white90 Posted January 25, 2009 Share Posted January 25, 2009 I am in need of some decent shelving to store allsorts in the garage ideally strong and with a few shelves any suggestions/advice or what have you done/amade etc? Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted January 25, 2009 Share Posted January 25, 2009 http://www.rapidracking.com/ Al Quote Link to comment Share on other sites More sharing options...
sotal Posted January 25, 2009 Share Posted January 25, 2009 Aldi had some cheap shelving units in on Thursday - probably still got some. They were 400mm deep by 1.8m high but I can't remember the width. No idea how good they were but I think they were rated for 90kgs per shelf which seemed quite good. Plus each shelf had a slide out drawer type thing. Not sure if they were plastic or metal but either way they were rated higher than the machine mart budget range. They were about £21 a peice. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 25, 2009 Share Posted January 25, 2009 Al's Mention is the stuff we have at work, the orange and blue stuff (and being orange, means you could have an extreme garage ) Quote Link to comment Share on other sites More sharing options...
Bio-Maniacs Posted January 25, 2009 Share Posted January 25, 2009 Also notice ALDI now have a set of parts bins for £8.27 looks good for storing nut & bolts http://www.aldi.co.uk/uk/html/offers/58_8704.htm Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 26, 2009 Share Posted January 26, 2009 If you have a look around some trading estates , I found loads of the stuff down in Avonmouth left outside in the corner , Just went in and asked and hey presto "Take the lot and how much do you want for clearing it " Admitidly it was the pallet sized shelving but just cut and weld it to suit , Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 26, 2009 Share Posted January 26, 2009 Are you able to bolt it to the walls Tony?? If so I've found the cheap shelving from Ikea, Aldi etc works well. If it needs to be free standing, then spending some money on a more robust metal shelving would be worth it in my opinion. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted January 26, 2009 Share Posted January 26, 2009 Angle iron is pretty cheap - how about welding some up, you could make it exactly as you want it (to fit the space etc). Al. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 26, 2009 Share Posted January 26, 2009 The stuff ciderman is talking about is pallet racking, it's almost as cheap as buying raw steel, slots together and holds 2 Ton per shelf. If you've got the space it makes a lot of sense. If you find a local business clearing out then you may get it for nowt as has been said. Quote Link to comment Share on other sites More sharing options...
smo Posted January 26, 2009 Share Posted January 26, 2009 The original link to rapid racking is your best bet - they are the daddies of "proper" shelving, sadly i recently bought some cheap stuff else where and wilst it does the job its not a patch on the real deal and with their buy one get one free it seems even better Quote Link to comment Share on other sites More sharing options...
andyb Posted January 26, 2009 Share Posted January 26, 2009 I would think that at the moment (cynical as it may seem) is to look out for industrial units that are clearing out or closing. Quote Link to comment Share on other sites More sharing options...
white90 Posted January 26, 2009 Author Share Posted January 26, 2009 I can bolt anything to the wall. plus I'll look out locally to see if any is going spare. I need enough for 12ft by approx 6/7ft high ideally 2-3ft depth. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 26, 2009 Share Posted January 26, 2009 Tony Thought you had some off scrumps ?? as i still have some of it, if wanted Quote Link to comment Share on other sites More sharing options...
davidlandy Posted January 26, 2009 Share Posted January 26, 2009 i can get tons of it to all sorts of dimensions are you in a hurry for it? Quote Link to comment Share on other sites More sharing options...
white90 Posted January 26, 2009 Author Share Posted January 26, 2009 No immediate hurry David Been in this house a year and just really getting around to sorting out the Garage. just keep moving stuff around trying to find other bits Quote Link to comment Share on other sites More sharing options...
white90 Posted January 26, 2009 Author Share Posted January 26, 2009 TonyThought you had some off scrumps ?? as i still have some of it, if wanted Tim I failed to collect it in time as I had to sort out the house first, unfortunatley it got moved on Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 26, 2009 Share Posted January 26, 2009 I got some good ones from Makro - not sure if they are a stock item. But they were very solid and a decent size. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted January 29, 2009 Share Posted January 29, 2009 Have a look at Key Online - tonnes of stuff in thier catalogue. Quote Link to comment Share on other sites More sharing options...
papadad Posted February 23, 2009 Share Posted February 23, 2009 Hi, I have a friend that bought a pallet load of slightly damanged aluminium extension ladders from a large hardware shop and used these for shelving, very strong and adjustable, I think he paid about $40.00 for them.Keep your eyes open at your local hardware. Papadad Quote Link to comment Share on other sites More sharing options...
