Which rear recovery point?
I seen these two different types of recovery point to fit to the tow hitch holes on a rear crossmember. Other than price and visual size, has anyone got any experience/views of their suitability? I'm looking at something that can handle recovering vehicles with 1 axle stuck, with snatching being a rare event.
http://www.lrsshop.co.uk/content/rear-recovery-hitch
http://www.ebay.co.uk/itm/Land-Rover-recovery-Swivel-Shackle-/321077261238
I already have jate rings, but find the ability to not get on hands and knees appealing!
I didn't realise the td5 crossmember was that much different.
Dixon bate do several types of jaw, the 3.5 ton bolt holes are standard tow ball fitting, the 5 ton jaw bolt holes are the same as the NATO hitch.
I was in Leisure Mart in Pershore last week they do a combined ball & pin rated at 4 ton for about £25.
Land Rover does a kit for the Td5 which allows you to mount a hitch on the crossmember. It includes a spreader plate and reinforcing bracket. Like many Genuine Parts items it's not cheap, but it's quick and easy to fit.
Phil.
Phil.
Phil, do you have any idea of a part number for that kit by any chance ?
Mo
I believe JATE rings were designed for attachment of the lifting strops used when moving vehicles as an underslung load beneath a helicopter. The army does use them for recovery, although we were taught not to on the driving course I did 30 years ago. I'm sure someone will be along to explain any technical issues, however, the main issue I've found is practical.
I find it much easier to pop a recovery rope in the jaw of a tow hitch on the crossmember than to get under the vehicle and fix a strop to rear JATE rings which tend to be especially hard to reach when the vehicle's bogged down.
Phil.
After some more research, they both seem to have been used with no dramas. The swivel one looks like it's made for pre-Td5 as it has a sandwich plate that it screws into.
Here's some other good reading:
http://www.defender2.net/forum/post213250.html
http://forums.lr4x4.com/index.php?showtopic=2690 (Lots of photos missing but enough to illustrate)
http://forum.landrovernet.com/showthread.php/158018-Rear-recovery-point-on-07-110-Standard-x-member-strong-enough
I think I will try to get a spreader plate and use a Dixon bate ball with pin eventually. In the meantime i've bought the fixed loop recovery point.
Thanks for the ideas!
Use a bridle with JATE rings, it spreads the load between the 2 rings/chassis rails, There's a few threads in here about JATE ring use & a drawing of how I fit a tow rope with a bridle.
if you suspect the vehicle might get stuck fit the recovery rope/strop before going into the sticky stuff.
