Brakes...a brain picking mission
The brakes on my hybrid are s**t...
I am driving the rangie brake system from a standard series pedal and servo unit. The pedal doesnt move very far, the servo is working, yet it takes an enormous effort to stop the thing!
Im guessing that the whole force*distance thing is playing a part in this...running twin calipers from a master cylinder and pedal designed for drums and a small servo unit.
So....how can I improve them?
Things ive thought of so far....
1) Chop up spare rangie pedal box and replace pedal and servo with rangie bits...but its going to be a b*****d to fit around steering column and bonnet (why I fitted the series pedal in the first place)
2) Try and fit larger servo to series pedal
3) Fit rangie servo and master cylinder to series pedal
4) Dual servo units?
5) Introduce a small amount of air into system to allow compressabilty and allow pedal to move further, therefore more help from servo..????!!!
6) Leave as is and use 2 feet on brake pedal
7) Give up and drink beer. :P
Any more? Any opinions on these?
You don't have enough displacement to make the pedal work in siomple terms.
Fit a 90/110 unit and you'll find yer nose meets the windscreen on heavy braking
Forget the servo, that increases the pressure, f the displacement isn't there (which it is not IMHO) a servo the size of a washing machine won't do it
Nige
Had exactly that with series master cylinder and discs, part of the problem is the servo not producing enough assistance, you can use a series master cylinder with a 90/110 servo and it works OK.
Also the pedal box from a 90 fitsstraigh in, but you need to shorten the pedal slightly.
I suspect that the series master cylinder bore is too large in diameter, ie it has a larger piston surface area than a coiler mastercylinder. This is would give you a short pedal stroke. By fitting calipers, you have increased the piston surface area at the brake end which means you have made the 'mechanical advantage' of the system worse. A smaller bore master cylinder should restore the 'mechanical advantage' and you will get a longer pedal travel.
A swop to a suitable coiler master cylinder and servo would probably be the cure.
Regards,
Diff
I would have thought you'd need less displacement with discs than with drums.
Could be the Series servo just doesn't give enough pressure for discs so I too would reckon a servo off a disc-braked vehicle would do the trick.
If what Roger says is correct and the above, then I think you need a master cyclinder with a smaller diameter bore.
My reasoning being the pedal will need to move further to supply the same volume as you have now for the pistons and also pressure will be greater for the same pedal pressing force due to P = F/A as area of the bore has decreased. This will increase the force on the pistons.
(no doubt someone with a phd in physics will correct me if I'm wrong)
Regards,
Diff
What he said ^^^. :)
Chris
im also running a rangie braking system from a series peddle... works fantastically
Interesting....maybe there is something up with my servo then....or I might have got the pipes the wrong way around and its braking with the rear wheels first...?
Ill try that first, failing that...a 90 or 110 master cylinder....
Ill let you know how I get on.
Interesting comments as I am concidering a similar upgrade.
you seem to have better solutions but just for info this from Designa Chassis web site
"If your Land Rover has a Series III type servo & dual master cylinder already fitted these can be used, but you would still require a vacuum pump from a Citroen or Peugeot diesel & the Land Rover balancing valve"
Early 110 pedal assembly and servo will fit under a series bonnet no probs. Series dual circuit master cylinder fits straight up to it. The difference between the two masters is imperial vs metric threads and also the brake bias. Watch the bias as there a number of different ones out there, the plastic clip that looks like a cable tie around the master will tell you this.
I'm running the 110 servo with a series master on my series with disks all round it it works alot bettter than the old series servo ever did!
Tonk's running the same in his series.
HTH
Jon
yep, early assembly is smaller diameter but deeper, u'll have to trim your wing slightly, later assembly is shallower but bigger diameter which will leave u cutting a hole in your bonnet for it to stick through :rolleyes:
Been fiddling today. The brakes lock at the front (albeit with a lot of effort) so I havnt got the brake lines the wrong way round.
However...I think the servo must be knackered...You can feel the pedal moves down when you start the engine, but it moves back up again when the engine stops...
Anyone got a 110 pedal and servo hangin around?
