rusty_wingnut Posted October 8, 2012 Share Posted October 8, 2012 Those nightmare buffers that go into the bulkhead, does anyone have any good tips on fitting them? Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2012 Share Posted October 8, 2012 warm them in hot water first & lubricate the small bit with vaseline or similar, they will pop in to place, a small flatblade screwdriver to assist the small end into the hole will help. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 10, 2012 Share Posted October 10, 2012 Eh? They just slide in on every vehicle I've ever owned... Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2012 Share Posted October 10, 2012 mine don't slide in, they have to be pushed into a hole these buffers Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 10, 2012 Share Posted October 10, 2012 i don't even have holes for them anymore, so i don't have to do any slideing, lubeing or otherwise.. Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted October 10, 2012 Share Posted October 10, 2012 Reminds me, one of mine fell out the other day, must get a new one. Never had trouble putting them in before, just spat on them and pushed them in. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 10, 2012 Author Share Posted October 10, 2012 Well I had one of them and was leaning against it and feeding the lip with a screwdriver with no luck - guess I'm just weedy I shall try warming them Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 10, 2012 Share Posted October 10, 2012 When i did have holes for them i just used patience and a small screwing driver if memory serves... Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted October 10, 2012 Share Posted October 10, 2012 Just had a look at my truck as I've never noticed these buffers before, mine are fine it seems because there is a 1cm gap between them and the bonnet ROFL! Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 10, 2012 Share Posted October 10, 2012 I was wondering where these actually go in the bulkhead..... As apparently water ingress can happen if they are not fitted. I have a 1997 300 tdi and am not sure if i actaully should have them..... But i do know that a get water in through the driver heater vent... So... Were should these go ? Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 10, 2012 Share Posted October 10, 2012 Well The search facility works..... Here a link to a previous thread showing the location.... http://forums.lr4x4.com/index.php?showtopic=58603&hl=+bonnet%20+buffer#entry513141 Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2012 Share Posted October 10, 2012 Yep, get them fitted if not already, V8Freak had to fit new ones to his red 110 a few years back, that thread should be in here somewhere too. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 10, 2012 Share Posted October 10, 2012 Yep, get them fitted if not already, V8Freak had to fit new ones to his red 110 a few years back, that thread should be in here somewhere too. I have tred and failed to find the thread. So are the holes in the bulkhead along the line where the bonnet meets the bulkhead? Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 10, 2012 Share Posted October 10, 2012 when i fitted them, i cut about 2/3rd' of the thingy and put some tiger seal around it, it went straight in and was also 100% water proof. Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2012 Share Posted October 10, 2012 I have tred and failed to find the thread. So are the holes in the bulkhead along the line where the bonnet meets the bulkhead? Yes, just inboard of the bonnet hinges, the first photo in the link you posted shows the holes they fit into. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 12, 2012 Author Share Posted October 12, 2012 This is the very reason my passenger footwell keeps filling up! Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 12, 2012 Share Posted October 12, 2012 Just had a look at my 300 tdi ..... Both are missing ! May be one of the reasons it leaks like a sieve! Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 15, 2012 Author Share Posted October 15, 2012 Right top tip from me, smear the points in fairy liquid and they press right in. No need to heat them or cut them about. Quote Link to comment Share on other sites More sharing options...
western Posted October 15, 2012 Share Posted October 15, 2012 Right top tip from me, smear the points in fairy liquid and they press right in. No need to heat them or cut them about. Next time it rains you'll have a cab full of bubbles Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 15, 2012 Share Posted October 15, 2012 Right top tip from me, smear the points in fairy liquid and they press right in. No need to heat them or cut them about. Thanks for the tip - I'll let you know how it goes ! Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted October 15, 2012 Share Posted October 15, 2012 Right top tip from me, smear the points in fairy liquid and they press right in. No need to heat them or cut them about. Same applies for fitting windscreen and other glass seals. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted October 21, 2012 Share Posted October 21, 2012 Well the washing up liquid tricks did the trick nicely. also found the soucre if the drivers footwell leak. The top left hand nut and bolt of the pedal box was loose alliwing water to ingress and then drip onto accelerator pedal and floor. Its only taken two years to find the source!! Quote Link to comment Share on other sites More sharing options...
MECCANO Posted October 21, 2012 Share Posted October 21, 2012 Any idea on their OD? I think these might be a great addition to my lwts bonnet to finally stop it sqeaking. Cheers Chris Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted October 22, 2012 Author Share Posted October 22, 2012 About 25mm OD and 8mm thick? Quote Link to comment Share on other sites More sharing options...
MECCANO Posted October 23, 2012 Share Posted October 23, 2012 Cheers Quote Link to comment Share on other sites More sharing options...
