Hi, I'm a new member
Francis
Hi everyone. I'm Francis and I just joined yesterday. Looking forward to learning loads from you all, and having good chats about our beloved Landies!
I have a 1984 110 County 3.5L V8, which I bought in Crawley last year for 485 squids. 440 more squids brought him up to roadworthyness and got the mot passed.
A deal eh?
Hi Francis.
Don't know what your plans are with the 110, but there are some great off-road sites near you, if you fancy seeing just how good the 110 really is.
What do you use him for?
Going to any shows / events this year?
Guest diesel_jim
I've got a 110 also! mine is also broken! (the end of the intercooler has split open..... sounds funny when you put your foot down, just like a 110" air compressor! :rolleyes: )
Well, only passed it's mot last week so not had a chance to do anything in it yet. It's been 'sitting' at a friend's workshop for several months, and prior to that, hadn't done anything since 2003 when it was last taxed!
I plan to use him for off road adventures and as my main and only drive. So, I will be looking for an LPG kit soon. And Si, I will have to pick your brain no doubt.
My first jobs are to get it tidied up around the windscreen where there is some rust, and of course the door frames could use a look at at the bottoms, and I will be repainting him gloss black, also looking for some black or alloy wheels to replace the original landie wheels.
Only just made it roadworthy last week. It's taken that long! I will use it off road, of course! I want to paint it black, change the wheels over for some alloys or something cool looking, and of course get a roll cage, upgrade the interior, sort out the door frame bottoms as they are a tad rusty, but not terrible, sort out the window frame at the bottom corners where it has rusted through and some numbnut has 'fillered' it!
I will most certainly be taking it out for mud runs! I heard that these V8s are 'restricted' and can be 'unrestricted'. Difference of about 30hp. Right or wrong?
Not sure about restriction, I know the LR versions are lower BHP but that could be down to compression ratio. IMHO it may pay you to get a flapper EFi setup for a few quid and bolt it on, that will gain you ~30bhp off the bat. Either that or a complete running 3.5/3.9 EFi from a RR. Is it too early to mention MegaSquirt? :lol:
Welcome Francis,
I met a bloke with an early 110"V8 in the eighties and he told me that LR had fitted restrictor plates under the carburetors which he had removed - could this be what you heard about? I'm sure that someone on here will know the answer :D
Rog
I'm a diesel geek pure and simple, so feel free to correct me, but i thought that low-compression engines were only fitted to vehicles destined for foreign markets with a variable quality of fuel. The 3.9 in the 110 is from a saudi spec RRC IIRC and is low-comp, as were the 4.0l's fiited to the 2003 G4 disco 2's, you can tell from the engine number - but i dunno how, i'm sure a real adult will be along shortly to put me straight
Lewis
Welcome Francis....
Sounds like a bargain as others have said.... But now you are on that journey of eternal expenditure, upgrades, must haves and endless hours of "tinkering"
Loads of people in here will show you how to spend thousands on the car so beware... :)
Engine numbers:
[b]Saloon 3.5 Litre[/b]  	Model  	Year
