Glue/epoxy/sticky stuff - magnetic drain plugs
In my knutian task of preventing wear in my overdrive, I'm going to adapt the drain plugs by adding magnets.
What's a good adhesive to use?
Yes, that's my worry. I'll recess the magnet into the plug, but I want to coat the thing in something as well, so that the chrome plating on the magnet doesn't delaminate.
I used little magnets with a countersunk hole in the middle, drill & tap M3/M4 and loctite a little screw in as well as loctiting the magnet into the recessed hole.
Just be aware that adhesives/sealants that tolerate oil are not necessarily the same as ones that will actually live submerged in oil.
  • Like 3
30 minutes ago, Gazzar said:
Nice idea! Or I could peen the recess. Thanks.
Yep, drill it slightly too deep and just centre-punch the edge a couple of times.
On the plus side, a magnet stuck in a hole in a lump of steel will mostly try quit hard to stay in there.
  • Like 1
JB weld
Regards Stephen
  • Like 1
  • Thanks 1
3 hours ago, Stellaghost said:
JB weld
Regards Stephen
Beat me to it.  Great stuff.  Just make sure the hollow of the plug is incredibly clean first.  In fact, it may be better to machine a hollow for the magnet to sit in the outside of the plug under a retaining lip that would prevent it from being drawn up into the box if the epoxy should fail.  Belt and braces.
  • Like 1
1 hour ago, hurbie said:
or just visit your local MAN truck dealer and buy a axle drain plug with the magnet installed 😉  (there the same thread as far as i can see)
Or hydraulics shop.
  • Like 1
Having tried glue once upon a time - and regretted it, Fridge's suggestion is the best option!
  • Like 1
