JST Posted August 25, 2006 Share Posted August 25, 2006 i know its been talked about before, but just wondering if mines hit the run in mileage yet as mpg has jsut gone up a bit. firstly i calculate mpg by 1. filling the tank to bottom of white plactic marker in the filler neck. 2. reset trip 3. refill to same point and note mileage 3. divide litres used by 4.54. 4. divide mileage by answer from 3. so last 2200miles it has only dropped below 30mpg once and that was 29.4 Last two fills each of 220 and 260miles respectively its done; 32.7mpg and 33.8mpg seems pretty good to me Thats on a 90 Td5 with overdrive and JE chipped (stage 1) The worse its ever done is 19.4 mpg but that was a 400mile round trip with 3.5T on the back of it. What does everyone else get Td5 wise? Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 25, 2006 Share Posted August 25, 2006 About 27mpg 110 with overdrive seems to get about the same, but often has two adults and 3 children on board. Cheers Steve Quote Link to comment Share on other sites More sharing options...
dottythe90 Posted August 25, 2006 Share Posted August 25, 2006 What does everyone else get Td5 wise? The 90 does around 28mpg on a daily use basis. Longer, non motorway runs average about 30mpg, but have had 33mpg on occasion. Motorway trips gives 25-26mpg. Standard vehicle, no overdrive The Disco usually does about 26-27mpg. Longer trips around 28mpg. Again, standard vehicle. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted August 25, 2006 Share Posted August 25, 2006 My discovery 2 is about 27 mpg but thats an auto so abit less is expected. Quote Link to comment Share on other sites More sharing options...
jules Posted August 25, 2006 Share Posted August 25, 2006 From the light being on to completely brimmed to the filler neck.. just under 500 miles out of a tank. Disco 2 auto about 84 lt max is around 27.02 are thats not so good but I do 68 miles in 1 hr 15 mins average each way every day. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted August 25, 2006 Share Posted August 25, 2006 If my 110 is anywhere near 25mpg i would count myself lucky, did check over the first few tank loads etc, and a trip to belgium, around 23 !! but all towing/round town etc the last one (53 110 XS TC ) did more or less the same !! Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted August 25, 2006 Share Posted August 25, 2006 I average about 27/28 mpg - that's a mix of around town, motorway and off roading. You know my car James, and it's not exactly lightweight...! Lowest was 25.2mpg - but that was on a 400 mile round trip towing a Disco on a trailer..... Matt Quote Link to comment Share on other sites More sharing options...
BoatBuoy Posted August 25, 2006 Share Posted August 25, 2006 110 with roofrack on, about 23-25mpg with load of survey gear in, and being driven like I stole it. Fortunately I have an AllStar fuel card. Quote Link to comment Share on other sites More sharing options...
pugwash Posted August 25, 2006 Share Posted August 25, 2006 I average about 27/28 mpg - that's a mix of around town, motorway and off roading. You know my car James, and it's not exactly lightweight...!Lowest was 25.2mpg - but that was on a 400 mile round trip towing a Disco on a trailer..... Matt That's bloody amazing considering you carry a main stealership with you at all times. Quote Link to comment Share on other sites More sharing options...
John_T Posted August 25, 2006 Share Posted August 25, 2006 About 29 overall including some heavy towing and off roading. Ona run it is about 32 but less on motorways. This is with AT tyres.....a bit less when I have the muds on. TD5 90 with overdrive. Quote Link to comment Share on other sites More sharing options...
nas90 Posted August 25, 2006 Share Posted August 25, 2006 I get 15mpg but only paying 44.5pence per litre. Oh! sorry it's you smelly diesel lot again! I'm gone....................... Quote Link to comment Share on other sites More sharing options...
cols110 Posted August 26, 2006 Share Posted August 26, 2006 firstly i calculate mpg by1. filling the tank to bottom of white plactic marker in the filler neck. 2. reset trip 3. refill to same point and note mileage 3. divide litres used by 4.54. 4. divide mileage by answer from 3. My odometer also over reads by about 4%, compared to my GPS, so I multiply my millage by .96 to get a corrected figure beofre doing the MPG calculation. If I get 27 I`m happy, normally its 25 or less. Mine normally gets driven at 70-75mph, or has an outing into the dunes, or has done a lot of city driving. I must admit, I was hoping the fuel ecconomy was going to be a bit better than what it is. I am going to have to do a good run just sitting on 60 to see what it can really do. Quote Link to comment Share on other sites More sharing options...
