reb78 Posted April 19, 2015 Share Posted April 19, 2015 I cant figure out why i cant stop this. I've tried two filler caps and a new filler neck and it is still leaking. Any ideas? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted April 19, 2015 Share Posted April 19, 2015 Stop putting fuel in? It looks like pressure building up and forcing it's way past the seal or air vent in the caps..... But I can't see why a new cap didn't sort it !! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 19, 2015 Share Posted April 19, 2015 Check the breather is clear there should be a small black plastic tube some where on the top of the tank. Failing that a new filler neck maybe in order. Mike Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2015 Share Posted April 19, 2015 My 110 does the same even with a clear breather hose & vented fuel cap. But only when I fill half way up the filler neck, with fuel level below the neck bottom fuel doesn't get pulled out. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted April 19, 2015 Share Posted April 19, 2015 Mine did this. I stopped filling at 1 click instead of 3 clicks, which helped a bit. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted April 20, 2015 Share Posted April 20, 2015 Mine did this. Like you, I tried everything. The only thing that worked was only half filling the tank. I figured it was because the filler neck was pitted at the point where the seal contacts it. I've just (this week) fitted a TD5 plastic filler neck and cap to see if it works. Once I've filled the tank up I'll let you know if it has worked. It was a fairly easy mod. All I needed was a step down (20mm to 14mm) pipe bayonet fitting: http://www.ebay.co.uk/itm/361002248732?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT because the return pipe on a TD5 is slightly larger, and then I fabricated a bracket where it bolts to the tub. The actual main delivery pipe needscutting down in length but is the right diameter. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 20, 2015 Author Share Posted April 20, 2015 Be good to hear how you get on with the TD5 neck. Did this need a new cap as well? I hate the mess the current setup is making of the back of my 110, not to mention the waste! Quote Link to comment Share on other sites More sharing options...
western Posted April 20, 2015 Share Posted April 20, 2015 I hate the Td5 filler cap, needs the key in it as you remove/refit the cap. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 20, 2015 Author Share Posted April 20, 2015 I hate the Td5 filler cap, needs the key in it as you remove/refit the cap. I do that with my current one anyway! Quote Link to comment Share on other sites More sharing options...
western Posted April 20, 2015 Share Posted April 20, 2015 but the existing cap only needs to be turned half a turn at the most, Td5 has to be unscrewed/screwed on more than 1 full turn. Quote Link to comment Share on other sites More sharing options...
Hazza Posted April 21, 2015 Share Posted April 21, 2015 I've just (this week) fitted a TD5 plastic filler neck and cap to see if it works. Once I've filled the tank up I'll let you know if it has worked. It was a fairly easy mod. I did the same on my 110, just be aware that the tank has no breather so you might find (as I did) that it develops either massive negative or massive positive pressure! I had to fix a breather into the Filler neck using a push fit bulkhead fitting. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 21, 2015 Share Posted April 21, 2015 Hazza and western fit a discovery 1 cap there the same thread but no key and they have a 1/4 turn vented/unvented facility built into the cap. Mike Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted April 21, 2015 Share Posted April 21, 2015 I hate the Td5 filler cap, needs the key in it as you remove/refit the cap. No it doesn't.. I un-lock mine and remove the key before taking the filler cap off.... Quote Link to comment Share on other sites More sharing options...
Hazza Posted April 21, 2015 Share Posted April 21, 2015 Hazza and western fit a discovery 1 cap there the same thread but no key and they have a 1/4 turn vented/unvented facility built into the cap. Mike Not sure I'd risk not having a locking cap...i know the tank is easy to drain but this would make it that but easier to do subtly! Quote Link to comment Share on other sites More sharing options...
Hazza Posted April 21, 2015 Share Posted April 21, 2015 No it doesn't.. I un-lock mine and remove the key before taking the filler cap off.... Agreed, no key needed here either Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 22, 2015 Share Posted April 22, 2015 No it doesn't.. I un-lock mine and remove the key before taking the filler cap off....Mine is the same as that too. Remove key before unscrewing. Mo Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted April 22, 2015 Share Posted April 22, 2015 If you go for the Carlos Vandango - Super-dooper go fast version with thing attached.... You won't leave it on your spare wheel carrier up a mountain in Italy and lose it either..... Quote Link to comment Share on other sites More sharing options...
C18RCH Posted April 22, 2015 Share Posted April 22, 2015 I did the same on my 110, just be aware that the tank has no breather so you might find (as I did) that it develops either massive negative or massive positive pressure! I had to fix a breather into the Filler neck using a push fit bulkhead fitting. Mine already has a breather fitted. And yes, you need the neck and a new filler cap. Don't know about the key, haven't had to fill it up yet since I did it. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted April 29, 2015 Share Posted April 29, 2015 Brimmed it this morning on the way into work. Gave it some boot around the corners for good measure. Not a drop, the mod seems to be working so far. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 29, 2015 Author Share Posted April 29, 2015 sounds promising! What breather system do you have on your tank? On mine, the breather is through the cap, but sounds like the TD5 uses a different system and that you have an alternative already in place? Quote Link to comment Share on other sites More sharing options...
C18RCH Posted April 29, 2015 Share Posted April 29, 2015 My tanks has a separate breather pipe at the front right corner. I have one of the extended wading kit breathers off ebay fitted to it: http://www.ebay.co.uk/itm/Land-Rover-Defender-Wading-Kit-ORANGE-V8-Engine-Gearboxs-and-Axles-/371250364168?pt=LH_DefaultDomain_3&fits=Model%3ADefender&hash=item56703eff08 Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 21, 2015 Author Share Posted September 21, 2015 Just resurrecting this from earlier this year. Cackshifter on another thread has mentioned that the Genuine caps are the only ones he has found to seal properly. I get two part numbers for this on searching - RTC4740 and STC4072. I think the latter supersedes RTC4740. Does this mean that there is no difference between them as parts are available under both numbers on LRDIRECT? Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted September 21, 2015 Share Posted September 21, 2015 Britcar is quite good for this type of information. Yes, STC4072 is the direct replacement for RTC4740 http://www.brit-car.co.uk/product.php/419684/5497/superceded_by_stc4072 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 21, 2015 Share Posted September 21, 2015 ...stc4072 was the gen part I got from lrdiect. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 21, 2015 Share Posted September 21, 2015 You should see mine. The filler tube is almost level with the top of the tank ! Even the lorry driver who delivered it ended up with his truck bed wet...... At least its the only thing that leaks at the moment. So i'm thankfull for small mercies. Quote Link to comment Share on other sites More sharing options...
