Daan Posted January 6, 2010 Share Posted January 6, 2010 Hi, As the topic says, I was about to put the engine back in the car today, and the hydraulic hoist stopped working. I took it to bits, and I think the release ball valve didn't seal well, which I think I can solve. The oil was a bit dark as well, so I need to replace it. Will ATF work for this, or do I need to get hydraulic oil? And where do i get this round bicester? Cheers, Daan Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted January 6, 2010 Share Posted January 6, 2010 You should use hydraulic oil, something like ISO 32 grade. Any agricultural supplies, oil merchants or plant hire firm should be able to supply some oil. Manual hydraulic jacks etc use, IIRC, ISO 15 weight. I think that ATF is equivalent to ISO 5. Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 6, 2010 Share Posted January 6, 2010 I've always used ATF in jacks and engine hoists without any problems. Jon Quote Link to comment Share on other sites More sharing options...
Dave W Posted January 6, 2010 Share Posted January 6, 2010 I used olive oil in my old hoist, worked well although I did replace it with hydraulic oil later. It did allow me to get an engine in on a Sunday afternoon though Vegetable oil also works, just depends what's in the kitchen cupboard ! Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 7, 2010 Share Posted January 7, 2010 Used ATF for yonks with no ill effects. Quote Link to comment Share on other sites More sharing options...
Night Train Posted January 7, 2010 Share Posted January 7, 2010 I used olive oil in my old hoist, worked well although I did replace it with hydraulic oil later. It did allow me to get an engine in on a Sunday afternoon though Vegetable oil also works, just depends what's in the kitchen cupboard ! Any risk of veg oils damaging the seals? Just thinking of the problem with biodiesel and some pipes and seals. Quote Link to comment Share on other sites More sharing options...
cactus Posted January 7, 2010 Share Posted January 7, 2010 Hi Bit off subject but.....Will a Landrover tow an Antar? Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted January 7, 2010 Share Posted January 7, 2010 P A Turney's at Middleton Stoney would certainly have some proper hydraulic oil, but possibly only in much bigger volumes than you need. Any agric dealer should be able to help. You may even find that Halfords have some for topping up trolley jacks. H Quote Link to comment Share on other sites More sharing options...
Night Train Posted January 7, 2010 Share Posted January 7, 2010 Hi Bit off subject but.....Will a Landrover tow an Antar? Of course it will, unless it's a Series 1! Quote Link to comment Share on other sites More sharing options...
Dave W Posted January 7, 2010 Share Posted January 7, 2010 Any risk of veg oils damaging the seals? Just thinking of the problem with biodiesel and some pipes and seals. No, I would say that vegetable oil is comparatively passive. It's not something I'd use all the time anyway but works well and is normally in plentiful supply. My old engine hoist was, like most I suspect, one of those that became "communal" being passed from one person to another to the point where tracking it down was never easy. The seal around the control valve went after a couple of years so it would steadily drain it's contents between use. It got filled with just about everything with no detrimental effects. As far as I know it's still going strong although I've not seen it for about 2 years. Quote Link to comment Share on other sites More sharing options...
missingsid Posted January 7, 2010 Share Posted January 7, 2010 Of course it will, unless it's a Series 1! In which case it will pull 2 Quote Link to comment Share on other sites More sharing options...
Farmhand Posted January 14, 2010 Share Posted January 14, 2010 i have used atf before now, seems to work fine ! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 15, 2010 Share Posted January 15, 2010 Any risk of veg oils damaging the seals? Just thinking of the problem with biodiesel and some pipes and seals. The damage biodiesel (at least the horrible stuff most commercial producers cook up) can do to seals is due to excess methanol left over from the conversion reaction. Funnily enough, most homebrew stuff is better. If it isn't damaged by diesel, it won't be damaged by veg oil. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 15, 2010 Share Posted January 15, 2010 Daan, Your local car accessories place should stock 'Jack oil' ........ usually sold by 0.5 or 1L ........ there are several manufacturers, but I normally use Comma. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 15, 2010 Share Posted January 15, 2010 Anyone know why they say "do not use brake fluid" all over the jacks? I have a 2tonne halfords trolley jack which had started leaking from the main ram seal when sat unloaded. It would lift just fine once you topped it up but every time i picked it up there was a puddle of oil under it, until one day i needed to lift a car and only had some DOT5.1 spare. I figured it would get the job done and the jack probably needed replaced so if it killed it then it didnt matter too much. Since filling it with the DOT5.1 its not leaked a drop since... I'm not sure why, or if its going to give out with a bang at some point in the future? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted January 16, 2010 Share Posted January 16, 2010 Anyone know why they say "do not use brake fluid" all over the jacks? I have a 2tonne halfords trolley jack which had started leaking from the main ram seal when sat unloaded. It would lift just fine once you topped it up but every time i picked it up there was a puddle of oil under it, until one day i needed to lift a car and only had some DOT5.1 spare. I figured it would get the job done and the jack probably needed replaced so if it killed it then it didnt matter too much. Since filling it with the DOT5.1 its not leaked a drop since... I'm not sure why, or if its going to give out with a bang at some point in the future? brake fluid makes the seals swell up its a top bodge on leaking PAS box's to get them through an MOT Quote Link to comment Share on other sites More sharing options...