Top90 Posted August 26, 2006 Share Posted August 26, 2006 I always get between 30 and 32 mpg when not towing. Speedo is only 1 mph out at 40 and 2 mph out at 70, so quite accurate. With J Fearn reprogram and 15% gear increase from disco 2 T box gears. 9 months old (2005) and run in. (31,000 miles) From new it was about 27mpg, Richard Quote Link to comment Share on other sites More sharing options...
white90 Posted September 3, 2006 Share Posted September 3, 2006 36.62 litres and 307 miles yesterday collecting Vals new 110XS works out at 37.76mpg driven steady all the way home at 60-65mph Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 3, 2006 Share Posted September 3, 2006 36.62 litres and 307 miles yesterday collecting Vals new 110XSworks out at 37.76mpg driven steady all the way home at 60-65mph mmmm, would be interested in what the next few tankfulls return !! Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 3, 2006 Share Posted September 3, 2006 36.62 litres and 307 miles yesterday collecting Vals new 110XSworks out at 37.76mpg driven steady all the way home at 60-65mph wow - were you slipstreaming every lorry on the way home Tony?? Steve Quote Link to comment Share on other sites More sharing options...
AJL Posted September 3, 2006 Share Posted September 3, 2006 wow - were you slipstreaming every lorry on the way home Tony?? Steve My 110 is pretty poor 23 -25 if i'm lucky round Devons lanes flat out up the motorway sub 20! Quote Link to comment Share on other sites More sharing options...
JST Posted September 16, 2006 Author Share Posted September 16, 2006 just been upto Yorkshire and back trip up 360 miles on 45.53L - 35.9mpg at 60-65 motorway all the way up and down dale for the week 230 miles on 30.1L - 34.7mpg havent refilled since coming home but its done 260 miles and is showing half a tank (normally 210miles) Quite suprised really, good news though! Quote Link to comment Share on other sites More sharing options...
range366 Posted September 17, 2006 Share Posted September 17, 2006 Disco TD5, Auto Never made the 500mile mark but been very close. Always wait till the orange light is on and always takes £80 (or round about) of fuel. Whether its a week travelling on the M8 from Glasgow to Edinburgh and back (roughly 90 mile return trip and although I,ve tried, I aint ever stuck to 70mph) or the wife uses it for local trips over a couple of weeks it always returns over 420 miles for a fill up. Haven,t taken exact notes so I cant give an exact figure at the mo. Managed about 490miles on holiday in Yorkshire. Wife states that it gives better fuel economy than her Ford Focus 1.6 estate, so she now only drives the Disco, (think I,m getting conned here!!) Range366 Quote Link to comment Share on other sites More sharing options...
reads90 Posted September 17, 2006 Share Posted September 17, 2006 Sorry don't know don't care. I drove a Landy becasue i like it . If i worried about that i would have bought a diesel 106 Quote Link to comment Share on other sites More sharing options...
JST Posted September 17, 2006 Author Share Posted September 17, 2006 ditto i drive one because i like it. is this a minivin post? Quote Link to comment Share on other sites More sharing options...
white90 Posted September 17, 2006 Share Posted September 17, 2006 decent results there James our figures have slipped somewhat around town now doing 27mpg Quote Link to comment Share on other sites More sharing options...
freeagent Posted September 17, 2006 Share Posted September 17, 2006 ditto i drive one because i like it.is this a minivin post? sounds like it, perhaps someone should throw a huge gay strop if they don't get the answer they were looking for..... then it would be a minivin post... Quote Link to comment Share on other sites More sharing options...
Daan Posted September 18, 2006 Share Posted September 18, 2006 Slightly ot: Whats the final word of a 300TDI versus a TD5 when it comes to consumption? I remember people complaining about the TD5 being thirsty. Anyone has the exact answer how they compare? Daan Quote Link to comment Share on other sites More sharing options...
reads90 Posted September 18, 2006 Share Posted September 18, 2006 always makes me laugh about MPG on landies. Reminds me of a good mate of mine who had a TVR Chrimea. Another mate (who is a tight ar*e) of mine asked him almost every week for the 3 years he had it .what the MPG of the TVR was. Mate with the TVR always said. I don't know , don't want to know , jut fill it up when it needs more petrol. My tight ar*e mate could never understand that you have a car because you like it and not because of what MPG it does. It always shocked him that my mate never knew what MPG the TVR did even up to when he sold it (btw he only sold it because his misses had a kid , and he could not get a car seat for the back ) Quote Link to comment Share on other sites More sharing options...
