Gemmer box. This. A proper box overhaul includes the worn area of the sector shaft being metal sprayed and reground, fitting a seal kit alone rarely works for long. That's why recon boxes have a poor reputation. There are companies out there that do a proper job, but they'll be more expensive than the "fit a seal kit and paint it" ones on ebay. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted August 2, 2020 Share Posted August 2, 2020 Have used these guys recently if you decide to have repaired/replaced - proper specialists, very good standard of work & service: https://www.dasteeringltd.co.uk Quote Link to comment Share on other sites More sharing options...
pat_pending Posted August 2, 2020 Share Posted August 2, 2020 To illustrate the point, this is the area of the sector shaft that the seal runs on. Shaft is from my old six bolt box. Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 2, 2020 Author Share Posted August 2, 2020 Thanks for the responses guys. I may try the seal to start with to see the outcome. If it goes again, then I’ll look into a proper refurbished box. It’s bone dry everywhere else and has been good in the years I’ve had the truck. Don't suppose there’s a good write up in the tech archives? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 2, 2020 Share Posted August 2, 2020 Is it possible to get a speedisleeve on there I wonder? Quote Link to comment Share on other sites More sharing options...
pat_pending Posted August 3, 2020 Share Posted August 3, 2020 (edited) 19 hours ago, cackshifter said: Is it possible to get a speedisleeve on there I wonder? Yes and no. I did it on my mine but it didn't last. The problem is the sector shaft is hung on a bearing in the top cap, when you adjust the box you're pulling the shaft/gear upwards and deeper into mesh. I struggled find a position for the sleeve that still allowed some movement on the shaft. It was also awkward to peel off the flare at the base of the sleeve (needs to come off or it fouls the seal pack) and that was with the box on the bench. I thought I posted up some pictures when I did it. After it leaked again I fitted a proper recon Adwest 4 bolt, as I wanted to fit a Disco drop arm at some point to do away with that stupid ball joint. Edit to add, yes I did post when I did it, April 2015. No useful pics though. My repair lasted a few thousand miles before a drip appeared. That's when the four bolt went in, still dry 5 years later. Edited August 3, 2020 by pat_pending Update Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 4, 2020 Share Posted August 4, 2020 Got a good working 6 bolt box. PM me if you're interested. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 4, 2020 Share Posted August 4, 2020 On 8/1/2020 at 4:23 PM, FridgeFreezer said: According to one LR manual the 6-bolt is the heavy duty box, hence why I'm retaining mine on the 127. Not sure what the difference is, and would quite like to know. Not sure what the insurance would make of fitting a different non-heavy duty one I think it gets worse than that - I've come across a 6 bolt and a HD 6 bolt. I think most Stage 1s / 6 cylinder ones had the HD version fitted. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 4, 2020 Share Posted August 4, 2020 8 hours ago, kevin50 said: Got a good working 6 bolt box. PM me if you're interested. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 4, 2020 Share Posted August 4, 2020 5 hours ago, Ed Poore said: I think it gets worse than that - I've come across a 6 bolt and a HD 6 bolt. I think most Stage 1s / 6 cylinder ones had the HD version fitted. Didn't think Stage 1's or any Series ever had PAS from the factory Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 4, 2020 Share Posted August 4, 2020 Maybe it was just the Sandringham's that had it fitted as standard then. Quote Link to comment Share on other sites More sharing options...
