mad_pete Posted June 1 Share Posted June 1 What’s the latest technology (lol) in the area of Rover V8 sump gaskets ? 1994 4.2 rover V8 non serp. Cork gasket and be careful not to over tighten ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 1 Share Posted June 1 RTV. 1 Quote Link to comment Share on other sites More sharing options...
muddy Posted June 2 Share Posted June 2 Elring Dirko is a nice RTV. 2 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted June 2 Share Posted June 2 What Land rover use: I have good experience with this one: https://www.ebay.co.uk/itm/184293788834?itmmeta=01HZDBQJ4AQTRQ7S58M3EGJA3E&hash=item2ae8c40ca2:g:XToAAOSwj4VdcAOd&itmprp=enc%3AAQAJAAAA4K9oORdLHQKEQYk%2Bik87PuzUPojCirElB4haC4t%2FjWMRo5gz%2B%2FY40ihc5c%2BL1tz--zyLRQ1Fz%2Fe6Az1efuDEv65CLy0n9lJkkATFBUEeiF74XktV1AZAPQOzY%2FZbDv4Dqdw1c1rX%2BvH2a9kU5K7mlmfu3BHF1VK0nXL%2Ff2FOJYPr1LiSAytDpeI0tz%2FkJf4gpfa6YHWZuHXLZxePQPIBJP7g%2FRCffmK3RHFOF4ffkgMAqYG%2F9wLY5ZdYFti5bn2uVfhWfvO2lxnvrZ9%2B%2BRSQcPJ%2BAgI6jiCgy%2FRe0GgCErYq|tkp%3ABk9SR6Si3qv7Yw It essentially is a rubbery glue that sticks the sump to the block. It is a bit hard to remove when you drop the sump again, but it forms a reliable seal. Daan 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 2 Share Posted June 2 Loctite SI 5980 1 Quote Link to comment Share on other sites More sharing options...
smallfry Posted June 2 Share Posted June 2 Cork and rubber gaskets leak in the long term, also the sump flange needs to be perfect, and need to be tweaked up bit by bit, and not overtightened. RTV far better. Clean and degrease both surfaces, along with all the bolts, and it will not leak. I hate oil dripping engines. I use red HTR 430 1 Quote Link to comment Share on other sites More sharing options...
fmmv Posted June 3 Share Posted June 3 But don't use more Rtv than you have to, I think LR say a 2 mm bead, it squeezes out and blocks the strainer. I let it go off for a bit before tightening beyond finger tight. 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted June 3 Share Posted June 3 I use Elring Dirko on sumps and anything not fuel related at work, very nice stuff Quote Link to comment Share on other sites More sharing options...
mad_pete Posted June 6 Author Share Posted June 6 So how much CPU thermal paste, sorry I mean RTV is exactly the right amount ? Internet as usual seems to have varying views with the joyful rtv broke off got stuck the oil feed and wrecked the engine stories to help raise the stakes. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 6 Share Posted June 6 I generally do enough to be spread evenly across the mating face with a finger - as in, thick enough that the whole mating face is covered but no more. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 6 Share Posted June 6 Enough where you can't see through it when spread, and some slightly larger gobs in sharp corners/around seals. 1 1 Quote Link to comment Share on other sites More sharing options...
mad_pete Posted August 29 Author Share Posted August 29 So I took it to a garage looks like they used cork gasket and sealant and maybe overtightened a touch. Still it’s not leaking so that’s a win. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 29 Share Posted August 29 30 minutes ago, mad_pete said: maybe overtightened a touch From the last 2 pics they overtightened it a lot - if bits of gasket are falling out the sides I'd worry about what's going to fall inside the sump 2 Quote Link to comment Share on other sites More sharing options...
mad_pete Posted August 29 Author Share Posted August 29 I’ve emailed them. I’ll see what they say. 1 Quote Link to comment Share on other sites More sharing options...
smallfry Posted August 31 Share Posted August 31 Thats disgusting. Sadly so typical of a professional job though. Looks like RTV on top a cork gasket. WTF ? 1 Quote Link to comment Share on other sites More sharing options...
joe1 Posted September 2 Share Posted September 2 Re makes of rtv - choose one that goes off reasonably quickly if it's going on thick (I was filling up the T seal channels in the 300tdi rear mains) ....I used an unnamed brand from an order with Island4x4 recently.....and it took over a day to harden .....not much good if you need oil in the sump the same day !&!&!😀 Quote Link to comment Share on other sites More sharing options...
mad_pete Posted September 2 Author Share Posted September 2 So I sent the photos to them and they didn’t really answer but the question becomes what do I want. Should I ask for it to be re done ? Not sure what else to say. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 2 Share Posted September 2 44 minutes ago, mad_pete said: So I sent the photos to them and they didn’t really answer but the question becomes what do I want. Should I ask for it to be re done ? Not sure what else to say. TBH if it's not leaking I'd probably leave it as not being worth the hassle... if it does leak again I'd be strongly inclined to DIY it with some decent sealant having given it a good clean up first. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted September 7 Share Posted September 7 I could be wrong. It’s been known before 🙄but I’m sure the gasket on my 4.0 Thor was a rubber one and not cork. It’s the only Landrover I’ve ever had that refuses to leak oil and yes, there is oil in it…🤷♂️ I should return it and get my money back 🤣 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 9 Share Posted September 9 On 9/7/2024 at 7:05 PM, Bigj66 said: I could be wrong. It’s been known before 🙄but I’m sure the gasket on my 4.0 Thor was a rubber one and not cork. Yes there were rubber ones, I suspect for the cast alloy sumps although I don't know for sure. Quote Link to comment Share on other sites More sharing options...
Escape Posted September 10 Share Posted September 10 Only the last V8s, with the Bosch EFI and alloy sump that bolts to the bellhousing, use a rubber gasket, LVF100400. It wont fit any of the older engines. I tried to adapt it when working on my first V8 but quickly gave up and used RTV instead. 1 Quote Link to comment Share on other sites More sharing options...
