Orgasmic Farmer Posted May 10, 2007 Share Posted May 10, 2007 and its comes in at 35 kgs :o add 30kg for the 8273 and then something for rope and hook and it adds up to about 70 kilos up front. Guessing thats about 60 more than standard set up!. Out of interest how does the wieght of my (over engineered?) bumper compared to marketed versions out there. No idea if its really that heavy (certainly feels that way!) Pics next time I take the camera down the shed Quote Link to comment Share on other sites More sharing options...
nige90 Posted May 10, 2007 Share Posted May 10, 2007 No idea what a marketed one weighs but I do know I nearly popped a pod when I took my home made one off with the winch still attached. I'd guess similar to yours though. Got my mate round when it came to refitting. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted May 11, 2007 Share Posted May 11, 2007 my guardian winch bumper is about 25 - 30kg Quote Link to comment Share on other sites More sharing options...
Mark90 Posted May 11, 2007 Share Posted May 11, 2007 Pah, that's nowt my over engineered bumper weighs 50kg Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 11, 2007 Share Posted May 11, 2007 Pah, that's nowt my over engineered bumper weighs 50kg Kin Hell Mark.... Does that thing actaully have capablities of walking on its own ? Looks like something from Terminator 3 Nice work though.............. Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted May 11, 2007 Share Posted May 11, 2007 Not my work. It was on the 90 when I bougt it off Ripley/Graham. It's held on with 10 M10/M12 bolts, that's just to make sure it doesn't fall off Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 11, 2007 Share Posted May 11, 2007 that looks heavier than mine FFS!!!!!!!!!! and mine is errrrrr well over engineered internally, and held on with 8 M12 bolts Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 11, 2007 Share Posted May 11, 2007 add 30kg for the 8273 and then something for rope and hook and it adds up to about 70 kilos up front. Sorry to add to your weight, but a bare 8274 without motor, wire and fairlead weighs just over 35kg. The kind people at the BA check-in desk weighed it for me. Cheers Steve Quote Link to comment Share on other sites More sharing options...
jameslwt Posted May 11, 2007 Share Posted May 11, 2007 Sorry to add to your weight, but a bare 8274 without motor, wire and fairlead weighs just over 35kg. The kind people at the BA check-in desk weighed it for me. Cheers Steve No idea how accurate the scales were, but the h14, inc wire rope (174ft, 10mm), and bumper came in at 110kgs! Moose and myself could barely lift the thing - puit it on with an engine crane in the end! Hence why in the superwinch manual they say you have to fit the HD springs at the front! Quote Link to comment Share on other sites More sharing options...
DefcoL Posted May 11, 2007 Share Posted May 11, 2007 Sorry to add to your weight, but a bare 8274 without motor, wire and fairlead weighs just over 35kg. The kind people at the BA check-in desk weighed it for me. Cheers Steve Hi mark I got this from the web so that I knew what mine weighed, should be similar to yours. BTW have you posted any recent pics as the last I saw you had just parked in ya field with large boots M8274-50 SPECS/PART NUMBERS Part Numbers: PN 38631 CE (12V DC) , PN 375832 CE (24V DC) Rated Line Pull: 8000 lbs. (3630 kgs.) single-line Motor: 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw, Series WoundTM Remote Control: Remote switch, 12' (3.7m) lead Geartrain: Spur Gear Gear Ratio: 134:1 Lubrication: 6 oz. SAE 30 (non-detergent) Clutch (freespooling): Sliding Motor Pinion Gear Brake: Automatic, disc type Drum Diameter/Length: 3.5"/8.5" (9cm/22cm) Weight: 110 lbs. (50 kgs.) Wire Rope: 150', 5/16" diameter (46m, 8mm diam.) Fairlead: Roller Recommended Battery: 650 CCA for winching Battery Leads: 2 gauge, 72" (1.83m) Finish: Argent Gray Powder Coat with Clear Coat Nuts: PN 7616, L/W: PN 2146 Bolts: PN 7165 Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted May 11, 2007 Author Share Posted May 11, 2007 I'll have to weigh the winch again. Maybe the bathroom scales were not accurate (I hope not or I am even more of a Lardy than I thought!). Pics? Nah Its such a mess in there at the mo with the dash out and front inner wings cut about. Maybe later. There are some newer ones on difflock if you're interested (but you may have seen them already). M Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted May 11, 2007 Share Posted May 11, 2007 8274 with wire cable is 56kgs IIRC Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted May 11, 2007 Author Share Posted May 11, 2007 Just wieghed it again this evening (and scales are acurate to within a few kgs max) and my 8274, minus wire, is only 30kgs. Includes motor and solenoids. Perhaps it needs some oil in it Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 12, 2007 Share Posted May 12, 2007 8274 with wire cable is 56kgs IIRC And an EP9 with cable and rollers is 50kg What is your bumper made of to be soo heavy Mine is made from lightweight 6mm so only 25kg Quote Link to comment Share on other sites More sharing options...
madmatt Posted May 12, 2007 Share Posted May 12, 2007 Just ordered an off the shelf bumper for the MM and the bumper is 30kgs. You need to be carefull with H14 winches as when the vehicle is loaded and you have a full compliment of bodies in a defender you can quite easily be over the front axle weight!!! We know this from experiance at work. lol Quote Link to comment Share on other sites More sharing options...
will_warne Posted May 12, 2007 Share Posted May 12, 2007 Just to make you feel good, Organsmic. My ARB bumper weighted in at twice yours I guess the new one will be 40-50 kgs with bull bars. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted May 18, 2007 Share Posted May 18, 2007 Kin Hell Mark....Does that thing actaully have capablities of walking on its own ? Looks like something from Terminator 3 I reckon he's building a transformer... Quote Link to comment Share on other sites More sharing options...
