Good-Bad
Hi,
This weekend I intend to change the springs & shocks on the 110, the reason being they have never been changed (to my knowledge) I get a fair bit of roll when cornering especially when loaded up with all the camping gear, the back have been done so I'm putting the roll down to the front springs!
What do you think about the condition of these:
I think they are worn? But to be honest I haven't got anything to compare them to!
What do the experts think?
Cheers Ted
Expert? Me? :unsure:
No, but they look perfectly allright for being standard springs. I had the same thoughts as you some years ago, so I bought a new set of springs. The result was exactly the same as before. :huh:
After having put on a winch and bumper, I changed to HD springs which totally transformed the driving, especially on bad roads. Much better and exact steering was the immediate result without the springs being too stiff.
They don't look like progressive springs to me, they look like totally f***ed standard springs. If that's the case then yes change them out.
If they haven't been changed from new expect to have fun getting nuts of shocks etc and for shock turrets and retainers to fall apart when you take them off. So in preparation it pays to get new shocks, new turrets and new retaining rings before you start. You may find your axle spring mounts are not in good shape too, but you may be ok.
Cheers
Steve
Go for OME replacements which you will be able to pick up locally.
I have their 500kg rated on the rear of my 110 plus their standard shocks.
A good ride even when empty (c2600kg) and no roll of any concern even when fully laden.
Same setup on the front but not so heavy duty rating but enough for a substantial winch.
Been on for 3 years and very pleased.
John
I beg to differ with most of you, :lol: that is a perfectly normal original front 110 spring. They ARE progressive and they DO close up the lower coils at ride height.
NRC 8044 on one side with 2 white stripes, NRC 8045 on the other with 2 yellow stripes.
Genuine springs are very good and last a long time, They are only knackered if the clearance between the bumpstop and axle has significantly reduced over standard. Can't remember what the standard bumpstop gap is off the top of my head, but I think it is between 50 and 75mm.
If you buy standard replacements from a cheap supplier rather than genuine, you can expect the front of the vehicle to be lower than on your original springs after about 6 months!
Regards,
Diff
I know the lower coils close up at ride height but there not supposed to be jammed hard together? Otherwise those particular coils are doing nothing at all....
Yes, they do go 'coil bound' and is normal for this type. The idea is that the lower rate coils operate when the vehicle is articulating, not in bump. This allows the vehicle to have a relatively stiff suspension at sensible ride height, but still be able to articulate well.
I agree, most progressive 'car' springs are not designed to go coil bound at ride height/weight, but these are are Land Rover springs, designed for a different purpose.
Regards,
Diff
Regards,
Diff
Indeed, well balanced progressive springs can be very usefull for an offroader.
Hi,
Cheers Ted
Compared to mine (new and original) they look worn out. The upper coils don´t touch each other that much.
ive just put a 2inch heavy duty lift on which has actualy given me 3 to 4 inches of lift somehow,but the ride is stunning i really recomend it,handles well and it doesnt bang over the bumps..for 200quid you cant go wrong,im using britpart and pro comp,just be warned the fronts are an absolute pig,grind the nuts on the top and either use stilsons or drill out the nut on the bottom,i heated the lower nut and then drilled a small whole then a large right through and the nut came off
I know what you mean mate ^^^^^^ i seem to have had the same type of kit using brit part and pro comp and got more lift than it said on the tin and as you say handles well on road and off to tell ya the truth
First thing..... Measure the height of each spring and post here. Do you want the front higher than it is now?
Those are normal 110 springs, http://members.shaw.ca/red90/NRC8044_5.html and look normal. If you want a bit of lift, fit regular 90 rear springs to the front. They are the "normal" 110 HD front springs. One assumes you can get some for free. If you don't like free, then there are many choices for aftermarket, but it depends if you want any lift or not and you current weight.
Guest diesel_jim
FWIW, i was down at Dunsfold LR yesterday picking up some brand new take off 110 rear springs and shocks i'd won on ebay (the puprple striped HD springs).
chap said to me "how many do you want? we've got a whole pallet load!"
so if you want some cheap new rear ones, genuine parts, that could be the place to head to.
<snip>
and bump stop measurements when parked on a level bit of concrete while you are at it. ;)
something to ponder about when replacing your springs, is the final ride height.
1. do you have a winch / bull bar on the front? these fellas are really heavy stuff and you don't want you truck looking like it has tired springs even after changing them. besides a truck with the back end sticking up too much is not my cuppa tea.
2. do you have to get the truck into a gararge? or do you visit a lot of multi story car parks? i've scrapped my roof far too many times even when the height limit says so otherwise.
3. higher, might not always mean better as no doubt you can fit taller tyres, but bear in mind you shift the CG of the vehicle, you need custom props, trailing and radius arms on anything more than a 2" lift and even with that, your axle case will still scrape as they aren't that high up then they were initially unless you decide to junk them for portal axles too.
Yeah sorry!
The 110 isn't on flat concrete at the moment but on fairly level ground, and the measurements are
P/side 65mm & d/side 70mm
Anyone shed light on whether this is average or below standard height?
Cheers Ted
Yeah sorry!
Cheers Ted
I agree with Red90, and would say those measurements are normal for standard springs.
Regards,
Diff
