robhybrid Posted August 4, 2008 Share Posted August 4, 2008 I was looking back over some previous messages and thought this deserved to be a topic in its own right. And lets face it, What parts on our landrovers arn't being used above and beyond what they were designed for? Interior mirror ? Some of mine Series front grill used for a beach barbque? Series used to tow a fully laiden fire engine? Std 90 cv joints used to drive 35" simex? Std RR 10 spline half shafts used to drive 35" simex? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 5, 2008 Share Posted August 5, 2008 Td5 rear crossmember used for towing anything larger than a pram Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 5, 2008 Share Posted August 5, 2008 Series hi/lo gaiters used as bulkhead grommets. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted August 5, 2008 Share Posted August 5, 2008 Series hand brake to stop the car? Quote Link to comment Share on other sites More sharing options...
D9OSV Posted August 5, 2008 Share Posted August 5, 2008 Series 11 wipers to try and remove moisture Defender standard jack for changing wheels LOL Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 5, 2008 Share Posted August 5, 2008 Disco II headlight washer pump for engine water injection .... Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted August 5, 2008 Share Posted August 5, 2008 Defender standard jack for changing wheels Well said Another one is the damn wrench you get with the jack - no good on my alloys Quote Link to comment Share on other sites More sharing options...
Boothy Posted August 5, 2008 Share Posted August 5, 2008 Defender door catch, for catching belt or new jeans, or creating cat flap in back of new coat, and looking stooopid on the car park as you set off only to find you've hooked yourself!!! Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 5, 2008 Share Posted August 5, 2008 Land Rover door seals for keeping moisture out. Quote Link to comment Share on other sites More sharing options...
firemannotsam Posted August 5, 2008 Share Posted August 5, 2008 Land rover engine oil seals! Are they designed to gently drip to remind you you have to check the oil regular. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 5, 2008 Share Posted August 5, 2008 2007 Puma sumps Quote Link to comment Share on other sites More sharing options...
tonyalbers Posted August 5, 2008 Share Posted August 5, 2008 Defender 110" fan and heater to warm up the cabin and remove moisture from the windshield. /A Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 5, 2008 Share Posted August 5, 2008 2007 Puma sumps I thought you get quite a loud "sump" when it hits the axle - seems to be working fine Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 5, 2008 Share Posted August 5, 2008 Defender door catch, for catching belt or new jeans, or creating cat flap in back of new coat, and looking stooopid on the car park as you set off only to find you've hooked yourself!!! Good bottle openers though Quote Link to comment Share on other sites More sharing options...
Night Train Posted August 5, 2008 Share Posted August 5, 2008 Series 3 transfer box gears used to make three speed transfer box for 6x6 with pto. Series 3 used to tow a Thornycroft Antar tank transporter. Quote Link to comment Share on other sites More sharing options...