42500001A 	P6 3500 Auto 10.5:1 CR 	1967-76
45100001A 	P6 3500 Auto 10.5:1 CR 	1967-76
45500001a 	P6 3500 Auto 10.5:1 CR 	1967-76
42700001A 	P6 3500 Auto 8.5:1 CR 	1967-76
43500001A 	P6 3500 Auto 8.5:1 CR 	1967-76
43000001A 	P6 3500S Auto 10.5:1 CR 	1967-76
43200001A 	P6 3500S Auto 8.5:1 CR 	1967-76
46600001A 	P6 3500S Auto USA 	1967-76
48100001A 	P6 3500S manual 10.5:1 CR 	1967-76
48500001A 	P6 3500S manual 10.5:1 CR 	1967-76
10A00001A 	SD1 manual 9.35:1 CR 	1976-87
11A00001A 	SD1 Auto 9.35:1 CR 	1979-80
12A00001A 	SD1 man. 8.13:1 CR USA efi 	1979-80
13A00001A 	SD1 Auto. 8.13:1 CR USA efi 	1979-80
14A00001A 	SD1 Auto 8.13:1 CR Sweden 	1976-87
15A00001A 	SD1 Auto 8.13:1CR Australia 	1976-87
16A00001A 	SD1 Auto 8.13:1CR  Japan 	1976-87
17A00001A 	SD1 V8S man 9.35:1 CR 	1979-80 (VDP 1981 on)
18A00001A 	SD1 V8S Auto 9.35:1 CR 	1979-80 (VDP 1981 on)
19A00001A 	SD1 Man 8.13:1 cr Australia 	1976 onwards
20A00001A 	SD1 Australia 8.13:1 cr efi 	1982 onwards
21A00001A 	SD1 Australia 8.13:1 cr efi 	1982 -87
23A00001A 	SD1 Man 8.13:1 cr SE/VDP 	1982 -7
24A00001A 	SD1 Man AC 8.13:1crSE/VD 	1982 -87
25A00001A 	SD1Man 8.13:1 cr SE/VDP 	1982 -87
26A00001A 	SD1Auto 8.13:1 cr SE/VDP 	1982 -87
27A00001A 	SD1 Man AC 8.13:1cr SE 	1982 –87 hot climate
28A00001A 	SD1 Auto AC 8.13:1cr SE 	1982 –87 hot climate
30A00001A 	SD1 Vitesse Man 9.75:1cr 	1982-87
31A00001A 	SD1 efi Auto 9.75:1cr 	1982-87
32A00001A 	SD1Vitesse Man AC 9.75:1cr 	1982-87
33A00001A 	SD1 Auto AC 9.75:1cr 	1982 –87
34A00001A 	SD1 Switzerland 9.35:1 cr 	1982-87
36A00001A 	SD1 Switzerland 9.35:1 cr 	1982-87
38A00001A 	SD1 Factory recon 9.35:1 cr 	1982-87
39A00001A 	SD1 Factory recon 9.35:1 cr 	1982-87
[b]Range Rover 3.5 Litre 	  	 [/b]
35500001C,D,E 	R.R Carb 8.25:1 cr 	1970-83
35500001F 	R.R Carb 8.13:1 cr 	1970-83
34100001 	R.R Carb 8.25:1 cr 	1970-83
35900001A 	R.R Carb  CDK 8.25:1 cr 	1970-83
39800001A 	R.R Carb 8 Australia.13:1 cr 	1970-83
11D00001A 	R.R Carb pulsair 9.35:1cr 	1970-83
13D00001A/B 	R.R Carb Auto 8.13:1 cr 	1981-85
15D00001A/B 	R.R CarbpulsairAuto 9.35:1cr 	1981-85
16D00001A/B 	R.R CarbpulsairAuto 9.35:1cr 	1983-85
17D00001A/B 	R.R CarbpulsairMan 9.35:1cr 	1983-85
18D00001A/B 	R.R Carb  Man 8.13:1 cr 	1983-85
19D0000!A/B 	R.R CarbpulsairMan 9.35:1cr 	1983-85
20D00001B 	R.R CarbpulsairMan 8.13:1cr 	1983-85
21D00001B 	R.R Carbpulsairauto 8.13:1cr 	1983-85
22D00001 	R.R Disc efi Man 8.13:1cr 	1986 onwards
23D00001 	R.R Disc efi Auto 8.13:1cr 	1986 onwards
24D00001 	R.R Disc efi Man 9.35:1cr 	1986 onwards
25D00001A 	R.R  efi Auto 9.35:1 cr 	1986 onwards
26D00001A 	R.R Carb Man 9.35:1Cr 	1986 Onwards
27D00001A 	R.R efi Auto 8.13:1Cr 	1986 Onwards
28D00001 	R:R Carb Man 8.13:1 cr 	1986 onwards
29D00001A 	R:R Carb Auto 8.13:1 cr 	1986 onwards
30D00001 	R:R Carb Man 8.13:1 cr 	1986 onwards
31D00001 	R.R efi 8.13:1 cr 	1986 onwards
[b]Factory 3.9 Litre Engines 	  	 [/b]
35D00001 	R.R Disc efi Man 9.35:1cr 	1988 onwards
36D00001 	R.R Disc efi Auto 9.35:1cr 	1988 onwards
37D00001 	R.R Disc efi Man 8.13:1cr 	1988 onwards
38D00001 	R.R Disc efi Auto 8.13:1cr 	1988 onwards
[b]Factory 4.2 Litre Engines 	  	 [/b]
40D00001 	R.R  4.2 efi 8.94:1cr 	1992 onwards
[b]Factory 4.0 Litre Engines 	  	 [/b]
42D 	R.R  efi 9.34:1 efi 	1994 onwards
[b]Factory 4.6 Litre Engines 	  	 [/b]
46D 	New R.R  4.6 efi 9.34:1 cr 	1994 onwards
48D 	New R.R 4.6 efi 8.12.1 cr 	1994 onwards
