TimR Posted February 23, 2009 Share Posted February 23, 2009 Can someone please tell me where I can get some replacement fluid to fill up my rear lights? I have just taken mine off to clean the connectors and it all ran out... Quote Link to comment Share on other sites More sharing options...
therealboss Posted February 23, 2009 Share Posted February 23, 2009 Can someone please tell me where I can get some replacement fluid to fill up my rear lights? I have just taken mine off to clean the connectors and it all ran out... I think the Landrover Fairy will fill it again for you, for free! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 24, 2009 Share Posted February 24, 2009 You can use headlamp fluid without any problems. Don't fill them with wiring smoke though, they won't work. HTH Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 24, 2009 Share Posted February 24, 2009 If you have clear lense indicators with the orange bulbs, then headlamp fluid won't work as headlamp fluid is clear. Headlamp/sidelight/reverse/number plate fluid is the same P/No, as are tail/stop and rear fog lamp fluid. Early model indicators can use the same fluid as headlamp, etc, but later models need the correct orange fluid. Les Quote Link to comment Share on other sites More sharing options...
sgnas Posted February 24, 2009 Share Posted February 24, 2009 If you have a TD5 you need nanocom or a trip to the dealers to reset the ECU with the new fluid code. On the Puma model you need Landrover special tool LRS4587 to relieve the pressure while filling to prevent airlocks in the system. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 24, 2009 Share Posted February 24, 2009 I have some genuine fluid from an ex MOD Wolf I can sell you, only £79 a bottle. B) Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 24, 2009 Share Posted February 24, 2009 I believe you can refill them yourself with 'tears of frustration' - I'm sure someone will have some spare if you don't have any at the moment? Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 24, 2009 Share Posted February 24, 2009 Can anybody tell me where the filter is as my fluid seems to be contaminated and could do with a change. Dave. Quote Link to comment Share on other sites More sharing options...
TimR Posted February 24, 2009 Author Share Posted February 24, 2009 There is some good advice here chaps - thanks. I was just going to use this: Quote Link to comment Share on other sites More sharing options...
TimR Posted February 25, 2009 Author Share Posted February 25, 2009 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 25, 2009 Share Posted February 25, 2009 That'll be fine Tim but you'll need to add rear light concentrate to make the fluid effective. Mo Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 25, 2009 Share Posted February 25, 2009 Tim, I think that's the old part number, there's a one shot version available now, you'd be forgiven for thinking it looks like thick muddy water but when it gets warm it thins out and has the advantage that it won't leak out of the light seals when cold. Quote Link to comment Share on other sites More sharing options...
santalars Posted February 25, 2009 Share Posted February 25, 2009 Don't use the B**tpart replacement fluid. I had quality issues with that before. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 25, 2009 Share Posted February 25, 2009 Always remember that side indicators use a different fluid. This is specially designed to help corrosion of the fender Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 25, 2009 Share Posted February 25, 2009 I am wondering if this is the Fluide-de-la-FOOTWELLS? Someone used it before? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 25, 2009 Share Posted February 25, 2009 Well it's a common problem.. People tend to overfill the side indicators, and then the fluid runs inside the fenders and down into the footwell Quote Link to comment Share on other sites More sharing options...
santalars Posted February 25, 2009 Share Posted February 25, 2009 Just heard that y-eng are working on a haevy duty fluid. However at first there will be the TD5 version available only while the 200 and 300tdi version will follow later. Quote Link to comment Share on other sites More sharing options...
sparg Posted February 25, 2009 Share Posted February 25, 2009 You can use headlamp fluid without any problems. Don't fill them with wiring smoke though, they won't work.HTH Mo No, it's when the smoke escapes that they stop working Quote Link to comment Share on other sites More sharing options...
gazelle Posted February 27, 2009 Share Posted February 27, 2009 I would be careful with this. I suspect that it is a fake. The fluid is far to clear to be found in a Land Rover light! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 27, 2009 Share Posted February 27, 2009 I heard that the Army guys, as an in field repair, would urinate in theirs to replace it ..... works well on the indicators but not so good on the headlights. Quote Link to comment Share on other sites More sharing options...
howard14 Posted February 27, 2009 Share Posted February 27, 2009 Can someone please tell me where I can get some replacement fluid to fill up my rear lights? I have just taken mine off to clean the connectors and it all ran out... Difflock do a synthetic version. Hope that helps. Howard. 2x300TdiDef. Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted February 27, 2009 Share Posted February 27, 2009 I have some original Series 2 fluid that I just drained out, still clear as maiden's water even after 50 years. Offers before it goes on Ebay? Quote Link to comment Share on other sites More sharing options...
