HoSS
Volvo C303 Overlander Build
157 posts in this topic
Great thread HoSS. you have a very impressive & eclectic skill set.
Many thanks for your time
regards all
Gren
Share this post
Link to post
On 9/14/2016 at 10:41 AM, Tobias said:
Care to explain why you need two MadMans?
Too many things for one, also being able to see 2 key readings at the same time e.g. water temp and EGT.
Number 1 has:
- Oil Pressure
- Coolant temp
- Air temp
- Relay controls radiator fan
Number 2 has:
- Boost pressure
- Intercooler temp
- EGT
- Relay controls intercooler fans
2 people like this
Share this post
Link to post
On 6/13/2016 at 8:03 PM, landroversforever said:
What if the windows were on the top section? They'd still be secure when the roof is down.... But they'd be vulnerable to damage.
Yeah i might do that, it would put the windows at a better height inside (head rather than crotch)
Share this post
Link to post
Well it moves... A short lap of the garage was achieved last night. Gearbox & controller behaving. No leaks. I need to reduce the PS pump pressure - Merc puts out 115 bar and my GM700 steering box i think is rated for 75, nothing blew but a quick cut of the spring will sort that.
Still lots to do, but i think i deserved the morale boost of seeing it move for the first time in 2 years.
2 people like this
Share this post
Link to post
Great to hear that HoSS! :D But where is the video proof? :P
Share this post
Link to post
Congratulations HoSS!!  Did you end up raising the motor to get more sump/axle clearance or is that a job for later?  And yes please post a video of its first burnout:)
1 person likes this
Share this post
Link to post
I've raised the cab another 40mm to enable me to raise the motor 40/50mm but havent put the spacers under the motor yet.
Share this post
Link to post
I took a clip earlier, will post it when i work out how to edit and upload.
I put the spacers under my engine mounts, now have a lot more clearance to the front axle, but my PS pump pulley is not 5mm from the body. So i'll have to go back down a little or move the PS pump (not easy).
So whats the best way to check axle articulation without removing the springs?
Thinking out loud.....
I certainly have more clearance vertically, about 100-150mm from sump to axle. And the bump stop gap is only about 50mm. But i'd like to be a bit more scientific to be sure they wont meet, and to see how much i can drop the engine down a little (PS Pump).
Jacking one wheel up is not going to represent the shock loading travel, but i guess it gives an idea which way things are moving...
Share this post
Link to post
HoSS
is it possible to modify the side of the engine compartment to give you a little more space for the PS pump without encroaching into the footwell too much?  I know the MB engine mounts are quite flexi so a bit more space may be available that way rather than lowering the motor again.
Share this post
Link to post
Can you check my measuring distance to bump stops and comparing to diff clearance. Whatever you do it shouldn't go beyond the bump stops!
Or find someone with a loader to push down on the front?
Share this post
Link to post
Well it can go beyond when the bump stops are compressed in shock load. But more than that, i need to look at where it ends up in several cases: one side fully compressed, the other and both.
Share this post
Link to post
Its always better to work on there being no bumpstops so you always have a worst case clearance Al. I assume its on leaf springs HoSS?
Share this post
Link to post
Just taken some measurements.
Diff to sump (nearest point) = 100mm
Bump stop gap = 40mm
If no bump rubber = 100mm
What do you think? Drop a bit..20mm?
The bumps wont compress 100%, but i guess if one drops off....
Share this post
Link to post
I've worked on the basis that the bump stops could compress completely, I've got 12mm between sump and axle with the axle against the chassis and no bumpstops.
Share this post
Link to post
But this is expedition not winch challenge racer right? How hard are you planning on pushing it? You've got to go easy to make sure it's going to get you home right? So in that case you shouldn't be hitting the stops anyway?
Obviously it's better to have a bigger gap so you don't smash the sump when your driving tired in the dark and don't see something but if it causes problems elsewhere how much are you prepared to risk? Could you guard the sump or whatever? Or a none deformable bump stop slightly higher? Or hack a bit of space around the pas pump?
Share this post
Link to post
Sure, but as you say if i mess up somewhere remote and put a hole in the sump im screwed. In an winch challenge i trailer it home. Its actually more critical.
Thats really my question - whats the compromise between squashing the motor in and a safe gap. My thoughts are 50% bump stop compression, but i'm looking for advice.
I could guard the sump, but thats effectively reducing the clearance and no guarantees that clouting the guard wont damage what its mounted to which would be the Alu block.
I've already moved the PAS pump in as far as i can. I can cut the body but its close to a support member and i dont really want to as it will weaken the cab. If the advice is maintain the gap of 100mm (no bump stop) then i'm inclined to relocate the PS pump somewhere else....not easy but possible
Share this post
Link to post
Ok a small video of movement. Yes, the rattle you hear while pulling away is the PS pump pulley on the body.
for anyone that knows these Merc engines, i'd be interested what you think of the idle sound, it sounds clacky to me, and pretty sure it didnt do that when in the e300 (although it was more enclosed/ soundproofed in  there)
Video proof
1 person likes this
Share this post
Link to post
Nice one!
Can't hear much of the idle in the video but I remember mine sounding quite rattly at idle with the bonnet open.
Share this post
Link to post
Video proof
Did you use the mecedes engine support ?
check the serpentine tensionner shock ,the shock itself is fine but the bushing goes wrong .
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
