bobtail84 Posted January 4, 2015 Share Posted January 4, 2015 Is this what your looking for? Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted January 4, 2015 Author Share Posted January 4, 2015 I certainly don't have that page, has to be the one! Thank you. Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 5, 2015 Share Posted February 5, 2015 How did you get on with the DB37? Like you i had such a horrible time with it, i ended up sourcing crimp type plugs. For belt and braces security i melted a little solder to each crimp before adding the heatshrink. For the life of me though i cant remember where i got the crimp type DB37 connectors, but they do make life easy. The only thing that you must have are GOOD QUALITY crimpers. Cheapos just wont give a professional crimp. I invested in Hozan crimpers as i made a custom vehicle harness so had lots of crimps to do. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 5, 2015 Share Posted February 5, 2015 ^^^^^^^^^ Er from ME lol....... Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 5, 2015 Share Posted February 5, 2015 Sorry Nige Im taking so long to finish mine i forget. I sometimes think my name is Warne..... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 5, 2015 Share Posted February 5, 2015 No probs Will...I mean Phil. .. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted February 8, 2015 Author Share Posted February 8, 2015 I have to admit defeat, it's just too fildly and I can't guarantee I'm not going to short the lot, so in fact today I was looking to make a purchase from a certain well known V8 Megasquirt site of one pre-wired D37. Are these crimpable connectors the ones on this page, third item down from the restrictor plates? http://www.megasquirt-v8.co.uk/ms_optional.php Nige - order incoming either way for some restrictor plates and a few other things. I'm going to be sending my crank pulley to you, could just bundle it into one package for the return to save you time? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 8, 2015 Share Posted February 8, 2015 Yup no probs at all sir Quote Link to comment Share on other sites More sharing options...
skauldy Posted February 19, 2017 Share Posted February 19, 2017 Hi 3.5, do you know the part number for the male plug to do this mod shane Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 20, 2017 Share Posted February 20, 2017 er which plug sir ?? Quote Link to comment Share on other sites More sharing options...
skauldy Posted February 20, 2017 Share Posted February 20, 2017 Sorry nige. I'd like to use the gems coil pack also. Looking for the ampseal or super seal plug that's mates up with it. Shane Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted March 25, 2017 Author Share Posted March 25, 2017 I got mine from the loom that came with the engine, no idea if it's available as a separate part but eBay's got to be the place to try. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 25, 2017 Share Posted March 25, 2017 I have new plugs I think for that Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 8, 2017 Author Share Posted April 8, 2017 (edited) Evening all, I've searched and found no definitive answer to this: do I need a Fuel Pressure Regulator? That is to say, the disc-looking chap that sits at the end of the fuel rail on the return line? All results I can find are talking (normally at cross purposes) about the Pressure Relief Valve, which is not the same thing. I was certain from Nige's manual that it says to cut off the nut that secures it to the rail (but in my version it doesn't actually explicitly say what the nut is for, though there is only one so not hard to work out). I was confident in this until I saw that Mr Fridge's build has it installed. Also noted on Fridge's build and something I like the idea of is the in-line filter on the return line to see quantity/quality of fuel going through but I need to find out where I stand on the regulator before I make any more changes to the fuel system. Edited April 8, 2017 by ThreePointFive Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 8, 2017 Share Posted April 8, 2017 Yes, you need a pressure reg, other wise you're injectors will see either zero or 100PSI, which is no good at all. Not sure what nige is referring to when cutting a nut off.... I would ignore it or post a photo of it here for clarification Quote Link to comment Share on other sites More sharing options...
Quagmire Posted April 9, 2017 Share Posted April 9, 2017 Could the "nut" being referred to actually be the union on the fuel rail which you would use to connect the factory pipework to? If you are fitting rubber fuel line with hoseclips then that needs to be removed so that the fuel hose can be pushed on. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 9, 2017 Author Share Posted April 9, 2017 I found the page. Its not on the return line as I'd guessed from memory but that is the nut I removed about two years ago following my interpretation of that instruction and the only one I had anywhere near that location. There is no other way to connect the regulator so I'm a little concerned now. I'm sure there's something glaringly obvious as to how I've misinterpreted it, but at the moment I can't see what else it would be talking about. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 9, 2017 Share Posted April 9, 2017 OK, have you got a full pic of your fuel rail? Opposite side to the fuel inlet you should have the fittings for the regulator... If not it is expecting an external regulator. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 10, 2017 Share Posted April 10, 2017 Aye, I don't think the regulator goes on that nut and yes you do need one unless you are driving a later Thor P38 which I believe has the regulator in the fuel tank/pump assembly. Maybe these will help: This chappy (Early P38) I believe is to smooth out pressure fluctuations: Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 10, 2017 Share Posted April 10, 2017 Thanks FF, those were pics I was thinking of, was on phone before so tricky Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 10, 2017 Author Share Posted April 10, 2017 Having problems uploading pictures from mobile, but the bit I was referring to is the one in FFs last photo. I was operating under the impression that is the pressure regulator and the thing on the nearside rear of the plenum is the relief valve. Seems yet again I've made a tit of myself. Regardless, do I need that thing, because it's going to be a tad challenging to refit. Thanks for the help, anyway. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 10, 2017 Share Posted April 10, 2017 I can't imagine you will notice that thing missing. I'm assuming you do have a PRV as per FF? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 11, 2017 Share Posted April 11, 2017 Well, technically the FPR is a pressure relief valve, that's all it does. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 11, 2017 Share Posted April 11, 2017 Yes, sorry, getting my acronyms sort of muddled there Replace PRV with FPR in my post above... Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 17, 2017 Author Share Posted April 17, 2017 (edited) So if the FPR is the PRV.... Wish I'd worked that out before I posted. Thanks for the help, I guess it must be like trying to teach a monkey astrophysics. So here is a picture of what I've got, minus the weird disc thing on the inlet rail. FPR sitting in there somewhere... Filter idea not at all stolen from Fridge's build... Edited April 17, 2017 by ThreePointFive Quote Link to comment Share on other sites More sharing options...
