reb78 Posted August 13, 2016 Share Posted August 13, 2016 I'm fairly handy with the spanners etc. it's looking like my gearbox is going to have to come off, so I'm thinking I might recon my spare transfer box at the same time to replace the leaky one on there. Is there anything massivley challenging about the job? Are any special tools required? 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 13, 2016 Share Posted August 13, 2016 I've rebuilt one in the back of a 110..... Dead easy. Hardest bit was keeping my hands clean to eat my chips. All the info is in the workshop manual and iirc you need spanners and bearing pullers and that's it. There is a shim in the front output housing that might need changing but I doubt, and there is also a shim behind the front bearing of the input gear. 1 Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted August 13, 2016 Share Posted August 13, 2016 Easy have done two recently. Access to a large vice, some brass drifts and a dishwasher also helps!! If you get the overhaul kits they come with all the new stake nuts, seals, bearings, crush tubes diff lock switch etc. Pay extra to get Corteco seals and Timken bearings. Toby 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 13, 2016 Author Share Posted August 13, 2016 That all sounds reassuring! What's the general thoughts with the intermediate shaft where it sits in the txb case? Just replace the o rings there, or is it really a common problem for the hole itself to wear and need a steel insert? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 13, 2016 Share Posted August 13, 2016 I've never seen one with an oval hole.... However, I should be able to make a decent repair of it if you need it doing. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 13, 2016 Share Posted August 13, 2016 Or me, or Dave on my mill! I've studied the manuals and come to the conclusion the t'box is that easy it isn't worth sending to a specialist, the LT77 on the other hand is. Plus although it's heavy, it's not a major job to get the t'box off if it fails, whereas the LT is much more of a job. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 13, 2016 Share Posted August 13, 2016 Yep. You'll need a dishwasher. most of the bits that fit have been in mine. these rear bumperettes came up a treat. Quote Link to comment Share on other sites More sharing options...
Tal Posted August 13, 2016 Share Posted August 13, 2016 euww thats gnarly...If I did that I would end up having to buy a new dishwasher and crockery..couldnt bring myself to eat off them Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 13, 2016 Share Posted August 13, 2016 My wife would kill me to though we do have a spare dish washer and I haven't set up this garage yet...... Mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 13, 2016 Share Posted August 13, 2016 My missus would castrate me ....... If she found out ? Mo Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted August 13, 2016 Share Posted August 13, 2016 Wendy!!!!!!! Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 13, 2016 Share Posted August 13, 2016 SShhhhh. she'll take me bits off if she see's what i did. funny, the machine died shortly after. totally due to an unrelated issue....... i hope. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted August 14, 2016 Share Posted August 14, 2016 I am lucky enough to have a dishwasher in the shed. I did put some stuff in the house dishwasher once, but I got serious earache when it turned dark grey! Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 14, 2016 Share Posted August 14, 2016 i fly tipped mine at Chudeigh. ( just kiddin ) Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 17, 2016 Author Share Posted August 17, 2016 A further question on this. With my current transfer box, i believe the only issue that it has it leaking from the intermediate shaft o rings. Now, i think there are two in there - one in the case and one on the shaft. With the box off of the vehicle, can i remove the intermediate shaft, replace the o rings and reset the preload on it (with a new crush spacer) without dismantling anything else? I have a feeling that the gears that the intermediate shaft mesh with will need to be removed to do this so the answer is probably no? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2016 Share Posted August 17, 2016 You can almost certainly drop the intermediate shaft from the box without removing anything else. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 17, 2016 Author Share Posted August 17, 2016 But can I set the preload properly on reassembly? When I got this box, it had a loose stake but on the intermediate shaft so it'd be nice to make sure it's set properly. I'm probably cutting corners and should just rebuild the box properly! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 17, 2016 Share Posted August 17, 2016 Do the whole box Rich, save you taking it apart to fix something else next year ? Mo Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2016 Share Posted August 17, 2016 Is your spare transfer box good enough to fit and then rebuild the one on there now? Quite happy to give you a hand swapping them and rebuilding/repairing the one fitted now? Iirc you have a later, better LT230 fitted at the min. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 18, 2016 Author Share Posted August 18, 2016 I may take you up on that David I could just refit my old box, it leaks in the same way the newer one does. Annoying really as the person who sold me the current one assured me it was a leak free perfect box. (They aren't on here or other fora much these days...) What makes the td5 transfer box better than my original from 1989? My current thinking is drop the lot this weekend. Recon one of the TXBs I have in the evenings next week. Decide what an earth to do about the main gearbox (repair or replace) and refit the lot next weekend. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 18, 2016 Share Posted August 18, 2016 Mainly the gears are cut to a different angle to keep the noise down a bit more. Quote Link to comment Share on other sites More sharing options...
toenden Posted August 19, 2016 Share Posted August 19, 2016 I went for a td5 "q" tbox from a d2 a couple of years ago, mainly to try the 1,2 gearing. Even in my tdi powered, mudterrain running soft top I could hear the noise difference... :-) /Mads Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 19, 2016 Author Share Posted August 19, 2016 Yep - my understanding was that it is the Q boxes that were quieter. I run an overdrive on my 110 - i thought the Q boxes had the gear angles cut such that the OD couldn't be used on them? Or, am i thinking of something else? Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 19, 2016 Share Posted August 19, 2016 To save starting a new topic I have a couple of related questions.... I have a number of transfer boxes on the floor including a late TD5 disco one without the difflock mechanism. I am hoping to rebuilt a good box using the internals from the TD5 box (Q gears???) into an earlier case with a difflock fitted. Is this possible to do? This will be to replace current box on the 110 which is starting to leak quite badly from around the slaked nut. Is there a temporary fix for this without removing the box from the car? Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 19, 2016 Share Posted August 19, 2016 Overdrives are only available for 1.4:1 LT230s, not 1.22:1, irrespective of the tooth geometry. Quote Link to comment Share on other sites More sharing options...
